emil@MegaLeif: ~/svn/composite $ ./makecc install
Welcome to Compiz/CompComm
Configuring compiz...
Executing autogen.sh --prefix=/usr/local --enable-kde --disable-gtk --enable-librsvg in compiz...
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy
libtoolize: `config.guess' exists: use `--force' to overwrite
libtoolize: `config.sub' exists: use `--force' to overwrite
libtoolize: `ltmain.sh' exists: use `--force' to overwrite
autoreconf: running: /usr/bin/autoconf
autoreconf: running: /usr/bin/autoheader
autoreconf: running: automake --add-missing --copy --no-force
kde/window-decorator/Makefile.am:32: `%'-style pattern rules are a GNU make extension
kde/window-decorator/Makefile.am:35: `%'-style pattern rules are a GNU make extension
kde/window-decorator/Makefile.am:38: `%'-style pattern rules are a GNU make extension
metadata/Makefile.am:39: patsubst %.xml.in,compiz-%.schemas,$(xml_in_files: non-POSIX variable name
metadata/Makefile.am:39: (probably a GNU make extension)
metadata/Makefile.am:42: `%'-style pattern rules are a GNU make extension
metadata/Makefile.am:43: subst compiz-,,$*: non-POSIX variable name
metadata/Makefile.am:43: (probably a GNU make extension)
autoreconf: Leaving directory `.'
cat: /etc/ld.so.conf.d/*.conf: No such file or directory
Installing compiz...
Executing make
decorator.o: In function `KWinInterface':
/home/emil/svn/composite/compiz/kde/window-decorator/KWinInterface.h:9: undefined reference to `VTT for KWD::Decorator'
decorator.o: In function `Decorator':
/home/emil/svn/composite/compiz/kde/window-decorator/decorator.cpp:195: undefined reference to `vtable for KWD::Decorator'
decorator.o: In function `~KWinInterface':
decorator.o: In function `~Decorator':
/home/emil/svn/composite/compiz/kde/window-decorator/decorator.cpp:245: undefined reference to `vtable for KWD::Decorator'
decorator.o:/home/emil/svn/composite/compiz/kde/window-decorator/decorator.cpp:245: more undefined references to `vtable for KWD::Decorator' follow
window.o: In function `Window':
/home/emil/svn/composite/compiz/kde/window-decorator/window.cpp:86: undefined reference to `vtable for KWD::Window'
window.o: In function `~Window':
/home/emil/svn/composite/compiz/kde/window-decorator/window.cpp:132: undefined reference to `vtable for KWD::Window'
window.o:/home/emil/svn/composite/compiz/kde/window-decorator/window.cpp:132: more undefined references to `vtable for KWD::Window' follow
collect2: ld returned 1 exit status
make[3]: *** [kde-window-decorator] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
