Linux Mint
nicefinger
Linux Mint
Inlägg av nicefinger »
Körde Linux mint XFCE från live-cd igår.
Jäkligt snyggt utseende. Och allt funkade med en gång utan krångel  ... kuben, dallerfönster etc ...
TForsman
OS: Foresight
SV: Linux Mint
Inlägg av TForsman »
Mint är riktigt snyggt och "lätt"
Linux Mint is based on and compatible with Ubuntu and shares the same repositories.
Most differences are on the desktop. Linux Mint comes with home made applications which are designed to enhance the user experience. For instance, mintDesktop allows greater Gnome configuration and automatic browsing of Windows workgroups and network neighbourhoods. MintWifi makes it easier to configure wireless cards without an internet connection. MintDisk mounts NTFS partitions in read/write mode. MintMenu and mintConfig provide new ways to use the Gnome desktop, etc.
A few changes in the system make Linux Mint a bit faster than Ubuntu. For instance, ipv6 support is disabled in Linux Mint.
Multimedia codecs are installed by default in Linux Mint.
The default set of applications is different in the two distributions and some software is more up to date in Linux Mint (namely Amarok, KDE, Koffice, OpenOffice). Also, because Linux Mint tends to release more frequently than Ubuntu its installed packages are more up to date.
On the other hand Ubuntu is better tested and considered more stable. It supports more languages from the liveCD and comes with better localization than Linux Mint. Also, Ubuntu supports PPC and x64 architectures while Linux Mint only supports x86. Finally Ubuntu provides server installations and an alternative text-based install which are not available from Linux Mint.
nicefinger
SV: Linux Mint
Det stämmer, jag kunde inte få svenska bokstäver.
... and some software is more up to date in Linux Mint ..
Det stämmer ett tag, men snart kommer Gutsy. Då ligger Ububtu före igen.
Pinky
OS: Fedora
SV: Linux Mint
Inlägg av Pinky »
jag testade standardversionen av mint. Direkt vid uppstart så skilde det sig inte mkt från ubuntu, förutom ett snyggare tema (som man nog lätt kan klämma in i ubuntu också). Sen hade de lagt till hem-mappen och "datorn" på skrivbordet, samt ordnat till menyerna så att det liknade windoze mer.
Med tanke på å-ä-ö-problemen så väntar jag nog på gutsy :) är ju inte långt kvar nu!
Dick Lundberg
SV: Linux Mint
Inlägg av Dick Lundberg »
Skrämmer igång den här gamla tråden igen... Har länge varit sugen på att testa Linux Mint och fick igår tummen ur *. (Köpte nyligen en begagnad laptop med Ful-OS på och orkade först inte byta men det blev jobbigt att bli handikappad och inte kunna göra sånt man är van vid.) Det visade sig att version 4.0 bara var några dagar gammal (om jag läste rätt) och det gör ju det hela lite skojigare. Mina intryck hittills är mestadels positiva. Mitt system är näst intill uråldrigt idag: Pentium III på 1113 MHz, 512 meg RAM, Nvidia grafikkort med 32 meg minne. Trots det flyter allt fint. Inte minsta antydan till segt vid normalanvändning. Grafikkortet installerades med ett klick i en bockruta (samma som i Ubuntu), mitt trådlösa nätverkskort (Belkin FD57011) likaså. Tror att drivrutinerna körs genom ndiswrapper men det är i så fall ingenting jag behövt bekymra mig om.
Skrivbordet är klart snyggare än Ubuntus skrivbord och jag gillar startmenyn där alla flikar öppnas i en enda... svårt att förklara för den som inte sett det. Kontrollpanelen är suverän med fler verktyg än Ubuntu och med bra struktur.
På minussidan är en av de saker som är Linux Mints kännetecken: Multimedia "out of the box". Nja. Mplayer är visserligen installerat med w32codecs och allt men det fungerar ju inte! Går jag in på svt.se kommer mplayerfönstret fram och ser ut att ladda men ingenting visas. Nånsin. Tv4.se likadant. Precis som i min ubuntudator måste jag alltså avinstallera Mplayers firefox-plugin (som jag förresten aldrig fått att fungera till någonting), lägga in Real Player och då fungerar det på svt.se. Tv4.se får jag förstås inte att fungera, men det är ju ganska känt att det är problem med deras hemsida och Linux överlag.
Well, det var en liten rapport. Nu har jag snart installerat Wow klart... Blir spännande att se hur det går. Peace & Pussar!
to wonder
SV: Linux Mint
Inlägg av to wonder »
Skriver just nu fran en Live-cd Linux mint Daryna....[engelskt t-bord  :P...
Undrar om en sak nar jag bootar upp med mint live-cd skivan, innan skrivbordet ska visas
blir allt svart , men syns sen nar man ror vid datormusen. Som en skarmslackare  fast de ar
uppstart pa ca: 2 min.....screensaver is 10 min originalinstallningen...hmm!
ursakta engelska t-bordet  ::)...
Dick Lundberg
SV: Linux Mint
to wonder skrev: Skriver just nu fran en Live-cd Linux mint Daryna....[engelskt t-bord  :P...
Beats me... Känner inte igen det.
to wonder
SV: Linux Mint
vadå !  de som sas endast
Dick Lundberg
SV: Linux Mint
Well well well. Börjar komma tillrätta med min laptop med Linux Mint. World of Warcraft tuffar på finfint efter lite handpåläggning och fifflande med inställningar i spelet och jag kan alltså se film på svt.se men ännu inte tv4.se. Smällar man får ta. Youtube fungerade från start eftersom Flash installerades med operativsystemet. Bra grej! För att bli av med felmeddelande om cpufreq, nåt om att frekvensen inte kunde ändras fick jag ge mig in i en textfil och lägga in lite text jag hittade i ett forum.
