Compiz Fusion
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
Ändra den här till 5 sekunder
Writing configuration to: /home/john/.config/compiz-managerrc
Starting delayed decorator in the background: sleep 1 && emerald --replace &
sleep 5      (1 sekund är för kort för de flesta burkar.)
Sen starta om X om det strular,  Ctrl-Alt-Backsteg så startar du med rent X
beryl-manager ska alltid funka  eller beryl --replace
invaderjohn
SV: Compiz Fusion
Inlägg av invaderjohn »
plun skrev: Ändra den här till 5 sekunder
får detta nu
john@ubuntu:~$ compiz-manager
Looking for configuration file(s):
         Not found: /etc/xdg//compiz-managerrc
         Loading /home/john/.config/compiz-managerrc
Skipping nVidia check, using stored value.
Skipping Xgl check, using stored value.
Skipping FBConfig check, using stored value.
Skipping texture_from_pixmap check, using stored value.
Skipping non-power-of-two texture check, using stored value.
Skipping Composite extension check, using stored value.
Skipping Damage extension check, using stored value.
Skipping XSync extension check, using stored value.
Skipping screen detection check, using stored value.
Skipping "possible" test, using stored value.
Not writing config; allready exists.
Starting delayed decorator in the background: sleep 5 && emerald --replace &
Checks indicate compiz should work on your system
Exporting: __GL_YIELD=NOTHING
Executing: compiz --loose-binding --sm-disable --replace ccp
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
Okidok, nu startar det riktigt.
Du måste aktivera pluggar  sudo ccsm  eller via inställningar > Compiz bla bla
Så här ser starten ut då
plun@dunder:~$ sudo compiz-manager
         Loading /home/plun/.config/compiz-managerrc
Adding plugin wallpaper (wallpaper)
Adding plugin ezoom (ezoom)
Adding plugin gears (gears)
Adding plugin mswitch (mswitch)
Adding plugin workarounds (workarounds)
Adding plugin dbus (dbus)
Adding plugin expo (expo)
Adding plugin wall (wall)
Adding plugin screenshot (screenshot)
Adding plugin png (png)
Adding plugin wobbly (wobbly)
Adding plugin video (video)
Adding plugin fakeargb (fakeargb)
Adding plugin reflex (reflex)
Adding plugin splash (splash)
Adding plugin showdesktop (showdesktop)
Adding plugin cube (cube)
Adding plugin decoration (decoration)
Adding plugin snap (snap)
Adding plugin winrules (winrules)
Adding plugin mblur (mblur)
Adding plugin water (water)
Adding plugin zoom (zoom)
Adding plugin rotate (rotate)
Adding plugin cubereflex (cubereflex)
Adding plugin fs (fs)
Adding plugin scale (scale)
Adding plugin put (put)
Adding plugin fade (fade)
Adding plugin firepaint (firepaint)
Adding plugin annotate (annotate)
Adding plugin move (move)
Adding plugin animation (animation)
Adding plugin blur (blur)
Adding plugin text (text)
Adding plugin thumbnail (thumbnail)
Adding plugin imgjpeg (imgjpeg)
Adding plugin vpswitch (vpswitch)
Adding plugin group (group)
Adding plugin place (place)
Adding plugin bench (bench)
Adding plugin ring (ring)
Adding plugin switcher (switcher)
Adding plugin snow (snow)
Adding plugin opacify (opacify)
Adding plugin scaleaddon (scaleaddon)
Adding plugin addhelper (addhelper)
Adding plugin inotify (inotify)
Adding plugin minimize (minimize)
Adding plugin regex (regex)
Adding plugin clone (clone)
Adding plugin neg (neg)
Adding plugin svg (svg)
Adding plugin trailfocus (trailfocus)
Adding plugin plane (plane)
Adding plugin fadedesktop (fadedesktop)
Adding core settings (General Options)
Adding plugin resizeinfo (resizeinfo)
Adding plugin resize (resize)
Adding plugin tile (tile)
Adding plugin extrawm (extrawm)
Adding plugin glib (glib)
Adding plugin crashhandler (crashhandler)
Backend     : ini
Integration : true
Profile     : default
Initializing core options...done
compiz (dbus) - Error: dbus_bus_get error: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
compiz (core) - Error: Couldn't activate plugin 'dbus'
Initializing reflex options...done
Initializing showdesktop options...done
Initializing decoration options...done
Initializing winrules options...done
Initializing zoom options...done
Initializing firepaint options...done
Initializing move options...done
Initializing animation options...done
Initializing thumbnail options...done
Initializing place options...done
Initializing ring options...done
Initializing snow options...done
Initializing minimize options...done
Initializing resize options...done
Initializing tile options...done
Initializing wobbly options...done
Initializing fade options...done
Initializing group options...done
Initializing cube options...done
Initializing rotate options...done
Initializing cubereflex options...done
Initializing scale options...done
Initializing switcher options...done
Initializing wallpaper options...done
Initializing expo options...done
Active Plugin List update
invaderjohn
SV: Compiz Fusion
okej. körde igen o nu blir det såhär
Adding plugin sound (sound)
Adding plugin scalefilter (scalefilter)
Adding plugin soundeffects (soundeffects)
Adding plugin 3d (3d)
Adding plugin alsa (alsa)
Backend     : ini
Integration : true
Profile     : default
/usr/bin/compiz-manager: line 535: 20666 Segmentation fault      (core dumped) compiz $ARGS $PLUGINS
nått som inte stämmer där nere ju. hmm
sen vet jag innan att när jag kört scriptet så stod det att man kunde köra compiz-icon, men d går inte på mitt?
