name of display: :1.0
display: :1 screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (2.1 Mesa 7.0.1)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_imaging,
GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_point_sprite, GL_NV_texgen_reflection, GL_NV_texture_rectangle,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x2c 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2d 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2e 32 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 Ncon
0x2f 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
adde@adde-laptop:~$
