Skärmupplösning 1680x1050 [LÖST]
lurson
Inlägg av lurson »
Hej
Efter att jag installerade de senaste ATI drivrutinerna med Envy så kan jag inte längre välja rätt skärmupplösning. Jag har lagt till "1680x1050" i xorg.conf men det har inte hjälpt. Är det någon som har något tips?
Min xorg.conf
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"CoreKeyboard"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"se"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
	Option		"CorePointer"
	Option		"Device"	"/dev/input/mice"
	Option		"Protocol"	"ImPS/2"
	Option		"ZAxisMapping"	"4 5"
	Option		"Emulate3Buttons"	"true"
EndSection
	Identifier	"Synaptics Touchpad"
	Driver		"synaptics"
	Option		"SendCoreEvents"	"true"
	Option		"Device"	"/dev/psaux"
	Option		"Protocol"	"auto-dev"
	Option		"HorizEdgeScroll"	"0"
EndSection
	Driver		"wacom"
	Identifier	"stylus"
	Option		"Device"	"/dev/input/wacom"
	Option		"Type"	"stylus"
	Option		"ForceDevice"	"ISDV4"# Tablet PC ONLY
EndSection
	Driver		"wacom"
	Identifier	"eraser"
	Option		"Type"	"eraser"
EndSection
	Driver		"wacom"
	Identifier	"cursor"
	Option		"Type"	"cursor"
EndSection
Section "Device"
	Identifier	"Generic Video Card"
	Driver		"fglrx"
	Busid		"PCI:1:0:0"
	Option		"VideoOverlay"	"on"
	Option		"OpenGLOverlay"	"off"
EndSection
Section "Monitor"
	Identifier	"Generic Monitor"
	Option		"DPMS"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"Generic Video Card"
	Monitor		"Generic Monitor"
	Defaultdepth	24
	SubSection "Display"
		Modes		"1680x1050"
	EndSubSection
EndSection
Section "ServerLayout"
	Identifier	"Default Layout"
  screen "Default Screen"
	Inputdevice	"Generic Keyboard"
	Inputdevice	"Configured Mouse"
	# Uncomment if you have a wacom tablet
	#	InputDevice     "stylus"	"SendCoreEvents"
	#	InputDevice     "cursor"	"SendCoreEvents"
	#	InputDevice     "eraser"	"SendCoreEvents"
	Inputdevice	"Synaptics Touchpad"
EndSection
Section "Extensions"
	Option		"Composite"	"Enable"
EndSection
HP Compaq nc8430: Ubuntu + ATI Radeon Mobility X1600
ZX Spectrum
SV: Skärmupplösning 1680x1050
Inlägg av ZX Spectrum »
Har haft samma bekymmer med min brors dator. Har en tanke om att det kan vara ati:s properitära drivrutin som ställer till det.
Vilken upplösning får du nu?
Mekaniserad Apelsin
Hedersmedlem
Posta filen /var/log/Xorg.0.log som ni kan öppna genom att köra gedit /var/log/Xorg.0.log i det fönster som kommer upp när man trycker alt-f2
lurson
Inlägg av lurson »
Jag kan endast köra 1280x1024 nu  :-[
Här kommer filen
Xorg.0.log
(296 KiB) Nerladdad 95 gånger
Mekaniserad Apelsin
Hedersmedlem
Den där loggen visar väl uppstart när den inte ens försöker sätta upplösningen till 1680x1050 ?
Prova att först köra system - administration - Skärmar och grafik och där ställa in allt så det stämmer så bra det går. Kan du då välja 1680x1050?
Om inte lägg till det valet i /etc/X11/xorg.conf genom att alla rader som startar med Modes lägga till före de andra alternativen 1680x1050.
ZX Spectrum
Vad jag kan se från Lursons xorg så finns den upplösningen där redan nu:
Section "Screen"
Defaultdepth 24
Modes "1680x1050"
EndSubSection
EndSection
Samma problem var det hos min bror. Körde en reconfigure av xorg och då hittades hans platta skärm automatiskt, dessutom med rätt skärmupplösning 1680x1050, men när vi startade om datorn så fick han bara 1024x768.
Verkar mer luta åt att det har något med ati-kortet att göra. Jag hjälpte honom innan dess att installera ati:s properitära drivrutin.
Mekaniserad Apelsin
Hedersmedlem
ZX Spectrum skrev: Vad jag kan se från Lursons xorg så finns den upplösningen där redan nu:
Jo, men jag undrade om han ändrat om den, för jag hittade inte när den försökte sätta skärmupplösningen till annat än 1280x1024. Därav den första frågan: "Den där loggen visar väl uppstart när den inte ens försöker sätta upplösningen till 1680x1050 ?"
