problem install updates
lasseroth
Inlägg av lasseroth »
när jag klickar på updates får jag följande
Software index is broken
jag uppmanas köra
run "sudo apt-get install -f" in a terminal to fix this issue at first.
och får då följande
lasseroth@ubuntu:~$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  gftp-text gftp-common
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
  totem-xine
0 upgraded, 0 newly installed, 1 to remove and 41 not upgraded.
3 not fully installed or removed.
Need to get 0B of archives.
After unpacking 6787kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 123107 files and directories currently installed.)
Removing totem-xine ...
(update-desktop-database:6089): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
Segmentation fault (core dumped)
dpkg: error processing totem-xine (--remove):
subprocess post-removal script returned error exit status 139
Errors were encountered while processing:
totem-xine
Okänd
SV: problem install updates
Inlägg av Okänd »
starta pakethanteraren (synaptic)
Sen där under nån flik, finns fixa trasiga paket. Testa det, se om det sen funkar.....
lasseroth
jag hittade ett ställe att klicka "mark all uprades"
då laddas 48 filer ner för installation, dock med dessa errors
E: openoffice.org-common: subprocess post-installation script returned error exit status 139
E: gnome-btdownload: subprocess post-installation script returned error exit status 139
E: openoffice.org-writer: subprocess post-installation script returned error exit status 139
E: openoffice.org-calc: subprocess post-installation script returned error exit status 139
E: openoffice.org-draw: subprocess post-installation script returned error exit status 139
E: openoffice.org-impress: dependency problems - leaving unconfigured
E: openoffice.org-math: subprocess post-installation script returned error exit status 139
E: openoffice.org-java-common: dependency problems - leaving unconfigured
E: openoffice.org-base: dependency problems - leaving unconfigured
E: openoffice.org-filter-mobiledev: dependency problems - leaving unconfigured
E: openoffice.org: dependency problems - leaving unconfigured
E: openoffice.org-evolution: dependency problems - leaving unconfigured
E: totem-xine: subprocess post-installation script returned error exit status 139
E: mplayer: subprocess post-installation script returned error exit status 139
dpkg --configure -a
Hjälper det?
lasseroth
lasseroth@ubuntu:~$ dpkg --configure -a
dpkg: requested operation requires superuser privilege
och vad gör jag då?
lasseroth
lasseroth@ubuntu:~$ sudo dpkg --configure -a
Password:
Setting up openoffice.org-math (2.2.0-1ubuntu4) ...
(update-desktop-database:9002): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing openoffice.org-math (--configure):
Setting up openoffice.org-draw (2.2.0-1ubuntu4) ...
(update-desktop-database:9010): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing openoffice.org-draw (--configure):
Setting up gnome-btdownload (0.0.28-1~feisty1) ...
(update-desktop-database:9021): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing gnome-btdownload (--configure):
Setting up openoffice.org-calc (2.2.0-1ubuntu4) ...
(update-desktop-database:9029): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing openoffice.org-calc (--configure):
Setting up mplayer (1.0~rc1-0ubuntu9.1) ...
(update-desktop-database:9034): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing mplayer (--configure):
Setting up openoffice.org-common (2.2.0-1ubuntu4) ...
Updating OpenOffice.org's dictionary list... done.
(update-desktop-database:9046): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing openoffice.org-common (--configure):
Setting up openoffice.org-writer (2.2.0-1ubuntu4) ...
(update-desktop-database:9054): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing openoffice.org-writer (--configure):
Setting up totem-xine (2.18.1-0ubuntu3) ...
(update-desktop-database:9070): GLib-CRITICAL **: g_key_file_get_string_list: assertion `group_name != NULL' failed
dpkg: error processing totem-xine (--configure):
dpkg: dependency problems prevent configuration of openoffice.org:
openoffice.org depends on openoffice.org-writer; however:
  Package openoffice.org-writer is not configured yet.
openoffice.org depends on openoffice.org-calc; however:
  Package openoffice.org-calc is not configured yet.
openoffice.org depends on openoffice.org-draw; however:
  Package openoffice.org-draw is not configured yet.
openoffice.org depends on openoffice.org-math; however:
  Package openoffice.org-math is not configured yet.
dpkg: error processing openoffice.org (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-java-common:
openoffice.org-java-common depends on openoffice.org-common; however:
  Package openoffice.org-common is not configured yet.
dpkg: error processing openoffice.org-java-common (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-impress:
openoffice.org-impress depends on openoffice.org-draw (= 2.2.0-1ubuntu4); however:
dpkg: error processing openoffice.org-impress (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-base:
openoffice.org-base depends on openoffice.org-java-common; however:
  Package openoffice.org-java-common is not configured yet.
dpkg: error processing openoffice.org-base (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-filter-mobiledev:
openoffice.org-filter-mobiledev depends on openoffice.org-java-common (= 2.2.0-1ubuntu4); however:
dpkg: error processing openoffice.org-filter-mobiledev (--configure):
dpkg: dependency problems prevent configuration of openoffice.org-evolution:
openoffice.org-evolution depends on openoffice.org-base; however:
  Package openoffice.org-base is not configured yet.
dpkg: error processing openoffice.org-evolution (--configure):
openoffice.org-math
openoffice.org-draw
gnome-btdownload
openoffice.org-calc
mplayer
mrArne
Utgåva: 10.04 Lucid LTS
Inlägg av mrArne »
Hallå,
Jag hittade en jobbig lösning som tidigare hänvisats till i detta forum;
http://ubuntuforums.org/showthread.php?t=514646
Den handlar om felaktigt tidsstämplade fonter.
Sen finns det en enkel lösning enligt nedanstående länk;
http://ubuntuforums.org/showthread.php?t=515273
Det är bara å fiska hem ett par paket med synaptic  ;) ;)
Ha re rama
ola
Varför snöar jag alltid in på sånt här...?
Registered Linux User #446194
tcob
Vidare problem "Software index is broken"
Inlägg av tcob »
Skriver jag:
'sudo apt-get install -f'
i terminalen får jag fram:
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
skriver jag således
får jag fram
Okej. Hur blir jag superuser?
(Kan inte starta synaptic heller. Får bara fram
E: _cache->open() failed, please report.
Vad göra? Kan inte istallera något och inte heller uppdatera.
SV: Vidare problem "Software index is broken"
tcob skrev: Skriver jag:
skriver jag således
får jag fram
Lägg till sudo före kommandot så får du rättigheter. :)
tcob
Inlägg av tcob »
Ja men ser man på. Tackar.
