Här kan du läsa om vad sudo är: https://sv.m.wikipedia.org/wiki/SudoTjadden skrev:sudo vill ha mer info och vilken kod ska ges?
Lång uppstartstid på ett av två OS
- OS: Kubuntu
- Utgåva: 23.04 Lunar Lobster
Re: Lång uppstartstid på ett av två OS
Vad får du ut av "sudo mount"
~$ sudo mount
[sudo] password for arne:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1841720k,nr_inodes=460430,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=378800k,mode=755)
/dev/sda7 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd,nsroot=/)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct,nsroot=/)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event,nsroot=/)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids,nsroot=/)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio,nsroot=/)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory,nsroot=/)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices,nsroot=/)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb,nsroot=/)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer,nsroot=/)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio,nsroot=/)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,nsroot=/)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=378800k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
Skickar för nästa kommando separat!
~$ sudo mount
Kod:
sudo /lib/recovery-mode/options/dpkg
...utskriften får du klipp-o-klistra från skärmen istället och lägga in här sedan...
~$ sudo /lib/recovery-mode/options/dpkg
Läser cache
Läser paketlistor... Färdig
Bygger beroendeträd
Beräknar ändringarna
Vill du starta uppgraderingen?
36 paket kommer att uppgraderas.
Du måste hämta totalt 29,4 M. Denna hämtning kommer att ta ungefär 3
minuter med en 1 Mbit DSL-anslutning och ungefär 1 timme 8 minuter
med ett 56k-modem.
Fortsätt [jN] Detaljer [d]j
Hämtar
Läs:1 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 apturl amd64 0.5.2ubuntu11.1 [8 406 B]
Läs:2 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 apturl-common amd64 0.5.2ubuntu11.1 [10,9 kB]
Läs:3 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 bamfdaemon amd64 0.5.3~bzr0+16.04.20160523-0ubuntu1 [81,4 kB]
Läs:4 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 libbamf3-2 amd64 0.5.3~bzr0+16.04.20160523-0ubuntu1 [51,8 kB]
Läs:5 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 binutils amd64 2.26-8ubuntu2.1 [2 306 kB]
Läs:6 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs-bin amd64 1.28.2-1ubuntu1~16.04.1 [55,2 kB]
Läs:7 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs-backends amd64 1.28.2-1ubuntu1~16.04.1 [301 kB]
Läs:8 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs-fuse amd64 1.28.2-1ubuntu1~16.04.1 [30,3 kB]
Läs:9 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs amd64 1.28.2-1ubuntu1~16.04.1 [91,2 kB]
Läs:10 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs-daemons amd64 1.28.2-1ubuntu1~16.04.1 [112 kB]
Läs:11 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs-libs amd64 1.28.2-1ubuntu1~16.04.1 [110 kB]
Läs:12 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 gvfs-common all 1.28.2-1ubuntu1~16.04.1 [45,4 kB]
Läs:13 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 hunspell-sv all 1:5.1.0-1ubuntu2.2 [641 kB]
Läs:14 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 hunspell-sv-se all 1:5.1.0-1ubuntu2.2 [40,2 kB]
Läs:15 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 hyphen-sv all 1:5.1.0-1ubuntu2.2 [84,9 kB]
Kod:
Läser cache
Bygger beroendeträd
med ett 56k-modem.
Hämtar
Om du startar upp dina två ubuntuversioner i datorn
och i var och en,
var för sig,
öppnar en terminal och kopierar, klistrar in i terminalen,
följande kommando,
tryck Enter
och kan du sedan återge resultaten av dem till oss andra här i tråden?
uname -a
uname -m
- Osprey
Ser bra ut. Du har dock inget separat /home, det ligger alltså direkt under system-rooten ("/") och den är monterad med rw. Så det ska generellt sett inte vara några som helst problem för dig att skapa en fil eller något annat där. Mer än vanliga rättigheter och så alltså, men det är oftast inga problem när man är inne som root eller kör sudo...Tjadden skrev:~$ sudo mount
Ser också bra ut så långt jag kan se, hela utskriften är ju inte med, men jag antar att det gick bra...Tjadden skrev:~$ sudo /lib/recovery-mode/options/dpkg
Läser cache
Bygger beroendeträd
En möjlighet är att någon av uppdateringarna kan rätta till något som gjorde att det tog lång tid att starta upp. Tar det fortfarande lika "lång" tid?
