Skärmupplösning Xubuntu 6.10
J0henz
Inlägg av J0henz »
Hur kan jag få högre skärmupplösning än 800x600, eller är det den högsta, på Windows XP kan jag få upp till 1280x1024.
Jag har ett ATI Mobility Radeon X1300 grafikkort.
Här är innehållet i /etc/X11/xorg.conf
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#  sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier    "Default Layout"
Screen      0  "aticonfig-Screen[0]" 0 0
InputDevice    "Generic Keyboard"
InputDevice    "Configured Mouse"
InputDevice    "stylus" "SendCoreEvents"
InputDevice    "cursor" "SendCoreEvents"
InputDevice    "eraser" "SendCoreEvents"
InputDevice    "Synaptics Touchpad"
EndSection
Section "Files"
# path to defoma fonts
FontPath    "/usr/share/X11/fonts/misc"
FontPath    "/usr/share/X11/fonts/cyrillic"
FontPath    "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath    "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath    "/usr/share/X11/fonts/Type1"
FontPath    "/usr/share/X11/fonts/100dpi"
FontPath    "/usr/share/X11/fonts/75dpi"
FontPath    "/usr/share/fonts/X11/misc"
FontPath    "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load  "i2c"
Load  "bitmap"
Load  "ddc"
Load  "dri"
Load  "extmod"
Load  "freetype"
Load  "glx"
Load  "int10"
Load  "type1"
Load  "vbe"
EndSection
Section "InputDevice"
Identifier  "Generic Keyboard"
Driver      "kbd"
Option     "CoreKeyboard"
Option     "XkbRules" "xorg"
Option     "XkbModel" "pc105"
Option     "XkbLayout" "se"
Option     "XkbOptions" "lv3:ralt_switch"
EndSection
Identifier  "Configured Mouse"
Driver      "mouse"
Option     "CorePointer"
Option     "Device" "/dev/input/mice"
Option     "Protocol" "ExplorerPS/2"
Option     "ZAxisMapping" "4 5"
Option     "Emulate3Buttons" "true"
EndSection
Identifier  "Synaptics Touchpad"
Driver      "synaptics"
Option     "SendCoreEvents" "true"
Option     "Device" "/dev/psaux"
Option     "Protocol" "auto-dev"
Option     "HorizScrollDelta" "0"
EndSection
                                                      # /dev/input/event
                                                      # for USB
Identifier  "stylus"
Driver      "wacom"
Option     "Device" "/dev/wacom"          # Change to
Option     "Type" "stylus"
Option     "ForceDevice" "ISDV4"              # Tablet PC ONLY
EndSection
                                                      # /dev/input/event
                                                      # for USB
Identifier  "eraser"
Driver      "wacom"
Option     "Type" "eraser"
EndSection
                                                      # /dev/input/event
                                                      # for USB
Identifier  "cursor"
Driver      "wacom"
Option     "Type" "cursor"
EndSection
Section "Monitor"
Identifier  "Generic Monitor"
Option     "DPMS"
EndSection
Section "Monitor"
Identifier  "aticonfig-Monitor[0]"
Option     "VendorName" "ATI Proprietary Driver"
Option     "ModelName" "Generic Autodetecting Monitor"
Option     "DPMS" "true"
EndSection
Section "Device"
Identifier  "ATI Technologies, Inc. ATI Default Card"
Driver      "vesa"
BusID      "PCI:1:0:0"
EndSection
Section "Device"
Identifier  "aticonfig-Device[0]"
Driver      "fglrx"
EndSection
Section "Screen"
Identifier "Default Screen"
Device    "ATI Technologies, Inc. ATI Default Card"
Monitor    "Generic Monitor"
DefaultDepth    24
SubSection "Display"
Depth    1
Modes    "1024x768" "800x600" "640x480"
EndSubSection
Depth    4
EndSubSection
Depth    8
EndSubSection
Depth    15
EndSubSection
Depth    16
EndSubSection
Depth    24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device    "aticonfig-Device[0]"
Monitor    "aticonfig-Monitor[0]"
DefaultDepth    24
Viewport  0 0
Depth    24
EndSubSection
EndSection
Section "DRI"
Mode        0666
EndSection
nicefinger
SV: Skärmupplösning Xubuntu 6.10
Inlägg av nicefinger »
Det kan du nog få. Visa innehållet i filen /etc/X11/xorg.conf här så kan säkert nån hjälpa dig. Berätta också vad du har för grafikkort.
ycc
Inlägg av ycc »
Jag är ingen expert, men jag hade samma läge, då gjorde jag:
1. säkerhetskopiera:
sudo cp /etc/X11/xorg.conf   /etc/X11/xorg.conf.backup
2.sudo dpkg-reconfigure xserver-xorg
Det ökade upplösningen en del. Det sista steget, för att få maximal upplösning var att ändra den här delen av etc/X11/xorg.conf:
      Depth     1
   EndSubSection
      Depth     4
   EndSubSection
      Depth     8
   EndSubSection
      Depth     15
   EndSubSection
      Depth     16
   EndSubSection
      Depth     24
   EndSubSection
Helt enkelt manuellt lägga till den upplösning jag visste kortet klarade.
