Radeon x1950: Allt fungerar, förutom direct rendering: No
blajban
Inlägg av blajban »
Jag har suttit sjukt många timmar, googlat, kollat på forum, fixat och trixat. Men jag har ingen aning om hur jag får direct rendering: No att bli YES.
Alla skrivbordseffekter fungerar, men spel fungerar definitivt inte. Som jag har förstått det så har jag inte fungerande "3d" nu.
Tack på förhand!
fglrxinfo:
display: :0.0  screen: 0
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: Radeon X1950 Series
OpenGL version string: 2.0.6747 (8.40.4)
glxinfo:
name of display: :1.0
Xlib:  extension "XFree86-DRI" missing on display ":1.0".
display: :1  screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
    GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
    GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
    GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
    GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
    GLX_ARB_multisample
OpenGL version string: 1.2 (2.0.6747 (8.40.4))
OpenGL extensions:
    GL_ARB_multitexture, GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_dot3, GL_ARB_transpose_matrix, GL_EXT_abgr,
    GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x2c 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 None
0x2e 32 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 Ncon
0x2f 32 tc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 Ncon
zenbios
SV: Radeon x1950: Allt fungerar, förutom direct rendering: No
Inlägg av zenbios »
Nu är inte riktigt grafik min grej.
men har du både fglrx o xgl så får du inte Yes där.
har ja fel, får gärna nån rätta mig.
men läste det på ett annat forum.
har du båda eller?
blajban
Inlägg av blajban »
hm, jag antar det. Var tvungen att installera xgl (har jag för mig) för att få igång compiz fusion.
Det enda jag vill är att det ska stå yes så att man kan köra typ wow eller motsvarande :)
Jag är som sagt inte riktigt haj på detta, så tveka inte att fråga efter ytterligare information
Kattskrället
AVREGISTRERAD
Inlägg av Kattskrället »
Det står no vid direct rendering om du kör xgl.
Jag förmodar att du måste stänga av skrivbordseffekterna för att det ska stå yes och spel ska fungera.....men jag vet inte då jag inte spelar i ubuntun.
blajban
Inlägg av blajban »
Hur stänger jag av det då? :)
Och kan man stänga av och sätta på det på ett smidigt sätt?
Barre
Inlägg av Barre »
jag var tvungen att starta mitt spel (etqw demo) med DISPLAY=:0 när jag körde fglrx + Xgl.
alltså
från terminalen starta spelet med DISPLAY=:0 före programet, exempel
DISPLAY=:0 /usr/local/games/etqw.demo/etqw
byt ut /usr/local/games/etqw.demo/etqw till sökvägen för wow...
vem vet, det kanske fungerar
twitter @ BarreGargamel
blogg @ Gargamel.NU
