This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by Eggdrop configure 1.6.18, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure
## Platform. ##
hostname = daniel
uname -m = i686
uname -r = 2.6.20-16-generic
uname -s = Linux
uname -v = #2 SMP Sun Sep 23 19:50:39 UTC 2007
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/games
## Core tests. ##
configure
result:
configure
result: This is Eggdrop's GNU configure script.
configure
result: It's going to run a bunch of tests to hopefully make your compile
configure
result: work without much twiddling.
configure
result:
configure
checking for gcc
configure
found /usr/bin/gcc
configure
result: gcc
configure
checking for C compiler version
configure
gcc --version </dev/null >&5
gcc (GCC) 4.1.2 (Ubuntu 4.1.2-0ubuntu4)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure
$? = 0
configure
gcc -v </dev/null >&5
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --program-suffix=-4.1 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-mpfr --enable-checking=release i486-linux-gnu
Thread model: posix
gcc version 4.1.2 (Ubuntu 4.1.2-0ubuntu4)
configure
$? = 0
configure
gcc -V </dev/null >&5
gcc: '-V' option must have argument
configure
$? = 1
configure
checking for C compiler default output file name
configure
gcc conftest.c >&5
/usr/bin/ld: crt1.o: No such file: No such file or directory
collect2: ld returned 1 exit status
configure
$? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "Eggdrop"
| #define PACKAGE_TARNAME "eggdrop"
| #define PACKAGE_VERSION "1.6.18"
| #define PACKAGE_STRING "Eggdrop 1.6.18"
| #define PACKAGE_BUGREPORT "
bugs@eggheads.org"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure
error: C compiler cannot create executables
See `config.log' for more details.
## Cache variables. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_prog_ac_ct_CC=gcc
## Output variables. ##
AWK=''
BASENAME=''
CC='gcc'
CFLAGS=''
CPP=''
CPPFLAGS=''
DEFAULT_MAKE=''
DEFS=''
DEST=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGGEXEC=''
EGGVERSION=''
EGREP=''
EXEEXT=''
HEAD_1=''
INSTALL_DATA=''
INSTALL_PROGRAM=''
INSTALL_SCRIPT=''
LDFLAGS=''
LIBOBJS=''
LIBS=''
LN_S=''
LTLIBOBJS=''
MODULE_XLIBS=''
MOD_CC=''
MOD_EXT=''
MOD_LD=''
MOD_STRIP=''
MOD_UPDIR=''
OBJEXT=''
PACKAGE_BUGREPORT='
bugs@eggheads.org'
PACKAGE_NAME='Eggdrop'
PACKAGE_STRING='Eggdrop 1.6.18'
PACKAGE_TARNAME='eggdrop'
PACKAGE_VERSION='1.6.18'
PATH_SEPARATOR=':'
RANLIB=''
SET_MAKE=''
SHELL='/bin/bash'
SHLIB_CC=''
SHLIB_LD=''
SHLIB_STRIP=''
STRIP=''
TCLINC=''
TCLINCFN=''
TCLLIB=''
TCLLIBFN=''
TCL_LIBS=''
TCL_REQS=''
UNAME=''
ac_ct_CC='gcc'
ac_ct_RANLIB=''
bindir='${exec_prefix}/bin'
build_alias=''
datadir='${prefix}/share'
egg_ac_parameters=''
exec_prefix='NONE'
host_alias=''
includedir='${prefix}/include'
infodir='${prefix}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
oldincludedir='/usr/include'
prefix='NONE'
program_transform_name='s,x,x,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
bugs@eggheads.org"
configure: exit 77
