jeg har problemer med at rtorrent ikke kjører unrar på complete, eller det skjer ikke noe.
Dette er rtorrent configfilen min:
scgi_port = localhost:5000
#scgi_local = /home/rt/.rsession/rpc.socket
# This is an example resource file for rTorrent. Copy to ~/.rtorrent.rc and enable/modify the options as
# needed. Remember to uncomment the options you wish to enable.
# Maximum and minimum number of peers to connect to per torrent.
min_peers = 40
max_peers = 100
# Same as above but for seeding completed torrents (-1 = same as downloading)
min_peers_seed = 10
max_peers_seed = 50
# Maximum number of simultanious uploads per torrent.
max_uploads = 15
# Global upload and download rate in KiB. "0" for unlimited.
download_rate =1050
upload_rate =125
# Default directory to save the downloaded torrents.
#directory =/download
# Default session directory. Make sure you don't run multiple instance
# of rtorrent using the same session directory. Perhaps using a
# relative path?
session = /home/rt/.rsession
# Watch a directory for new torrents, and stop those that have been
# deleted.
schedule = watch_directory,10,10,load_start=/download/*.torrent
# Denne maa vaere kommentert ut for at ctrl +d (stopp) skap funke..
#schedule = tied_directory,10,10,start_tied=
schedule = untied_directory,10,10,close_untied=
# Multiple watch folders
schedule = watch_directory_1,10,10,"load_start=/download/Music/*.torrent,d.set_directory=/download/Music/"
schedule = watch_directory_2,10,10,"load_start=/download/TV/*.torrent,d.set_directory=/download/TV/,d.set_custom1=/arkiv/Serier/"
schedule = watch_directory_3,10,10,"load_start=/download/Films/*.torrent,d.set_directory=/download/Films/,d.set_custom2=/arkiv/Filmer/"
schedule = watch_directory_4,10,10,"load_start=/download/Games/*.torrent,d.set_directory=/download/Games/"
schedule = watch_directory_5,10,10,"load_start=/download/Software/*.torrent,d.set_directory=/download/Software/"
schedule = watch_directory_6,10,10,"load_start=/download/Annet/*.torrent,d.set_directory=/download/Annet/"
schedule = watch_directory_7,10,10,"load_start=/download/PDF/*.torrent,d.set_directory=/download/PDF/"
schedule = watch_directory_8,10,10,"load_start=/download/Fonts/*.torrent,d.set_directory=/download/Fonts/"
# Close torrents when diskspace is low.
schedule = low_diskspace,5,60,close_low_diskspace=100M
#Pakke ut rar-filer og flytte de.
on_finished = unrar_tv,"execute=/home/rt/bin/unpack_torrent_rar.sh,$d.get_base_path=,$d.get_custom1="
on_finished = unrar_filmer,"execute=/home/rt/bin/unpack_torrent_rar.sh,$d.get_base_path=,$d.get_custom2="
# Create symlinks in the watch directory with a suffix indicating the
# download state.
#on_start = link1,"create_link=tied,,.started"
#on_stop = link1,"delete_link=tied,,.started"
#on_finished = link1,"create_link=tied,,.finished"
#on_erase = link1,"delete_link=tied,,.finished"
# Create symlinks in the same directory as the download.
#on_start = /download/Software/,"create_link=base_path,,.started"
#on_stop = /download/Software/,"delete_link=base_path,,.started"
#on_finished = /download/Software/,"create_link=base_path,,.finished"
#on_erase = /download/Software/,"delete_link=base_path,,.finished"
# Max slots
max_uploads_global = 0
max_downloads_global = 3
# Stop torrents when reaching upload ratio in percent,
# when also reaching total upload in bytes, or when
# reaching final upload ratio in percent.
# example: stop at ratio 2.0 with at least 200 MB uploaded, or else ratio 20.0
#schedule = ratio,60,60,stop_on_ratio=200,200M,2000
# The ip address reported to the tracker.
#ip = 127.0.0.1
#ip = rakshasa.no
# The ip address the listening socket and outgoing connections is
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
# Port range to use for listening.
port_range = 55500-55555
# Start opening ports at a random position within the port range.
#port_random = no
# Check hash for finished torrents. Might be usefull until the bug is
# fixed that causes lack of diskspace not to be properly reported.
check_hash = yes
# Set whetever the client should try to connect to UDP trackers.
#use_udp_trackers = yes
# Alternative calls to bind and ip that should handle dynamic ip's.
#schedule = ip_tick,0,1800,ip=rakshasa
#schedule = bind_tick,0,1800,bind=rakshasa
# Encryption options, set to none (default) or any combination of the following:
# allow_incoming, try_outgoing, require, require_RC4, enable_retry, prefer_plaintext
# The example value allows incoming encrypted connections, starts unencrypted
# outgoing connections but retries with encryption if they fail, preferring
# plaintext to RC4 encryption after the encrypted handshake
# encryption = allow_incoming,enable_retry,try_outgoing
# Do not modify the following parameters unless you know what you're doing.
# Hash read-ahead controls how many MB to request the kernel to read
# ahead. If the value is too low the disk may not be fully utilized,
# while if too high the kernel might not be able to keep the read
# pages in memory thus end up trashing.
#hash_read_ahead = 10
# Interval between attempts to check the hash, in milliseconds.
#hash_interval = 100
# Number of attempts to check the hash while using the mincore status,
# before forcing. Overworked systems might need lower values to get a
# decent hash checking rate.
#hash_max_tries = 10
# Max number of files to keep open simultaniously.
#max_open_files = 128
# Number of sockets to simultaneously keep open.
#max_open_sockets = <no default>
# Example of scheduling commands: Switch between two ip's every 5
# seconds.
#schedule = "ip_tick1,5,10,ip=torretta"
#schedule = "ip_tick2,10,10,ip=lampedusa"
# Remove a scheduled event.
#schedule_remove = "ip_tick1"
directory=/home/media/
#!/bin/bash
if [ "$2" != "" ]; then
yes no | nice -n 15 unrar x -r "$1/*.rar" "$2" >&- 2>&- &
fi
Bruker rt skal ha rettigheter til å pakke ut i /arkiv.
Noen tips?
Takk for all hjelp!
