Jag har problem med cdbrännaren. Jag har tidigare testat gnomebaker och exakt samma problem uppstod (en annan ubuntu-installation på samma dator så fungerade brännaren out of the box. Är osäker på om det var feisty eller den innan) och nu försöker jag bränna i terminalen.
När jag kör
tt@laptop:~$ sudo cdrecord dev=1,0,0 speed=4 -v /media/sda3/fil.iso
får jag meddelandet:
wodim: No write mode specified.
wodim: Asuming -tao mode.
wodim: Future versions of wodim may have different drive dependent defaults.
TOC Type: 1 = CD-ROM
scsidev: '1,0,0'
scsibus: 1 target: 0 lun: 0
Linux sg driver version: 3.5.34
Wodim version: 1.1.2
SCSI buffer size: 64512
atapi: 1
Device type : Removable CD-ROM
Version : 5
Response Format: 2
Capabilities :
Vendor_info : 'HL-DT-ST'
Identification : 'DVDRAM GSA-T10N '
Revision : 'PC05'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x0009 (CD-R)
Profile: 0x0012 (DVD-RAM)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0015 (DVD-R/DL sequential recording)
Profile: 0x0016 (DVD-R/DL layer jump recording)
Profile: 0x0014 (DVD-RW sequential recording)
Profile: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x001A (DVD+RW)
Profile: 0x001B (DVD+R)
Profile: 0x002B (DVD+R/DL)
Profile: 0x0010 (DVD-ROM)
Profile: 0x0009 (CD-R) (current)
Profile: 0x000A (CD-RW)
Profile: 0x0008 (CD-ROM)
Profile: 0x0002 (Removable disk)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Drive buf size : 1053696 = 1029 KB
Track 01: data 541 MB
Total size: 621 MB (61:35.36) = 277152 sectors
Lout start: 622 MB (61:37/27) = 277152 sectors
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 4
Is not unrestricted
Is not erasable
Disk sub type: Medium Type A, low Beta category (A-) (2)
ATIP start of lead in: -12508 (97:15/17)
ATIP start of lead out: 359845 (79:59/70)
Disk type: Short strategy type (Phthalocyanine or similar)
Manuf. index: 22
Manufacturer: Ritek Co.
Blocks total: 359845 Blocks current: 359845 Blocks remaining: 82693
Speed set to 1764 KB/s
Starting to write CD/DVD at speed 10.0 in real TAO mode for single session.
Last chance to quit, starting real write 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Performing OPC...
Starting new track at sector: 0
Track 01: 0 of 541 MB written.Errno: 5 (Input/output error), write_g1 scsi sendcmd: no error
CDB: 2A 00 00 00 00 9B 00 00 1F 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 10 2A 30 02 80 21 02 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x21 Qual 0x02 (invalid address for write) Fru 0x0
Sense flags: Blk 0 (not valid)
resid: 63488
cmd finished after 0.002s timeout 40s
write track data: error after 317440 bytes
wodim: The current problem looks like a buffer underrun.
wodim: It looks like 'driveropts=burnfree' does not work for this drive.
wodim: Please report.
wodim: Make sure that you are root, enable DMA and check your HW/OS set up.
Writing time: 17.635s
Average write speed 210.2x.
Fixating...
Fixating time: 28.360s
Har ni någon aning om vad jag ska göra? Hur kontrollerar jag om DMA är aktiverat? Hur tar man reda på vad cd-romen har för namn (i.e. sdx)? Jag har försökt lite med hdparm men det går inte framåt.
Problem med cd/dvdbrännaren
SV: Problem med cd/dvdbrännaren
RW verkar inte fungera i Ubuntu. I K3b programmet finns kommandot Format DVD-RW.
Det bränns spår i skivan. Har man tur kan den sedan monteras och allt verkar fungera.
CD-RW formatering verkar inte finnas i Ubuntu. Har lyckats få en fungerande DVD, men den har formaterats
med Windows Vista. Lägger till fotografier vartefter kameran töms.
Däremot går det att bränna på CD-RW, tömma och bränna pånytt. Har prövat ett otal program
i Ubuntu, men ingenting får CD-RW att fungera som en hårddisk. Borde meddela programmerare.
