We are happpy to announce the 0.5.2 release of compiz. Among countless optimizations and fixes it now offers better multi-screen support, a logging framework, improved plugin- and option-systems and the often demanded cube transparency.
http://www.compiz.org/
Compiz V 0.52 ute
SV: Compiz V 0.52 ute
Och så Compiz-fusions första release som bygger på den.
http://compiz-fusion.org/index.php?acti ... 80cdeeedf3
