Jag har precis installerat Ubuntu Dapper 32 på min Acer 5020 och det fungera fint.
lspci
0000:00:00.0 Host bridge: ATI Technologies Inc RS480 Host Bridge (rev 01)
0000:00:02.0 PCI bridge: ATI Technologies Inc RS480 PCI-X Root Port
0000:00:06.0 PCI bridge: ATI Technologies Inc: Unknown device 5a38
0000:00:13.0 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller
0000:00:13.1 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller
0000:00:13.2 USB Controller: ATI Technologies Inc IXP SB400 USB2 Host Controller
0000:00:14.0 SMBus: ATI Technologies Inc IXP SB400 SMBus Controller (rev 11)
0000:00:14.1 IDE interface: ATI Technologies Inc Standard Dual Channel PCI IDE Controller ATI
0000:00:14.3 ISA bridge: ATI Technologies Inc IXP SB400 PCI-ISA Bridge
0000:00:14.4 PCI bridge: ATI Technologies Inc IXP SB400 PCI-PCI Bridge
0000:00:14.5 Multimedia audio controller: ATI Technologies Inc IXP SB400 AC'97 Audio Controller (rev 02)
0000:00:14.6 Modem: ATI Technologies Inc ATI SB400 - AC'97 Modem Controller (rev 02)
0000:00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
0000:00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
0000:00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
0000:00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
0000:01:00.0 VGA compatible controller: ATI Technologies Inc M24 1P [Radeon Mobility X600]
0000:06:05.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
0000:06:06.0 CardBus bridge: Texas Instruments PCIxx21/x515 Cardbus Controller
0000:06:06.2 FireWire (IEEE 1394): Texas Instruments OHCI Compliant IEEE 1394 Host Controller
0000:06:06.3 Mass storage controller: Texas Instruments PCIxx21 Integrated FlashMedia Controller
0000:06:06.4 0805: Texas Instruments PCI6411, PCI6421, PCI6611, PCI6621, PCI7411, PCI7421, PCI7611, PCI7621 Secure Digital (SD) Controller
0000:06:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8169 Gigabit Ethernet (rev 10)
Tyvärr har jag haft problem med programmet Gaphor. Installerade det via apt-get och när jag försöker start upp det från konsolen får jag felmeddelande:
:~$ gaphor
** (gaphor:9725): WARNING **: couldn't make the type `CanvasGroup' ready
/usr/lib/python2.4/site-packages/diacanvas/__init__.py:13: RuntimeWarning: tp_co mpare didn't return -1 or -2 for exception
from _canvas import *
TypeError: Cannot create a consistent method resolution
order (MRO) for bases GObject, CanvasGroupableIface, CanvasGroupable
/usr/lib/python2.4/site-packages/diacanvas/__init__.py:19: DeprecationWarning: M odule gnome.canvas is deprecated; please import gnomecanvas instead
from view import *
/usr/lib/python2.4/site-packages/gaphor/undomanager.py:195: RuntimeWarning: Inte rface type UndoManager has no python implementation support
gobject.type_register(UndoManager)
Traceback (most recent call last):
File "/usr/bin/gaphor", line 10, in ?
gaphor.main(model)
File "/usr/lib/python2.4/site-packages/gaphor/__init__.py", line 48, in main
import diagram
File "/usr/lib/python2.4/site-packages/gaphor/diagram/__init__.py", line 56, i n ?
from classifier import ClassifierItem
File "/usr/lib/python2.4/site-packages/gaphor/diagram/classifier.py", line 18, in ?
from nameditem import NamedItem
File "/usr/lib/python2.4/site-packages/gaphor/diagram/nameditem.py", line 9, i n ?
from elementitem import ElementItem
File "/usr/lib/python2.4/site-packages/gaphor/diagram/elementitem.py", line 74 , in ?
initialize_item(ElementItem)
File "/usr/lib/python2.4/site-packages/gaphor/diagram/__init__.py", line 39, i n initialize_item
if (diacanvas.CanvasItem in bases) or \
AttributeError: 'module' object has no attribute 'CanvasGroup'
Har sökt på det engelska forumet och det verkar vara fler med liknande problem, dock utan någon direkt lösning:
http://www.ubuntuforums.org/showthread.php?t=194979
Några förslag på lösning?
