rTorrent droppar alla peers på privata trackers:-\
andreas35
Utgåva: 10.04 Lucid LTS
Inlägg av andreas35 »
hej!..
som topic/ämnet så droppar rtorrent alla peers när filenn e på 100% om den kommer från en privat-tracker,
JAG HAR PROVAT/ÄNDRAT  schedule = ratio,60,60,stop_on_ratio=0        (provat= 0 1 2 100 110 200)
                                            Ctrl-S på torrenten,
jag har ingen router/brandvägg heller.
vad kan vara fel o hur fixar jag rtorrent,
.rtorrent.rc
"# Maximum and minimum number of peers to connect to per torrent.
min_peers = 60
max_peers = 180
# Same as above but for seeding completed torrents (-1 = same as downloading)
min_peers_seed = 10
max_peers_seed = 50
# Maximum number of simultanious uploads per torrent.
max_uploads = 20
# Global upload and download rate in KiB. "0" for unlimited.
download_rate = 12500
upload_rate = 2500
# Default directory to save the downloaded torrents.
directory = /media/sda2/downloads
# Default session directory.
session = /home/andreas/torrents/sessions
# Watch a directory for new torrents, and stop those that have been
# deleted.
schedule = watch_directory,5,5,load_start=/home/andreas/torrents/torrentfiles/*.torrent
schedule = untied_directory,5,5,stop_untied=
# Close torrents when diskspace is low.
schedule = low_diskspace,5,60,close_low_diskspace=100M
#Stop torrents when reaching upload ratio in percent,
# when also reaching total upload in bytes, or when
# reaching final upload ratio in percent.
# example: stop at ratio 2.0 with at least 200 MB uploaded, or else ratio 20.0
# Port range to use for listening.
port_range = 50990-50999
# Start opening ports at a random position within the port range.
port_random = yes
# Set whetever the client should try to connect to UDP trackers.
use_udp_trackers = yes
max_open_files = 208
#check_hash = yes
safe_sync = yes
#max_memory_usage = 768000
encryption = allow_incoming,enable_retry,prefer_plaintext,try_outgoing,require,require_RC4
connection_leech = seed
MVH Andreas ubuntu-noob
:) fy va kul detta e!
