avahi deamon
katxor
avahi deamon
Inlägg av katxor »
vad gör denna? hur kan man ändra den?
det verkar vara den som stänger ner mitt nätverk varannan minut
Ubuntu 7.10
Xubuntu 7.10
maths57
SV: avahi deamon
Inlägg av maths57 »
I Synaptic står det här som information till paketet
Avahi mDNS/DNS-SD daemon
Avahi is a fully LGPL framework for Multicast DNS Service Discovery.
It allows programs to publish and discover services and hosts
running on a local network with no specific configuration.  For
example you can plug into a network and instantly find printers to
print to, files to look at and people to talk to.
This package contains the Avahi Daemon which represents your machine
on the network and allows other applications to publish and resolve
mDNS/DNS-SD records.
På hemsidan står det så här
Avahi is a system which facilitates service discovery on a local network. This means that you can plug your laptop or computer into a network and instantly be able to view other people who you can chat with, find printers to print to or find files being shared. This kind of technology is already found in Apple MacOS X (branded Rendezvous, Bonjour and sometimes Zeroconf) and is very convenient. Avahi is mainly based on Lennart Poettering's flexmdns mDNS implementation for Linux which has been discontinued in favour of Avahi.
Programmet har alltså med din DNS-server att göra. Konfigurationsfilerna hittar du i /etc/avahi. Ett verktyg du kan installera är avahi-utils, men jag vet inte hur man använder det. Jag kan själv ingenting om det här så det blir svårt att ge direkt hjälp. Men posta gärna  lite fler uppgifter så gräver vi vidare. :)
Hemsidan: http://avahi.org/. Där finns också en dokumentation, men den är väldigt teknisk.
Kolla också: http://linuxguru.se/node/81
