max@max:~$ cd /home/max/Desktop/gDesklets-0.36beta
max@max:~/Desktop/gDesklets-0.36beta$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
http://www.speedyshare.com/163998274.html
Tack på förhand.
