avbruten installation
Har jag gjort bort mig helt nu?
Igår skulle jag uppgradera till GG, men installationen avbröts en stund efter att filerna var hämtade (min fru skulle byta användare) och nu går det inte att starta datorn.
Hur gör jag. finns det nån typ startdiskett eller något annat sätt att komma in på den och börja om?
SV: avbruten installation
Får du några felmeddelanden?
Da ar fragan vad som ar vasentligt eller ej. Jag borjade skriva av allt
Faile to start the X server (your graphical interface). It is likely that it is not set up correcctly. Would you like to view teh X server output to diagnose the problem?
Yes
.X window system Version 7.2.0
Release date: 22 Januari 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating system: Linux Ubuntu
Current Operating system: Linux tonny-desktop 2.6.20-16-generic #2 SMP
Sun sep 23 19:50:39 UTC 2007 i 686
Build date: 04 april 2007
Before reporting problem check http://wiki.x.org to make sure that you have the latest version
Module loaders present
Markers (--) probed, (**) from config file (==)default settings, (++) from command line, !! notice, II informational WW warning EE error NI not implemnted ?? unknown
== logfile: "/var/log/xorg.log", Time: tue oct 30 16:57>42 2007
== Using config file: "/etc/x11/xorg.conf"
-== Serverlayout "Default layout"
** screen " default screen" (0)
** monitor, allm'n sk'rm
**Device "NVIDIA Corporation NV6 [Vanta Vanta LT]
** input device "generic keybord"
** input device "configured Mouse"
** input device "stylus"
** input device "cursor"
** input device " eraser"
WW The directory "/usr/share/fonts/x11/cyrillic" does not exist
Entry dekleted from font path
** Fontpath st to: /usr/ share fonts/x11/misc
/usr/ share fonts/x11/100dpi/:unscaled
/usr/ share fonts/x11/75dpi/:unscaled
/usr/ share fonts/x11//Type1,
/usr/ share fonts/x11/100 dpi,
/usr/ share fonts/x11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dmsTrueType
etc etc etc
(II) Module ABI versions:
x.org Ansi C Emulation: 0.3
x.org Video driver: 1.1
x.org x1input driver" 0.7
x.org server extension" 0.3
en massa chip-info typ
PCI: 00:00:7: chip 1106,7269 card 1043,8129 rev 20 class 06,00,00
flera
Bus 0 non-prefectabel memoryrange
All system resource range
Load modules
Loading extansion
(II) resorce ranges after probing
NIVIDIA not using default mode
(II) Initializing built-in extension
(II) Initializing extension GLX
OK
The X server is now disabled. Restart GDH when it is configured correctly
OK
sa nu ar fragan hur jag configurerar Xservern corect_
behovs n[gon av all den infon jag hoppade over_
Yes
etc etc etc
flera
Load modules
Loading extansion
OK
OK
Logga in som vanligt (i det textbaserade läget) och skriv sedan: sudo dpkg-reconfigure xserver-xorg
Välja Vesa som drivrutiner för ditt grafikkort och följ resten av guidningen så ska det lösa sig med den biten.
jag kan inte skriva nagot
det verkar som om den inte svarar pa tangentbordet
men jag skriver pa det nu pa en desktopcd
det hander alltsa inget nar jag trycker esc, eller delete, f1 eller F8
sa hur skall jag komma till textbaserat lage?
Om du inte kommer dit automatiskt kan du pröva att trycka på CTRL + ALT + F1.
nu kom jag in och fick svaret
Paketet "xserver.xorg" 'r inte installerat och ingen information finns
För att installera det: sudo apt-get install xserver.xorg
Frågan är ju vad som det mer är fel på? Kanske både enklare och snabbare att lägga om allting?
Tack tack tack
sag nar jag skrev in mitt f;rra meddelande att jag skrev xserver.xorg, och gjorde nytt f;rs;k med xserver/xorg ist'llet och nu ar jag har.
Men vad ar mer fel
hur andrar jag tangentbordet som helt klart blivit fel, amerikanskt kanske_
har jag Feisty eller Gusty nu?
Men vad ar mer fel
Oj! Jag såg nu att jag skrev fel.
Det ska vara "-" inte ".".
Det rätta är alltså: sudo apt-get install xserver-xorg
You have 2 broken packages on your system!
Use the "Broken" filter to locate them.
jag hittar inte l'ngre mina filer i "PLACES"
men finner dem om jag oppnar via program
skall jag g;ra en ny uppgradering?
Du sitter med Live-CD'n nu va? Då är det Livesessionens mappar man ser där.
Har du något du vill ha kvar? Isf får du rädda det innan.
Det skulle kanske vara säkrast med en ominstallation antar jag.
Nej jag sitter inte längre med livecd:n
Ditt kommando funkade utmärkt när jag upptäckte att jag skrivit . ist f -
tangentbordet var också lätt att fixa
nu säger systemet att jag har två trasiga paket.
Jag kommer inte åt mina mappar via "Places/Hemmapp" Men jag kan öppna dem i respektive program i openoffice-filmuppspelare etc.
Frågan är om jag kan bränna dem som säkerhet, beror på hur brännaren hittar.
skall försöka.
Sen undrar jag om jag går in på sidan http://www.ubuntu-se.org/drupal/node/369 och uppgraderar till Gusty där, vad händer då?
skall försöka.
Vad är det för paket? Du kan öppna Synaptic och sedan menyn Edit finns något som heter "Fix broken packages". Det borde lösa det.
Vad för du för meddelande när du försöker öppna din hemmapp?
Om du inte har 7.10 så kan du uppgradera via uppdateringshanteraren.
nyttproblemttproblemMellanslagstangenenOchandraTeckentangenterSläckerNerFirefoxPaketnLagasdeGustyGibbonUppgraderad
HurÄndraAttInteMellanslagKopplarNer
äntligen verkar allt funka
lite tålamod och pillande här och där hjälper.
Sen vet jag inte precis vad jag gjort, men tackar för den hjälp jag fått på vägen
Kul att det löste sig.
Det är väl inget annat som krånglar nu?
Jo det är det säkert
, men inget nytt som jag ännu upptäckt.
Bör jag avinstallera automatix?, hör mycket ont om det och installerade det förut enligt Bossiemans blogg. Jag har vissa Javaproblem sen förut. Kan det ha ett samband?
Om Automatix har gjort nått dumt är skadan redan skedd. Men jag tycker du ska avinstallera det och hoppas på programmet aldrig gjorde något dumt.
Vad är det för javaproblem du har?
