http://ubuntusoftware.info/Ubuntu_Ultimate_CD/
Ett script körs efter installation för kompletteringar.
How it works
As a live CD it is not too special or anything to write home about, it's you basic feisty fawn pre-injected with the version checking script. After installed a whole new ball of wax. Gaim will be removed from the distro through the upgrade script as it is no longer gaim and replaced by Pidgin, Compiz was also removed and replaced by Compiz Fusion, Envy has also been injected for driver installation, but otherwise pure Feisty. There is a icon on the desktop once installed called Upgrade, when clicked checks for a newer version of the script ultimately it gives you your choice of distro path or custom allowing you to select what will be installed. It then fetches and installs the software you have selected, building your Ultimate distro. Upon completion of installing your software it will then run Envy to allow video driver installation. The script will be constantly updated to allow new features / software.
Terminalkommando för mjukvarukompletteringar
In order to have full browser capabilty Java, Flash & Acrobat reader need to be installed; they are not pre-installed due to license agreements. If you installed them from the live CD/DVD before installing the distro you still have to install it after distro installation. It does not hurt to do the below statement if you are unsure.
Open a terminal: Applications>>Accessories>>Terminal
Paste the following:
sudo apt-get install -y --force-yes java flash acroread java-browser-plugin
Diskussionstråd Ubuntuforums:
http://ubuntuforums.org/showthread.php?t=461378
Buggar:
https://launchpad.net/ubuntu.ultimate/
Svensk nedladdning:
http://mirror2.jerrcs.net/ubuntu-ultimate-1.4-cd.iso
Have Fun...