Detta är väl egentligen överspelat nu, men jag vill bara nämna att man behöver root-åtkomst för att skriva i /home, så det första kommandot hade behövt vara något åt det här hållet:Osprey skrev:Man behöver bara ha med "namn" om man vill att den ska hamna i någons hemkatalog, jag ville göra det lite enklare nu och lägga den direkt i "/home" istället... (och "./" blir det automatiskt om man bara anger "fixa-trasiga.log")gruble skrev:Ska det inte varaOsprey skrev:Kod: Markera allt
sudo /lib/recovery-mode/options/dpkg > /home/fixa-trasiga.log 2>&1
eller ./fixa-trasiga.log Jag måste även trycka j och Enter 2 ggr i terminalen för att loggen ska slutföras (Zorin).Kod: Markera allt
sudo /lib/recovery-mode/options/dpkg > /home/namn/fixa-trasiga.log 2>&1
sudo sh -c '/lib/recovery-mode/options/dpkg > /home/fixa-trasiga.log 2>&1'
Gunnars kod löser skrivrättigheten till /home men i terminalen visas bara en blinkande cursor om man väljer att skriva till en log.
Öppnas fixa-trasiga.log med texteditor så ser man val och kommandon som ska göras, varefter filen ökar i storlek efter vaje åtgärd.
(- Endast som en liten sk. epilog om .log info - i väntan på svaren om uppstartstider)
När det gällde < sudo /lib/recovery-mode/options/dpkg > blev det en enorm lång text som hade tagitOsprey skrev:Ser också bra ut så långt jag kan se, hela utskriften är ju inte med, men jag antar att det gick bra...
all plats för en hel sida, alltså det är bara en tredjedel visad text.
Dessvärre tog det nästan en halv minut längre tid för att starta upp?
- Osprey
Då har vi alltså eliminerat och visat att det inte beror på grub, swap eller några paket som inte är korrekt installerade... allt sådant är ju fixat nu... Vidare har vi försökt kolla att de två starterna är identiska, dvs. att det inte är väldigt mycket mer som startas upp i den ena installationen och det var det inte förutom ett par processer med LVM...Tjadden skrev:Dessvärre tog det nästan en halv minut längre tid för att starta upp?
Kvar är då bara att ta redan på vad det verkligen är som tar tid och detta gör du som sagt var med systemd-analyze eller bootchart... försök åstadkomma en rapport med någon av dem och lägg in den här......
~$ systemd-analyzeOsprey skrev:Kvar är då bara att ta redan på vad det verkligen är som tar tid och detta gör du som sagt var med systemd-analyze eller bootchart... försök åstadkomma en rapport med någon av dem och lägg in den här......
Startup finished in 3.971s (kernel) + 3min 2.042s (userspace) = 3min 6.013s
sudo apt install pybootchartgui
~$ sudo apt install pybootchartgui
Läser paketlistor… Färdig
Bygger beroendeträd
Läser tillståndsinformation… Färdig
Föreslagna paket:
bootchart
Följande NYA paket kommer att installeras:
pybootchartgui
0 att uppgradera, 1 att nyinstallera, 0 att ta bort och 25 att inte uppgradera.
Behöver hämta 19,8 kB arkiv.
Efter denna åtgärd kommer ytterligare 91,1 kB utrymme användas på disken.
Läs:1 http://se.archive.ubuntu.com/ubuntu xenial/universe amd64 pybootchartgui amd64 0+r141-0ubuntu6 [19,8 kB]
Hämtade 19,8 kB på 0s (126 kB/s)
Väljer tidigare ej valt paket pybootchartgui.
(Läser databasen ... 214485 filer och kataloger installerade.)
Förbereder att packa upp .../pybootchartgui_0+r141-0ubuntu6_amd64.deb ...
Packar upp pybootchartgui (0+r141-0ubuntu6) ...
Ställer in pybootchartgui (0+r141-0ubuntu6) ...
