/etc/apt/sources.list?
Lulle
Inlägg av Lulle »
Tjenare kör ubuntu 7.10 och tänkte höra med er vad jag ska ta bort och lägga till i /etc/apt/sources.list för att få ubuntu att uppdateras bra över nätet?
Jag vill inte att dne ska fråga efter skivan osv. Den som jag har nu ser ut så här:
deb cdrom:[Ubuntu 7.10 _Gutsy Gibbon_ - Release i386 (20071016)]/ gutsy main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://se.archive.ubuntu.com/ubuntu/ gutsy main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://se.archive.ubuntu.com/ubuntu/ gutsy-updates main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://se.archive.ubuntu.com/ubuntu/ gutsy universe
deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy universe
deb http://se.archive.ubuntu.com/ubuntu/ gutsy-updates universe
deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://se.archive.ubuntu.com/ubuntu/ gutsy multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy multiverse
deb http://se.archive.ubuntu.com/ubuntu/ gutsy-updates multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://se.archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
# deb-src http://se.archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository. This software is not part of Ubuntu, but is
## offered by Canonical and the respective vendors as a service to Ubuntu
## users.
# deb http://archive.canonical.com/ubuntu gutsy partner
# deb-src http://archive.canonical.com/ubuntu gutsy partner
deb http://security.ubuntu.com/ubuntu gutsy-security main restricted
deb-src http://security.ubuntu.com/ubuntu gutsy-security main restricted
deb http://security.ubuntu.com/ubuntu gutsy-security universe
deb-src http://security.ubuntu.com/ubuntu gutsy-security universe
deb http://security.ubuntu.com/ubuntu gutsy-security multiverse
deb-src http://security.ubuntu.com/ubuntu gutsy-security multiverse
# deb http://download.tuxfamily.org/syzygy42 gutsy avant-window-navigator
# deb-src http://download.tuxfamily.org/syzygy42 gutsy avant-window-navigator
Ubuntu Scripts:
http://www.tinicorp.se/
mcNisse
SV: /etc/apt/sources.list?
Inlägg av mcNisse »
Sätt en brädgård, #, först på första raden.
jonasbjork
Inlägg av jonasbjork »
Lulle skrev: Tjenare kör ubuntu 7.10 och tänkte höra med er vad jag ska ta bort och lägga till i /etc/apt/sources.list för att få ubuntu att uppdateras bra över nätet?
## distribution.
## team.
## security team.
## repository.
## users.
Den första raden:
är den som anger att du vill använda CD/DVD-skivan, ändra till:
#deb cdrom:[Ubuntu 7.10 _Gutsy Gibbon_ - Release i386 (20071016)]/ gutsy main restricted
Det vill säga, lägg till ett # i början. Spara filen, se till att du är root när du ändrar i filen.
Sen kör du:
sudo apt-get update
För att apt skall ha koll på att du inte har skivan kvar.
Lulle
Inlägg av Lulle »
## distribution.
## team.
## security team.
## repository.
## users.
Den första raden:
Sen kör du:
sudo apt-get update
Efter jag körde apt-get update körde jag apt-get upgrade och fick följande fel medelande:
Efter uppackning kommer ytterligare 0B utrymme användas på disken.
Vill du fortsätta [J/n]? j
Ställer in jde (2.3.5.1-2) ...
Error in `/usr/share/doc-base/jde', line 1: the first line does not contain valid `Document' field
dpkg: fel vid hantering av jde (--configure):
underprocess post-installation script gav felkod 1
Ställer in sun-java6-doc (6-03-0ubuntu2) ...
This package is an installer package, it does not actually contain the
JDK documentation.  You will need to go download one of the
archives:
    jdk-6-doc.zip jdk-6-doc-ja.zip
(choose the non-update version if this is the first installation).
Please visit
    http://java.sun.com/javase/downloads/
now and download.  The file should be owned by root.root and be copied
to /tmp.
[Press RETURN to try again, 'no' + RETURN to abort] no
.... vad ska jag göra?
Ubuntu Scripts:
jonasbjork
Inte upgrade, update.
Lulle
Inlägg av Lulle »
jonasbjork skrev: Inte upgrade, update.
