# xorg.conf (xorg X Window System server configuration file)
# This file was generated by failsafeDexconf, using
# values from the debconf database and some overrides to use vesa mode.
# You should use dexconf or another such tool for creating a "real" xorg.conf
# For example:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "Module"
Load "glx"
Load "GLcore"
Load "v4l"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Section "Device"
Identifier "Failsafe Device"
Boardname "vesa"
Busid "PCI:1:0:1"
Driver "fglrx"
Screen 0
EndSection
Section "Monitor"
Identifier "Failsafe Monitor"
Vendorname "Plug 'n' Play"
Modelname "Plug 'n' Play"
modeline "800x600@56" 36.0 800 824 896 1024 600 601 603 625 +hsync +vsync
modeline "800x600@72" 50.0 800 856 976 1040 600 637 643 666 +hsync +vsync
modeline "800x600@75" 49.5 800 816 896 1056 600 601 604 625 +hsync +vsync
modeline "800x600@60" 40.0 800 840 968 1056 600 601 605 628 +hsync +vsync
modeline "1152x768@54" 64.995 1152 1178 1314 1472 768 771 777 806 +hsync +vsync
modeline "1280x854" 80.0 1280 1309 1460 1636 854 857 864 896 +hsync +vsync
modeline "1280x768@60" 80.14 1280 1344 1480 1680 768 769 772 795 -hsync +vsync
modeline "1280x720@60" 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync
modeline "1280x800@75" 107.21 1280 1360 1496 1712 800 801 804 835 -hsync +vsync
modeline "1280x768@75" 102.98 1280 1360 1496 1712 768 769 772 802 -hsync +vsync
modeline "1280x800@60" 83.46 1280 1344 1480 1680 800 801 804 828 -hsync +vsync
modeline "1440x900@75" 136.49 1440 1536 1688 1936 900 901 904 940 -hsync +vsync
modeline "1440x900@60" 106.47 1440 1520 1672 1904 900 901 904 932 -hsync +vsync
modeline "1600x1024@60" 136.36 1600 1704 1872 2144 1024 1025 1028 1060 -hsync +vsync
modeline "1680x1050@60" 147.14 1680 1784 1968 2256 1050 1051 1054 1087 -hsync +vsync
modeline "1680x1050@75" 188.07 1680 1800 1984 2288 1050 1051 1054 1096 -hsync +vsync
modeline "1920x1200@60" 193.16 1920 2048 2256 2592 1200 1201 1204 1242 -hsync +vsync
Gamma 1.0
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Failsafe Device"
Monitor "Failsafe Monitor"
Defaultdepth 24
SubSection "Display"
Depth 24
Virtual 1920 1200
Modes "1600x1024@60" "1680x1050@60" "1440x900@60" "1680x1050@75" "1440x900@75" "1920x1200@60" "1280x800@60" "1280x768@75" "1280x800@75" "1280x720@60" "1280x768@60" "1280x854" "1152x768@54" "800x600@60" "800x600@75" "800x600@72" "800x600@56"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen 0 "Default Screen" 0 0
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
EndSection
Section "device" #
Identifier "device1"
Boardname "ATI Radeon (fglrx)"
Busid "PCI:1:0:0"
Driver "ati"
Screen 0
Vendorname "ATI"
Option "MergedFB" "off"
EndSection
Section "screen" #
Identifier "screen1"
Device "device1"
Defaultdepth 24
Monitor "monitor1"
EndSection
Section "monitor" #
Identifier "monitor1"
Gamma 1.0
EndSection
Section "ServerFlags"
EndSection
Section "Extensions"
Option "Composite" "0"
EndSection
edit: värt att notera kanske är att: jag har kört "Installera ATI (fglrx) drivrutinen i Gutsy" om då den tidigare fanns när det funkade.vid start får jag felmeddelandet "ubuntu is running in low praphics mode, graphic card and screen not detected bla bla bla". har kört xserver-xgl också om det kanske påverkat...
edit2: kanske kan va bra att veta att i "proprietära drivisar" finns ati drivis aktiverad MEN "används ej" vilket den var förrut.hur får jag den att bli aktiverad?har dual boot och på XP funkar graffekort och skärm lika bra som förrut.
edit3: har testat flera gånger nu med får hela tiden att "proprietära drivisar" till graffekortet "ej används" fast ja försökr återaktivera. ngt måste ligga och trycka där som ska bort. även innan man kmr in i ubuntu så se man svart skärm emd vit txt...bla "kinit: no resume image" bla bla "normal boot" nånting.felen kanske beror av varandra?
edit4: kanske kan köra sudo dpkg-reconfigure xserver-xorg ?? för att få xorg att va som den va innan kollapsen.så kanske det funkar?
Boardname "vesa" # verkar skumt också...har för mig att det itne va så förrut men kan ha fel.
