Trådlöst till min Acer
Som nybörjare har jag klåpat ett tag med att komma åt mitt trådlösa nätverk (WPA) med min Acer Aspire. Kör Ubuntu Drapper. Får bara upp alternativet WEP då jag ska konfigurera uppkopplingen.
Tips?
Tips?
Vilket Acer? Modell?
För att börja med något så skriv lspci i terminalen och posta svaret det här.
Samt Acers modell.
Samt Acers modell.
Aspire 3100
lspci
0000:00:00.0 Host bridge: ATI Technologies Inc RS480 Host Bridge (rev 10)
0000:00:01.0 PCI bridge: ATI Technologies Inc: Unknown device 5a3f
0000:00:04.0 PCI bridge: ATI Technologies Inc: Unknown device 5a36
0000:00:05.0 PCI bridge: ATI Technologies Inc: Unknown device 5a37
0000:00:13.0 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller (rev 80)
0000:00:13.1 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller (rev 80)
0000:00:13.2 USB Controller: ATI Technologies Inc IXP SB400 USB2 Host Controller (rev 80)
0000:00:14.0 SMBus: ATI Technologies Inc IXP SB400 SMBus Controller (rev 83)
0000:00:14.1 IDE interface: ATI Technologies Inc Standard Dual Channel PCI IDE C ontroller ATI (rev 80)
0000:00:14.2 0403: ATI Technologies Inc: Unknown device 437b (rev 01)
0000:00:14.3 ISA bridge: ATI Technologies Inc IXP SB400 PCI-ISA Bridge (rev 80)
0000:00:14.4 PCI bridge: ATI Technologies Inc IXP SB400 PCI-PCI Bridge (rev 80)
0000:00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Hyp erTransport Technology Configuration
0000:00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Add ress Map
0000:00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRA M Controller
0000:00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Mis cellaneous Control
0000:01:05.0 VGA compatible controller: ATI Technologies Inc: Unknown device 597 5
0000:06:01.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C /8139C+ (rev 10)
0000:06:02.0 Ethernet controller: Atheros Communications, Inc.: Unknown device 0 01a (rev 01)
0000:06:04.0 CardBus bridge: ENE Technology Inc CB-712/4 Cardbus Controller (rev 10)
0000:06:04.1 FLASH memory: ENE Technology Inc ENE PCI Memory Stick Card Reader C ontroller (rev 01)
0000:06:04.2 0805: ENE Technology Inc ENE PCI Secure Digital Card Reader Control ler (rev 01)
0000:06:04.3 FLASH memory: ENE Technology Inc: Unknown device 0520 (rev 01)
0000:06:04.4 FLASH memory: ENE Technology Inc: Unknown device 0551 (rev 01)
lspci
Ingen som kör trådlöst?
[quote="lillkillen"]Aspire 3100
lspci
0000:06:02.0 Ethernet controller: Atheros Communications, Inc.: Unknown device 0 01a (rev 01)[/quote]
Trådbundna är Realtek och fungerar förmodligen alldeles utmärkt.
Atheros : Unknown device -är det lika med oinstallerade drivrutiner? Ja, jag tror det.
Du kanske får det i gång med denna guide:
http://madwifi.org/wiki/UserDocs/Distro/Debian/MadWifi
Om andra Acer laptop kan du läsa här:
https://wiki.ubuntu.com/HardwareSupport ... aptopsAcer
Dock inte 3100, gör ett tillägg där om du får igång din!
en citat "Suspend problem fixed with 2.6.17 kernel, but no wifi. Solution: Install madwifi from source and add "ath_pci" to /etc/modules." på modellen 3624
lspci
Hade samma problem fast på en bärbar Fujitsu-Siemens. Installerade en annan nätverkshanterare så var problemet löst.
I terminalen skriv: sudo apt-get install network-manager-gnome
Mer info i länken nedan om det inte fungerar.
http://www.ubuntuforums.org/showthread. ... ager+howto
Tack så mycket,
Kommer åt ett trådlöst först om ett par veckor igen och ska testa då.
Det vara bara att installera network manager. Problemet var WPA men om man vänsterklickar på nm och väljer "connect to other wireless network", skriver in namnet på WLAN så får man upp alla options man någonsin behöver.
Tack för hjälpen!
Tack för hjälpen!
SV: Trådlöst till min Acer
Hade problem med Acer Extensa 5220 och dess WLAN.
Läste många förslag och laddade ned massor av filer osv.
Inget hjälpte. Beslöt att installera Ubuntu pånytt och samtidigt använda en fungerande
internetanslutning med tråd. Det blev en installation med 145 uppgraderingsfiler och
även drivrutiner för Acer kunde installationen själv hitta.
WLAN fungerar nu utan att något annat än ominstallation har behövts.
Det blev något förenklat med den första internetfria installationen.
Ubuntu var uptodate helt utan uppgraderingar.
Inte ens aktiva försök att uppgradera hjälpte med den första
internetlösa installationen.