Vet, men kör man inte upgrade om man vill updatera sakerna?
Ubuntu Scripts:
jonasbjork
Ok, jag tolkade det som att du ville update :) Ditt fel löser du genom att läsa vad som står. Du skall till java.sun.com/j2se/download och ladda ner dokumentationen. Filen du laddar ner skall du spara i katalogen /tmp och sätta ägaren till root och gruppen till root. Sen skall du köra installationen (upgrade) igen. Sätter rättigheterna gör du med kommandot chown:
$ sudo chown root.root /tmp/nedladdaddokument.fil
Update är att uppdatera programvaror och delar i befintlig version.
Upgrade är att uppgradera från t ex Feisty Fawn till Gutsy Gibbon
Nästa upgrade blir till Hardy Heron, det ska väl gå att uppgrade till en betaversion innan april?
jonasbjork
Ulsak skrev: Update är att uppdatera programvaror och delar i befintlig version.
Rättelse update används för att ladda ner de senaste listorna över tillgängliga paket, upgrade används för att uppgradera befintliga paket i systemet. dist-upgrade används för att uppgradera hela disten till nästa version..
upgrade används oftast efter en update, då systemet får kännedom om nya paket genom update.
Lulle
Inlägg av Lulle »
efter jag har gjort det så får jag följande felmedelande:
robin@robin:~$ sudo apt-get upgrade
Läser paketlistor... Färdig
Bygger beroendeträd
0 uppgraderade, 0 nyinstallerade, 0 att ta bort och 0 ej uppgraderade.
1 ej helt installerade eller borttagna.
Behöver hämta 0B arkiv.
Fel uppstod vid hantering:
jde
E: Sub-process /usr/bin/dpkg returned an error code (1)
robin@robin:~$
Ubuntu Scripts:
Mekaniserad Apelsin
Hedersmedlem
jonasbjork skrev: Rättelse update används för att ladda ner de senaste listorna över tillgängliga paket, upgrade används för att uppgradera befintliga paket i systemet. dist-upgrade används för att uppgradera hela disten till nästa version..
Det där är oxå fel, dist-upgrade tar inte och uppgraderar hela disten till nästa version, den tar, förutom att göra en upgrade, och intelligent hanterar förändrade "dependencies", vilket iofs ändras ytterst sällan mellan olika versioner av ubuntu, men det händer. För att citera manualen för apt-get:
      upgrade
          upgrade is used to install the newest versions of all packages
          currently installed on the system from the sources enumerated in
          /etc/apt/sources.list. Packages currently installed with new
          versions available are retrieved and upgraded; under no
          circumstances are currently installed packages removed, or packages
          not already installed retrieved and installed. New versions of
          currently installed packages that cannot be upgraded without
          changing the install status of another package will be left at
          their current version. An update must be performed first so that
          apt-get knows that new versions of packages are available.
      dist-upgrade
          dist-upgrade in addition to performing the function of upgrade,
          also intelligently handles changing dependencies with new versions
          of packages; apt-get has a "smart" conflict resolution system, and
          it will attempt to upgrade the most important packages at the
          expense of less important ones if necessary. The
          /etc/apt/sources.list file contains a list of locations from which
          to retrieve desired package files. See also apt_preferences(5) for
          a mechanism for overriding the general settings for individual
          packages.
rent teoretiskt är det alltså ingen risk ännu att man installlerar ut för en alfaversion av Hardy om skulle "råka" skriva ( t ex genom att händerna slumpvis hamnar på tangent borde efter att man råkat klicka terminalen och att någon strax efteråt under pistolhot tvingar en att skriva lösenordet  :Psudo apt-get install dist-upgrade
jonasbjork
Ulsak skrev: rent teoretiskt är det alltså ingen risk ännu att man installlerar ut för en alfaversion av Hardy om skulle "råka" skriva ( t ex genom att händerna slumpvis hamnar på tangent borde efter att man råkat klicka terminalen och att någon strax efteråt under pistolhot tvingar en att skriva lösenordet  :Psudo apt-get install dist-upgrade
Om du ändrar dina apt-källor i /etc/apt/sources.list till hardy och skriver det är du uppgraderad.
ja, så är det naturligtvis.. :)
