World of warcraft + ubuntu 7.04 = torkad sirap
För spelentusiaster !
mrhex
Inlägg av mrhex »
Jag har följt diverse guider på nätet, bland annat, http://www.wowwiki.com/Linux/Wine och http://www.pronetit.com/2007/04/20/howt ... esty-fawn/ och https://help.ubuntu.com/community/WorldofWarcraft.
Dessa guider har hjälp mig så långt att jag får wow att launcha, MEN redan vid loginskärmen har jag 0.00001 fps, det tar mig 1 minut att lyckas fylla i login/pass.
lite info:
mrhex@Hajpojken:~$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
    GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
    GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
    GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
    GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI R300 20060815 AGP 8x x86/MMX+/3DNow!+/SSE TCL
OpenGL version string: 1.3 Mesa 6.5.2
OpenGL extensions:
    GL_ARB_fragment_program, GL_ARB_imaging, GL_ARB_multisample,
    GL_ARB_multitexture, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_cube_map,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_MESAX_texture_float, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_window_pos,
    GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
    GL_EXT_compiled_vertex_array, GL_EXT_convolution, GL_EXT_copy_texture,
    GL_EXT_draw_range_elements, GL_EXT_gpu_program_parameters,
    GL_EXT_histogram, GL_EXT_packed_pixels, GL_EXT_polygon_offset,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_subtexture,
    GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
    GL_APPLE_packed_pixels, GL_ATI_blend_equation_separate,
    GL_ATI_texture_env_combine3, GL_ATI_texture_mirror_once,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
    GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
    GL_NV_texture_rectangle, GL_NV_texgen_reflection, GL_NV_vertex_program,
    GL_OES_read_format, GL_SGI_color_matrix, GL_SGI_color_table,
    GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
    GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x24 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x25 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x26 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0x27 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x2a 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0x2b 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x2c 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x2d 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x2e 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0x2f 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x30 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x31 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 Slow
0x32 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 Slow
0x4b 32 tc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 Ncon
liter snippets ur min xorg.conf, notera att jag använder radeon, jag verkar måsta göra det av någon anledning. ändrar jag till "fglrx" så kan inte X starta.
Section "Device"
        Identifier      "ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]"
        Driver          "radeon"
        Busid           "PCI:3:0:0"
        Option       "Capabilities" "0x00000800"
        Option       "UseFastTLS" "off"
        Option       "KernelModuleParm" "locked-userpages=0"
        Option "XAANoOffscreenPixmaps"
        Option "AGPMode" "8"
        Option "AGPFastWrite" "true"
        Option "DisableGLXRootClipping" "true"
        Option "AddARGBGLXVisuals" "true"
        Option "AllowGLXWithComposite" "true"
        Option "EnablePageFlip" "true"
EndSection
Vad göra ?
Galgalid
SV: World of warcraft + ubuntu 7.04 = torkad sirap
Inlägg av Galgalid »
Du måste ha fglrx installerar för att kunna spela WoW
http://ubuntu-se.org/smf/index.php/topic,13348.0.html
kolla vidare där när du får fglrx att fungera.
Återgå till "Spel"
