Geforce 5200 funderingar!
Machnine
Inlägg av Machnine »
Tjenna gott folk, jag har funderat en hel del över mitt grafikkort..
Om det verkligen är 3daccelerator på när jag kör ubuntu.
Min xorg.conf ser ut på följande vis:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/X11/fonts/misc"
FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/X11/fonts/Type1"
FontPath "/usr/share/X11/fonts/100dpi"
FontPath "/usr/share/X11/fonts/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc104"
Option "XkbLayout" "se"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/wacom" # Change to
# /dev/input/event
# for USB
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
# /dev/input/event
# for USB
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
# /dev/input/event
# for USB
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]"
Driver "nvidia"
BusID "PCI:1:0:0"
VideoRam 128000
Option "TwinView" "true"
Option "TwinViewOrientation" "Clone"
Option "TVOutFormat" "SVIDEO"
Option "TVStandard" "PAL-G"
Option "SecondMonitorHorizSync" "30-50"
Option "SecondMonitorVertRefresh" "50"
Option "MetaModes" "1024x768,1024x768;800x600,800x600;640x480,640x480; 512x384,512x384"
EndSection
Section "Monitor"
Identifier "MCM 171E"
Option "DPMS"
HorizSync 30-72
VertRefresh 50-160
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV34 [GeForce FX 5200]"
Monitor "MCM 171E"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x960" "1024x768" "800x600"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
väldigt enkel tvout config också för detta kortet.. funkar dessutom väldigt bra med clone..
Men det jag funderade på var för mina skärmsläckare laggar, inte ens dom enklaste spel som t-ex stepmania flyter på fint..
Jag har testat att lägga till lite diverse koder i min xorg som t.ex renderaccel = true m.m men det pajjar min xorg fil helt tyvärr.Sen vill jag tillägga att jag kör på en celeron 2,66ghz 512mb ram och 128mb grafik..
samt att jag får upp nvidia loggan innan inloggningsskärmen.
Nåfon som vet varför skärmsläckare och spel m.m laggar? eller om ni har någon bra xorg config för just geforce fx5200..
mch MachNine
Okänd
Inlägg av Okänd »
Här hittar du en tråd där det diskuters om 5200, verkar som at några fick den att fungera med äldre drivrutiner. Vad bra, nu vet jag att hoppa över den nvidia-chipset. :|
http://ubuntuforums.org/showthread.php? ... force+5200
Machnine
tackar så mycket :)
ska ta och gå igenom denna guide sen för att se om jag får det att fungera!
__filip_
Inlägg av __filip_ »
Jag har ett geforce 5200 128mb och det rullar på fint =) Compiz är inga som helst problem. Fast för mig funkade compiz på 8mb grafik också :>
