Galgalid
Inlägg: 1646 Blev medlem: 08 dec 2006, 12:30
Inlägg
av Galgalid » 21 jul 2007, 22:46
Hur ändrar jag upplösningen? Jag har en 1280x1024 skärm men max-upplösningen är 1024x768(en riktig plåga): min xorg.conf ser ut såhär:
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "se"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV380 0x3e50 [Radeon X600]"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-51
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV380 0x3e50 [Radeon X600]"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1024x768" "800x600"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Jag ändrade fölande i förhoppningen att nåt skulle hända: "1280x1024" "1024x768" "800x600". Det stod ursprungligen: "1024x768" "800x600" "640x480"
Så jag ändrade upp det ett snäpp. För säkerhets-skull har jag gjort en back-up på xorg.conf
koch
Inlägg: 693 Blev medlem: 13 jul 2007, 16:55
Inlägg
av koch » 21 jul 2007, 22:48
Så gjorde jag med fast jag la bara till 1280x940... Så jag vet inte vad som kan vara problemet.
Okänd
Inlägg: 30172 Blev medlem: 03 mar 2008, 01:30
Inlägg
av Okänd » 22 jul 2007, 09:20
funkar 1280x1024 i live-cd?
zero gravity
Wikiadmin
Inlägg: 2504 Blev medlem: 15 apr 2006, 15:37
Inlägg
av zero gravity » 22 jul 2007, 09:31
Ibland glömmer man att starta om x efter man har ändrat i xorg.
Tryck ctrl+alt+backspace (bakåtpil) för att starta om x. Logga sedan in och kolla om din upplösning står med under System -> Inställningar -> Skärmupplösning.
Alternativt kan du configurera om hela xorg.conf med kommandot:
Abusus non tollit usum
Galgalid
Inlägg
av Galgalid » 22 jul 2007, 11:16
jag kör en x-config och provar...meddelar resultatet sen
Samme
Inlägg: 107 Blev medlem: 02 maj 2007, 19:09
Inlägg
av Samme » 22 jul 2007, 11:30
Jag lånar tråden.Hoppas det går bra
xorg.conf ser ut så här och den har alltid gjort det(=har inte ändrat i den).
Men jag kan inte få 1280x1024
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
Fontpath "/usr/share/fonts/X11/misc"
Fontpath "/usr/share/fonts/X11/cyrillic"
Fontpath "/usr/share/fonts/X11/100dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/75dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/Type1"
Fontpath "/usr/share/fonts/X11/100dpi"
Fontpath "/usr/share/fonts/X11/75dpi"
Fontpath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Driver "wacom"
Identifier "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
EndSection
Section "Device"
Identifier "nVidia Corporation NV43 [GeForce 6600]"
Driver "nvidia"
Busid "PCI:1:0:0"
Option "AddARGBVisuals" "True"
Option "AddARGBGLXVisuals" "True"
Option "NoLogo" "True"
EndSection
Section "Monitor"
Identifier "TFT 30"
Option "DPMS"
EndSection
Section "Screen"
Device "nVidia Corporation NV43 [GeForce 6600]"
Monitor "TFT 30"
Defaultdepth 24
Depth 1
Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
screen "Default Screen"
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
Inputdevice "stylus" "SendCoreEvents"
Inputdevice "cursor" "SendCoreEvents"
Inputdevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Mvh Samme
Rasmus
Inlägg: 2291 Blev medlem: 07 sep 2006, 18:33
Inlägg
av Rasmus » 22 jul 2007, 11:35
# package.
Section "Files"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Driver "wacom"
Identifier "stylus"
EndSection
Driver "wacom"
Identifier "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
EndSection
Section "Device"
Driver "nvidia"
Busid "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "TFT 30"
Option "DPMS"
EndSection
Section "Screen"
Monitor "TFT 30"
Defaultdepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
Mvh Samme
Gör som jag gjorde och tvinga han att använda 1280x1024 d.v.s. ta bort dem andra. OPS ta backup på xorg först.
Samme
Inlägg
av Samme » 22 jul 2007, 11:54
Okej, hur tar jag backup då?
Galgalid
Inlägg
av Galgalid » 22 jul 2007, 11:55
sudo cp /etc/X11/xorg.conf /home/dittLoginNamn/xorg.conf.backup
för att återställa:
sudo cp /home/dittLoginNamn/xorg.conf.backup /etc/X11/xorg.conf
Galgalid
Inlägg
av Galgalid » 22 jul 2007, 11:57
Jag ändrade till bara "1280x1024"....och nu fick jag en hel del skumma modes...typ 1280 x 800 med mera..men inte den jag letade efter...annars kan man väl lista alla upplösningar upp till dom på 2000 eller vad det nu är....är nån villig att göra en lista åt mig?
Okänd
Inlägg
av Okänd » 22 jul 2007, 12:05
Listan syns här.... det står
HÄR vid bilden, Tab o mellanslag för att aktivera en upplösning.
http://ubuntu-se.org/drupal/node/249
Sen är det lite beroende vilken drivare man kör...OggVorbis siggen tyder på att man kör "rent"
Galgalid
Inlägg
av Galgalid » 22 jul 2007, 12:16
yep, jag kör rent ^^..vart tog förresten sid/stoffepojken vägen? Det accet är raderat
Okänd
Inlägg
av Okänd » 22 jul 2007, 12:32
Jo då får du väl bara bocka i upplösningen med ett mellanslag.
samt sedan starta om X med Ctrl-Alt-Backsteg och sedan kolla upplösningen i Meny System> Inställningar.
Kör man 3D drivare får man då även kolla det via tex nVidia-settings
Galgalid
Inlägg
av Galgalid » 22 jul 2007, 14:39
funkade inte
när jag loggar in så är hänger sig allt...så det blir att återställa xorg.conf bara