EDIT* körde sudo compiz-manager så funka det xD
hur lägger jag detta nu som autostart?
sudo compiz-manager i sessions bara?
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
invaderjohn skrev: nått som inte stämmer där nere ju. hmm
Compiz-icon är buggigt jox som låser burken... ;)
Har du verkligen avinstallerat Compiz innan du började på  ?
Bättre att börja precis som guiden och sedan börja med script.
http://ubuntu-se.org/drupal/node/261
Spelar ingen roll om Trevinos paket installeras.
invaderjohn
SV: Compiz Fusion
japps det gjorde jag.. men som sagt fick igång det nu iaf..
har foprtfarande inte riktigt kommit in i allt men d kommer väl snart :)
men hur ändrar jag skin på emerald nu då?
även när jag öppnar emerald theme manager där o trycker på nått annat så händer inge. har bara det fula röda orginal temat :;/
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
invaderjohn skrev: men hur ändrar jag skin på emerald nu då?
Jo Emerald är det nåt skumt med, kör en    emerald --replace &  så får du det du valt
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
kaapu skrev: Jo det vet jag, men "Rotate With Wheel Near Edges" är inte exakt samma som "Edge Flip Pointer"
När jag för musen mot kanten vill jag inte att den automatiskt ska byta sida på kuben. Jag vill kunna föra musen mot kanten och sen snurra på "mussnurran" och då ska den byta sida. Annars råkar jag byta sida hipp som happ utan att egentligen vela det.  :P
Funktionen finns nu via Desktop sektionen > "Viewport  mouse switch"
Musrullen funkar nu för att byta skrivbord, sen har jag inte klurat ut mer...
http://forums.opencompositing.org/viewt ... f=49&t=893
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
För de som kör med script har Fransrogar ett nytt script ute med helt nya GITs
3D, Sound, mm
http://forums.opencompositing.org/viewt ... &sk=t&sd=a
Engelska i 2:a meddelandet.
Emil.s
SV: Compiz Fusion
Inlägg av Emil.s »
plun skrev: För de som kör med script har Fransrogar ett nytt script ute med helt nya GITs
3D, Sound, mm
Ah, härligt! :)
Dock så har min Linuxburk lagt av.  ::) Vägrar att boota. Ska ta en titt på det imorrn...
invaderjohn
SV: Compiz Fusion
compiz-fusion va kul, funkade dock lite som det ville tyckte jag, kommer nog bli riktigt grymt när d e färdigt, som tur o va e man bara i gnome o leker lite då o då. funkar ju inte i fluxbox så. :P
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
invaderjohn skrev: compiz-fusion va kul, funkade dock lite som det ville tyckte jag, kommer nog bli riktigt grymt när d e färdigt, som tur o va e man bara i gnome o leker lite då o då. funkar ju inte i fluxbox så. :P
Tjau... det mesta funkar  ;)  Man ska fram till ver 0.6.0 som då med säkerhet
är med som standard i Gutsy.
Redan nu finns Fusion pakteten i Gutsys förråd... ;)
Emil.s
SV: Compiz Fusion
Inlägg av Emil.s »
haha, passar nog mer i Cafét, men men:
http://forums.opencompositing.org/viewt ... =46&t=1064
"you know you've been using this stuff too much when......"
... you build from git because you like watching it compile, but not because of any specific new features or bug fixes you want.
... you open/close/minimise windows and right-click on stuff for no reason other than to watch something animate.
Tagen på bar gärning!  ;D
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
Emil.s skrev: haha, passar nog mer i Cafét, men men:
Njau kör man makefusion så sköts det ju automagiskt.... ;)
Men att hämta från varje GIT är ju rena "självplågeriet"... ;D
Emil.s
SV: Compiz Fusion
Inlägg av Emil.s »
Man ser ju fortfarande koden fara förbi. ;)
depeo
SV: Compiz Fusion
Inlägg av depeo »
Har försökt lite med Compiz Fusion och har två frågor.
Hur tar man bort så fönstrena fastnar i kanterna, och varför tar det ett par sekunder att få upp menyer? (det är snabbt för övrigt, bara menyer som är sega)
(Se min fina video där jag visar vad jag menar) ;D
http://homer.ithelpdesk.se/out.ogg
Okänd
SV: Compiz Fusion
Inlägg av Okänd »
depeo skrev: Har försökt lite med Compiz Fusion och har två frågor.
Nice Video.... ;)
Nåt knasar med fönsterhanteringen och Emerald, många dt strular för.
Testa det här scriptet
http://gitweb.opencompositing.org/?p=us ... er;hb=HEAD
Kopiera texten och klistra in i en textredigerare (gedit)  > spara som compiz-manager
Högerklicka sedan på filen via Nautilus och gör den körbar.
sudo compiz-manager
    via terminalen.
invaderjohn
SV: Compiz Fusion
knåpa me ihop en video på mitt när jag satt i pilla lite.
dock la "kuben" av porecis innan, hmm
aja här e den iaf :P
http://www.youtube.com/watch?v=LW5ZvlIzveE
Bossieman
SV: Compiz Fusion
Inlägg av Bossieman »
invaderjohn skrev: knåpa me ihop en video på mitt när jag satt i pilla lite.
Hur får du menyerna (Gnome - Program - Platser -System) att bete sig som i videon?
invaderjohn
SV: Compiz Fusion
satte dom på zoom o sen drog ner hastigeheten som tusan ;D