Nu har jag en sak kvar: Muspekaren hänger sig med jämna mellanrum, inte ens en sekund men länge nog för att det ska vara irriterande. Jag har också märkt att ljudet stannar upp ibland och spelar ett litet stycke på repeat innan det fortsätter. Det här händer i allprogram för ljud och video utom Totem av någon anledning. Jag misstänker att den stannande muspekaren och hackande ljudet kan ha med varandra att göra... Någon som har tips?
Turbo
Utgåva: 10.04 Lucid LTS
SV: Linux Mint
Inlägg av Turbo »
Kör Mint Gnome i Virtualbox. Det funkar men går lite sakta. Ska testaMiint XFCE istället.
Fråga? Funkar Ubuntus deb-paket i Miint?    :)
Dick Lundberg
SV: Linux Mint
turbo skrev: Kör Mint Gnome i Virtualbox. Det funkar men går lite sakta. Ska testaMiint XFCE istället.
Jajjebulle! Mint 4.0 är inget annat än Gutsy Gibbons med lite pynt... Den stora anledningen till att jag valde Mint var just att disten bygger på Ubuntu men ändå är annorlunda på många sätt. Jag ville ha nåt nytt samtidigt som jag ville känna mig hemma.
Turbo
SV: Linux Mint
Inlägg av Turbo »
OK.  Nu skriver jag från Mint XFCE. (virtual).  Den är lite snabbare och ganska snygg. Lite annorlunda huvudmeny.  Tror att jag ska lägga den på en egen partition. Verkar stabil.  :D
Dick Lundberg
SV: Linux Mint
Jaförtusan! Jag gillar Mint! De nya konfigureringsverktyg som följer med är riktigt trevliga och skrivbordet är som sagt stilrent och snyggt. På "riktiga" datorn (den stationära) fortsätter jag med Ubuntu Studio men på laptopen får det bli Mint ett tag framöver.
Turbo
SV: Linux Mint
Inlägg av Turbo »
Jag blir så besviken. Försökte köra live från CD.  Samma problem som med Ubuntu 7.10.  Kommer till inloggen och sedan bara dör skärmen.  Någon ting med X måste det vara. Jag har alltså Nvidia Gerfoce FX 5200.    Måste jag köpa ett annat grafikkort eller vad beror det på?  ???
Jag får alltså ingen konsoll innan inlogg där jag kan köra toksnurran.
Genom Virtualbox på samma dator funkar den hur bra som helst.
På min gamla risiga dator startar den upp hur lätt som helst.      :)
Dick Lundberg
SV: Linux Mint
Det går inte att köra live-CD:n i läget för felsäker grafik eller vad det nu heter..? Med största sannolikhet är det grafikkortet och det här är lite av Linux akilleshäl - har man ovanlig eller lite för ny hårdvara kan man få problem som är ett elände att lösa. Nvidia-kortet är naturligtvis ingen konst att få igång när man väl installerat operativsystemet men man måste ju naturligtvis komma så långt att man överhuvudtaget KAN installera. Med Ubuntu Gutsy kan man ju gå förbi sådana där problem genom en "alternate" skiva utan grafisk installation men hur det förhåller sig med Mint vet jag inte.
Att det fungerar i Virtualbox är inte konstigare än att det är värdsystemets drivrutiner som låtsas vara ett standardgrafikkort för den virtuella datorn. Så funkar det i Vmware ialla fall...
Dick Lundberg
SV: Linux Mint
Dick Lundberg skrev: Nu har jag en sak kvar: Muspekaren hänger sig med jämna mellanrum, inte ens en sekund men länge nog för att det ska vara irriterande. Jag har också märkt att ljudet stannar upp ibland och spelar ett litet stycke på repeat innan det fortsätter. Det här händer i allprogram för ljud och video utom Totem av någon anledning. Jag misstänker att den stannande muspekaren och hackande ljudet kan ha med varandra att göra... Någon som har tips?
Tydligen hade detta med min Dell c810 och Speedstep att göra. Ännu en textfil att redigera men sedan har det fungerat.
Turbo
SV: Linux Mint
Inlägg av Turbo »
Dick Lundberg skrev: Det går inte att köra live-CD:n i läget för felsäker grafik eller vad det nu heter..?
Nej jag försökte det också. Jag hade väldigt gärna viljat ha Mint4 för den är läcker.
Kunde i.o.f.s. ladda hem en äldre Mint 3.1 och försöka med den och sedan om det går att uppgradera?  Nåja, jag får väl köra virtuellt så länge.  :-[
Dick Lundberg
SV: Linux Mint
Ja. Mint 4 är kanon! Uppgradering avråder de bestämt från på den officiella hemsidan även om det förstås går att göra det.
farmfield
SV: Linux Mint
Inlägg av farmfield »
to wonder skrev:Undrar om en sak nar jag bootar upp med mint live-cd skivan, innan skrivbordet ska visas blir allt svart , men syns sen nar man ror vid datormusen. Som en skarmslackare  fast de ar uppstart pa ca: 2 min.....screensaver is 10 min originalinstallningen...hmm!
Det där händer mig titt som tätt på mina Gutsy-installationer också...
jkrx
SV: Linux Mint
Inlägg av jkrx »
Mint är både snyggare och mer användar vänligt i mitt tycke än ubuntu :)
