försöker att installera gimp 2.4. men det krånglar en hel del.
har installerat gtk V 2.10.14 just nu men när jag ska confugera gimp så får jag upp detta meddelandet.
*** 'pkg-config --modversion gtk+-2.0' returned 2.10.14, but GTK+ (2.10.11)
*** was found! If pkg-config was correct, then it is best
*** to remove the old version of GTK+. You may also be able to fix the error
*** by modifying your LD_LIBRARY_PATH enviroment variable, or by editing
*** /etc/ld.so.conf. Make sure you have run ldconfig if that is
*** required on your system.
*** If pkg-config was wrong, set the environment variable PKG_CONFIG_PATH
*** to point to the correct configuration files
no
configure: error: Test for GTK+ failed. See the file 'INSTALL' for help.
är det någon om har någon tiori hur man ska lösa detta problem?
gimp 2.4
- Utgåva: 10.04 Lucid LTS