Tjadden: Har du möjlighet att boota upp det OS som tar lång tid på sig och öppna ett Terminalfönster och skrivaOsprey skrev:Vidare har vi försökt kolla att de två starterna är identiska, dvs. att det inte är väldigt mycket mer som startas upp i den ena installationen och det var det inte förutom ett par processer med LVM...
less /etc/fstab
# /etc/fstab: static file system information.Nemo skrev:Kod:
less /etc/fstab
Kopiera hela den text du får fram och lägg in den i denna tråd. Vill få det bekräftat att du inte kör med LVM, vilket innehållet i fstab borde ge svar på.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda11 during installation
UUID=67e21880-5257-45a6-916e-666c2a566d02 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda10 during installation
UUID=1f2eb097-088d-4f62-9aa3-97709b254b21 none swap sw 0 0
# swap was on /dev/sda6 during installation
UUID=d30a180d-df2b-46b7-ae62-3145d48bc103 none swap sw 0 0
# swap was on /dev/sda8 during installation
UUID=344fb96b-f9ff-4af2-8eb2-ff7762e5a243 none swap sw 0 0
Jag har kört den här koden vid ett tidigare tillfälle och detta error fanns inte med?
Det ser helt ok ut. Du använder inte LVM i din maskin, vilket gör att vi kan utesluta det som möjlig orsak till dina problem.Tjadden skrev:Jag har kört den här koden vid ett tidigare tillfälle och detta error fanns inte med?
Jag ser att du nu har 3 Swap partitioner på din maskin (sda6, sda8 och sda10).
Vad gäller raden du hänvisar till för sda11, hade du tidigare exakt samma sak i sda9, vilket framgår i följande inlägg.
Vad raden gör är att om den misslyckas med att montera root, då gör den en ny montering fast utan skrivrättigheter.
Jag ser att du nu har 3 Swap partitioner på din maskin (sda6, sda8 och sda10).Nemo skrev:Jag ser att du nu har 3 Swap partitioner på din maskin (sda6, sda8 och sda10).
Detta är en gammal historia som inte är aktuellt idag!
- OS: Kubuntu
Hur ser partitionerna ut i Gparted? Lägg in en bild på hur det ser ut. Har du tagit bort partitioner utan att uppdatera filen /etc/fstab? Det skulle i så fall kanske förklara varför uppstarten tar tid.Tjadden skrev:Detta är en gammal historia som inte är aktuellt idag!
Vi kan ju börja med att U1 fungerar perfekt och logiskt sätt borde U3 också fungera lika bra, men den har ju den långa uppstarten.HakanS skrev:Hur ser partitionerna ut i Gparted? Lägg in en bild på hur det ser ut. Har du tagit bort partitioner utan att uppdatera filen /etc/fstab? Det skulle i så fall kanske förklara varför uppstarten tar tid.
Vad jag och någon annan har funderat på, om Win 10 på plats 2 i Grub-menyn påverkar U3 av någon anledning.
Saken är den efter att jag var tvungen att ominstallera Win 10 så uppstod detta fel på U3!
Mitt minne säger mig att jag fick en order att ändra en detalj på Boot, som jag också sparade men fråga mig inte vad det var jag ändrade på, för det minns jag inte? Sparandet var ju för att ändringen skulle bestå!
- OS: Kubuntu
Nej, eftersom det är två olika operativsystemsinstallationer, så finns det inget som säger att båda ska fungera lika bra.Tjadden skrev:Vi kan ju börja med att U1 fungerar perfekt och logiskt sätt borde U3 också fungera lika bra
Om du svarar på mina frågor och gör det jag ber dig i mitt föregående inlägg så kan problemet kanska lösas.
Kan direkt säga att U3 fick ligga som U1 då fungerade U3 mycket bra!HakanS skrev:Nej, eftersom det är två olika operativsystemsinstallationer, så finns det inget som säger att båda ska fungera lika bra.
U1 som U3 fick problem med uppstarten! Lösa det problemet på GParted tror jag inte på.
Möjligt om Win 10 avinstallerades så skulle det bli bra. Tyvärr så har jag ett program på Win. som inte går att installera på Linux som gör att jag tvingas behålla Windows.
- OS: Kubuntu
Eftersom du, utan att tala om det för oss andra, håller på att ändra i partitionerna. Tar bort partitioner, installera om och gör nyinstallationer, så är det omöjligt att hjälpa till att lösa dina problem.
- OS: Debian
Det här ser inte ut som tidigare, men varför har du så många oallokerade områden?
