Ingen upgrade och dist-upgrade i nya versionen av Aptitude.
Okänd
Inlägg av Okänd »
Jag satt och undersökte nya versionen av Aptitude nu. 0.4.5. Det verkar som att upgrade och dist-upgrade är utbytt mot safe-upgrade och full-upgrade.
Från man aptitude:
       safe-upgrade
           Upgrades installed packages to their most recent version. Installed packages will not
           be removed unless they are unused (see the section “Managing Automatically Installed
           Packages” in the aptitude reference manual); packages which are not currently
           installed will not be installed.
           It is sometimes necessary to remove or install one package in order to upgrade
           another; this command is not able to upgrade packages in such situations. Use the
           full-upgrade command to upgrade as many packages as possible.
       full-upgrade
           Upgrades installed packages to their most recent version, removing or installing
           packages as necessary. This command is less conservative than safe-upgrade and thus
           more likely to perform unwanted actions. However, it is capable of upgrading packages
           that safe-upgrade cannot upgrade.
Bökigt...
Lars
SV: Ingen upgrade och dist-upgrade i nya versionen av Aptitude.
Inlägg av Lars »
Blir det motsvarande ändringar i apt-get?
Okänd
Inlägg av Okänd »
Lars skrev: Blir det motsvarande ändringar i apt-get?
Jag vet inte faktiskt inte. Jag hoppas det. safe-upgrade och full-upgrade är enligt mig mer logiskt om man ser till nya användare.
Återgå till "Terminalforum"
