felmeddelande jag får varje gång jag försöker köra ./configure som root
root@machnine-desktop:/home/machnine/Desktop/kxdocker/kxdocker-1.1.4a# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for kde-config... /usr/bin/kde-config
checking where to install... /usr (as returned by kde-config)
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking whether gcc is blacklisted... no
checking whether g++ supports -Wmissing-format-attribute... no
checking whether gcc supports -Wmissing-format-attribute... yes
checking whether g++ supports -Wundef... no
checking whether g++ supports -Wno-long-long... no
checking whether g++ supports -Wno-non-virtual-dtor... no
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
blaa jag blir så jäkla trött på allt just nu, bara krångel hela tiden..
att man inte ska kunna köra ./configure innan make och make install utan problem. sanslöst.. får samma felmeddelande på alla paket jag försöker med ./configure på innan installation..
