The program 'tilda' received an X Window System error.
Stirner
Inlägg av Stirner »
När jag försöker starta tilda är detta allt som händer..
xxx@xxx:~$ tilda - C
(tilda:5729): Gdk-CRITICAL **: gdk_window_set_geometry_hints: assertion `GDK_IS_WINDOW (window)' failed
This probably reflects a bug in the program.
The error was 'BadAccess (attempt to access private resource denied)'.
  (Details: serial 11 error_code 10 request_code 33 minor_code 0)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
http://stirner-eee.blogspot.com Stirner eee blog howto tips och trix för dig med eeePc http://stirner-eee.blogspot.com
Luxwarp
SV: The program 'tilda' received an X Window System error.
Inlägg av Luxwarp »
antar att detta är gammalt för dig nu när du äger loss på Yakuake:D
Återgå till "Terminalforum"
