Jag kör gnome, och inte kde, men det har fungerat perfekt innan! Jag saknar mitt amarok, så jag ber om snabb hjälp!!
X Error: BadDevice, invalid or uninitialized input device 169
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Failed to open device
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Amarok: [Loader] Starting amarokapp..
Amarok: [Loader] Don't run gdb, valgrind, etc. against this binary! Use amarokapp.
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
kbuildsycoca running...
kdecore (KAction): WARNING: KAction::insertKAccel( kaccel = 0x8099210 ): KAccel object already contains an action name "play_pause"
QLayout "unnamed" added to QVBox "unnamed", which already has a layout
QLayout: Adding KToolBar/mainToolBar (child of QVBox/unnamed) to layout for PlaylistWindow/PlaylistWindow
QObject::connect: Incompatible sender/receiver arguments
StarManager::ratingsColorsChanged() --> ContextBrowser::ratingOrScoreOrLabelsChanged(const QString&)
lukas@LinneaUbuntu:~$ X Error: BadWindow (invalid Window parameter) 3
Major opcode: 7
Minor opcode: 0
Resource id: 0x2ea
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
Major opcode: 147
Minor opcode: 3
Resource id: 0x0
kded: ERROR: : couldn't create slave : Kan inte prata med Klauncher
MediaManager::slotMediumRemoved: sdf1
MediaManager::slotMediumRemoved: sde1
MediaManager::slotMediumRemoved: sdd1
MediaManager::slotMediumRemoved: sdc1
MediaManager::slotMediumRemoved: sdb1
MediaManager::slotMediumRemoved: sda1
MediaManager::slotMediumRemoved: hdc1
MediaManager::slotMediumRemoved: hdb1
MediaManager::slotMediumRemoved: hda6
MediaManager::slotMediumRemoved: hda4
MediaManager::slotMediumRemoved: hda3
MediaManager::slotMediumRemoved: hda2
MediaManager::slotMediumRemoved: nfs
ICE default IO error handler doing an exit(), pid = 13615, errno = 0