Dvs, vad jag undrar är om han ändrat tillbaka sin xorg.conf till att inte ha"      Modes      '1680x1050'"
lurson
Inlägg av lurson »
Jag får inte ens möjligheten att välja 1680x1050 längre.
Men det verkar som att det är ati som har strulat. Läste något igår om en bug som gjorde att max upplösningen för 1680x1050 skärmar max kunde bli 1280x1024. Hoppas jag var trött och missuppfattade men just nu känns det som att man får installera en äldre drivrutin eller vänta tills nästa version.
Bowmore
Inlägg av Bowmore »
Ser ut som att du har en LG/Philips LP154WE2-TLA1 skärm. Kollade lite på nätet men fann inte mycket om den.
Det finns ett felmeddelande i loggen som jag inte kollat upp om det påverkar detta
(EE) fglrx(0): === [swlDalHelperAddCustomizeMode] === CWDDEDI_DisplayGetSetModeTimingOverride failed: 2
Jag saknar också info i loggen om din skärms synk- och refreshvärden. Antingen talar din skärm inte om det och då används default eller så bryr sig inte / loggar inte fglrx-drivaren detta.
Så frågan är då, var ger detta kommando
sudo xresprobe fglrx
TicToc
Inlägg av TicToc »
Du gör helt rätt, det är ATI som klantat till det.
https://a248.e.akamai.net/f/674/9206/0/ ... tml#183417
Connecting a display device that supports 1680x1050 to a system running Linux may
result in a maximum display resolution of 1280x1024 only being available
Jag har ett X1600 som funkar hur bra som helst, med allt. Jag kör version 8.37, förstår inte varför fler inte gör det. Använd Hanteraren för proprietära drivrutiner. Ta först bort den, starta om, lägg sedan till.
lurson
Inlägg av lurson »
Hallå!
Nu har tydligen det kommit en uppdatering av ati grafikdrivrutinerna där 1680x1050. Jag avinstallerade därför ati drivisarna med envy å sen installerade jag dem på nytt med hopp om att de var uppdaterade i envy.
Nu fungerar inte skrivborseffekter längre samt att jag kan fortfarande inte få min upplösning. Är det någon som har något tips? Så trött på att behöva installera om datorn varje gång man ska fixa med grafiken.
Hur ser man vad man har för drivrutiner?
TicToc
Inlägg av TicToc »
TicToc skrev: Jag har ett X1600 som funkar hur bra som helst, med allt. Jag kör version 8.37, förstår inte varför fler inte gör det. Använd Hanteraren för proprietära drivrutiner. Ta först bort den, starta om, lägg sedan till.
lurson
Inlägg av lurson »
Sugen på att testa men hur gör jag utan att sabba? Måste jag avinstallera nuvarande ati drivisar eller är det bara att köra enligt dina instruktioner? Måste jag ändra något i xorg.conf?
TicToc
Inlägg av TicToc »
Kanske att du har et avinstallationsskript i /usr/share/ati/ jag kommer inte ihåg var det brukar lägga sig.
Börja med att göra en kopia
sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf-bak
Sedan är det bara att köra Hanteraren...
Om den redan är ibockad urbockar du den. Låt den jobba lite, starta om datorn.
Bocka i rutan, starta om.
Beroende på resultat efter omstart kan behöva göra en sak till.
lurson
Inlägg av lurson »
hittar inget :)
Observera att jag är hyffsat färsking i Linux världen.
kanske det går att avinstallera med envy?
TicToc
Inlägg av TicToc »
Kör på med Hanteraren... så skall du se att det löser sig!  :D
lurson
Inlägg av lurson »
okej, så jag skiter i att avsintallera ati? Eller missförstår jag dig?  :)
revoltism
Inlägg av revoltism »
Grejen är att hitta rätt modeline, HorizSync och VertRefresh för skärmen.. jag har en LG Flatron L225WT och snodde Modeline från en L226WT.. klistrar in min xorg.conf
Section "Monitor"
Identifier  "L225W"
HorizSync    30.0 - 83.0
VertRefresh  56.0 - 75.0
ModeLine    "1680x1050" 119.0 1680 1728 1760 1840 1050 1053 1059 1080 +vsync
Option     "DPMS"
EndSection
Section "Screen"
Device    "Allmänt grafikkort"
Monitor    "L225W"
DefaultDepth    24
Depth    24
Modes    "1680x1050" "1280x1024" "1280x960" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
|- Grafikkort: ATI Radeon X1950 Pro - Moderkort: Asus P5W DH Deluxe - Skärm: LG L225W - Tangentbord: Logitech DiNovo Edge - Mus: Logithech MX Revolution -|
Bowmore
Inlägg av Bowmore »
Prova med sudo xresprobe vesa
Sen är det "bara" modeline kvar om inte skärmen vägrar svara ;)
revoltism
Finns ett program som heter xvidtune som man kan prova få fram modeline.. förstod mig inte på det dock..
