Såhär står det:
MPlayer interrupted by signal 13 in module: uninit_stream
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
Jag har försökt hitta den där htmlfilen men lyckas inte.
mplayer kraschar
mplayer kraschar
Really, I'm not out to destroy Microsoft. That will just be a completely
unintentional side effect. --- Linus Torvalds
SV: mplayer kraschar
/* Det finns inga Minor för Svärdet *\
