problem efter senaste uppdateringen!
Machnine
Inlägg av Machnine »
Jag fick upp info om att det fanns nya uppdateringar till linux, körde in dom och efter det funkar det inte att spela vissa spel längre.. et av spelen som har slutat fungera idag som fungerade igår är Stepmania. http://www.stepmania.com
här kommer ett utdrag ur spelets logg fil:
00:00.008: StepMania 3.9
00:00.008: Log starting 2006-09-19 10:11:58
00:00.008:
00:00.009: Reading 'Data/Defaults.ini' failed: No such file or directory
00:00.009: Reading 'Data/StepMania.ini' failed: No such file or directory
00:00.009: Reading 'Data/Static.ini' failed: No such file or directory
00:00.481: Loading window: gtk
00:00.481: OS: Linux ver 020615
00:00.481: Crash backtrace component: x86 custom backtrace
00:00.481: Crash lookup component: dladdr
00:00.481: Crash demangle component: cxa_demangle
00:00.481: Runtime library: glibc 2.3.6
00:00.482: Threads library: NPTL 2.3.6
00:00.482: TLS is available
00:00.482: AnnouncerManager::AnnouncerManager()
00:00.482: Reading 'Data/GamePrefs.ini' failed: No such file or directory
00:00.482: Reading 'Data/Static.ini' failed: No such file or directory
00:00.483: ThemeManager::SwitchThemeAndLanguage: "default", ""
00:00.532: Initializing driver: ALSA
00:00.539: ALSA: Advanced Linux Sound Architecture Driver Version 1.0.10rc3 (Mon Nov 07 13:30:21 2005 UTC).
00:00.540: ALSA Driver: 0: VIA 8237 [V8237], device 0: VIA 8237 [VIA 8237], 4/4 subdevices avail
00:00.540: ALSA Driver: 0: VIA 8237 [V8237], device 1: VIA 8237 [VIA 8237], 1/1 subdevices avail
00:00.545: ALSA error: pcm_hw.c:1217 snd_pcm_hw_open: open /dev/snd/pcmC0D0p failed (Device or resource busy)
00:00.546: Could only create 4 buffers; need at least 8 (failed with dsnd_pcm_open(hw:0): Device or resource busy). Hardware ALSA driver can't be used.
00:00.546: Couldn't load driver ALSA: Not enough substreams for hardware mixing, using software mixing
00:00.546: Initializing driver: ALSA-sw
00:00.547: OS: Linux ver 020615
00:00.548: ALSA: Software mixing at 44100hz
00:00.549: Starting thread: Decode thread
00:00.549: Starting thread: RageSound_ALSA9_Software
00:00.549: Sound driver: ALSA-sw
00:00.550: Starting thread: MusicThread
00:00.558: Initializing lights driver: Null
00:00.569: Reading 'Cache/index.cache' failed: No such file or directory
00:00.569: Cache format is out of date. Deleting all cache files.
00:00.569: Reading 'Cache/banners.cache' failed: No such file or directory
00:00.573:
00:00.573: //////////////////////////////////////////////////////
00:00.573: Exception: The folder 'Songs/BustaMove' contains music files.
00:00.573:
00:00.573: This means that you have a music outside of a song folder.
00:00.573: All song folders must reside in a group folder. For example, 'Songs/DDR 4th Mix/B4U'.
00:00.573: See the StepMania readme for more info.
00:00.573:
00:00.576: Shutting down music start thread ...
00:00.576: underrun (512 frames)
00:00.576: underrun (520 frames)
00:00.576: underrun (464 frames)
00:00.576: underrun (400 frames)
00:00.576: underrun (336 frames)
00:00.576: underrun (272 frames)
00:00.576: underrun (208 frames)
00:00.576: underrun (152 frames)
00:00.576: underrun (88 frames)
00:00.576: underrun (24 frames)
00:00.577: Music start thread shut down.
00:00.607: Shutting down mixer thread ...
00:00.608: Mixer thread shut down.
00:00.608: Shutting down decode thread ...
00:00.623: Decode thread shut down.
00:00.623: Mixing 382.105263 ahead in 38 Mix() calls
00:00.624: Language: english
00:00.624: Theme: default
tyvärr har jag ingen logg sparad sen igår då spelet fungerade...
men någon som har en aning om vad det är som är felet?
Machnine
Fick igång det igen.. :D
var jag som hade tankat hem lite sånger och en av sångerna gjorde så att progget inte ville funka.. så , problemet löst :D
