apt-get & aptitude hittar ej "paketen"
beedj
Inlägg av beedj »
Jag kör ubuntu server och har letat upp paketen jag vill köra på: packages.ubuntu.com, men när jag försöker installera paketen jag vill ha, får jag felmed: "Couldn't find any package whose name or description matched ...."
någon som vet vad detta beror på?
marwal
Inlägg av marwal »
posta innehållet i filen /etc/apt/sources.list (gksudo gedit /etc/apt/sources.list) (eller kedit om du kör KDE)
posta också namnet på det program du letar efter.
beedj
Inlägg av beedj »
Jo, Jag tänkte ta hem tex, proftpd.
(se.archive.ubuntu.com/ubuntu/pool/universe/p/proftpd/)
min sources.list ser ut såhär:
# deb cdrom:[Ubuntu-Server 6.06.1 _Dapper Drake_ - Release i386 (20060807.1)]/ dapper main restricted
deb http://se.archive.ubuntu.com/ubuntu/ dapper main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ dapper main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://se.archive.ubuntu.com/ubuntu/ dapper-updates main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ dapper-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://se.archive.ubuntu.com/ubuntu/ dapper universe
deb-src http://se.archive.ubuntu.com/ubuntu/ dapper universe
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://se.archive.ubuntu.com/ubuntu/ dapper-backports main restricted universe multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ dapper-backports main restricted universe multiverse
##deb http://security.ubuntu.com/ubuntu dapper-security main restricted
##deb-src http://security.ubuntu.com/ubuntu dapper-security main restricted
deb http://security.ubuntu.com/ubuntu dapper-security universe
deb-src http://security.ubuntu.com/ubuntu dapper-security universe
marwal
Inlägg av marwal »
det ser väl rätt bra ut.
kommentera gärna bort raden som börjar med "deb cdrom (så att den börjar "#deb cdrom")
vad händer om du skriver:
sudu aptitude update
sudo aptitude upgrade
sudo aptitude dist-upgrade
(starta om om det krävs)
sudo aptitude install proftpd
EDIT:
Undrar om inte
ska vara
deb http://se.archive.ubuntu.com/ubuntu/ dapper universe multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ dapper universe multiverse
också...
beedj
Inlägg av beedj »
yepp. man tackar, funka fint med en update.
