Posta din .conkyrc
- Utgåva: 10.04 Lucid LTS
SV: Posta din .conkyrc
jaha... man installerar conky på gamla burken, men jag tror att jag fick lite errors... bifogar...
Såhär ser min weather.xslt-fil ut:Pinky skrev: MIna sökvägar stämmer.
Fast det hänvisas i scriptet till weather.xslt vad har du i din sån?
This XSLT is used to translate an XML response from the weather.com
XML API.
You can format this file to your liking. Two things you may feel
like doing:
1) Modify the layout of the fields or static text already defined
2) Add other fields from the XML response file that aren't referenced in this
XSLT. You can grab a full list by just doing a:
wget "http://xoap.weather.com/weather/local/$LOCID?cc=*&unit=$UNITS"
(change $LOCID and $UNITS to suit your needs)
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0" >
<xsl:output method="text" disable-output-escaping="yes"/>
<xsl:template match="weather">
<xsl:apply-templates select="cc"/>
<xsl:apply-templates select="dayf/day[@d='1']"/>
</xsl:template>
<xsl:template match="cc">
<xsl:text> Temperature: </xsl:text><xsl:value-of select="tmp"/><xsl:value-of select="/weather/head/ut"/>
<xsl:if test="tmp != flik">
<xsl:text>
Feels Like: </xsl:text><xsl:value-of select="flik"/><xsl:value-of select="/weather/head/ut"/>
</xsl:if>
<xsl:text>
Conditions: </xsl:text><xsl:value-of select="t"/>
<xsl:text>
Wind: </xsl:text>
<xsl:choose>
<xsl:when test="wind/s = 'calm'"><xsl:text>0</xsl:text></xsl:when>
<xsl:otherwise><xsl:value-of select="wind/s"/></xsl:otherwise>
</xsl:choose>
<xsl:value-of select="/weather/head/us"/>
<xsl:choose>
<xsl:when test="wind/s = 'calm'"><xsl:text>(0mph)</xsl:text></xsl:when>
<xsl:otherwise><xsl:text> (</xsl:text><xsl:value-of select="round(wind/s * 0.6214)"/><xsl:text>mph)</xsl:text></xsl:otherwise>
</xsl:choose>
<xsl:text> (</xsl:text><xsl:value-of select="wind/t"/>
<xsl:text>)</xsl:text>
</xsl:template>
<xsl:template match="dayf/day[@d='1']">
<xsl:text>
Tomorrow: </xsl:text><xsl:value-of select="low"/><xsl:value-of select="/weather/head/ut"/>
<xsl:text> to </xsl:text><xsl:value-of select="hi"/><xsl:value-of select="/weather/head/ut"/>
<xsl:text>, </xsl:text><xsl:value-of select="part[@p='d']/t"/>
<xsl:text>
</xsl:text><xsl:value-of select="/weather/swa/a/t"/>
<xsl:text>
</xsl:text>
</xsl:template>
</xsl:stylesheet>
Jaha, där var nog mitt problem då.. Den ska ligga i samma mapp som scriptet antar jag? Jag trodde att det skulle vara det andra väderscriptets stoffepojken hänvisade till... Då ska vi prova igen
Yay! Nu funkar det! Var sjutton hittade du din weather.xslt??
Bra fråga? På nån sida när jag googlade.
- Jag hatar Snigel
nu syns inte mina ikoner på skrivbodet men stänger jag av conky kommer de tillbaka, o de försvinner även om de är på andra sidan skrivbordet!
de finns iof påp skrivbordet med de blir osynliga tar man muspekarn över så blinkar den till i nånna sekunder
Hund skrev:Jag råkade ut för samma sak nu och löste det!DeepThought skrev: Har haft precis samma problem med conky (det är därför jag kör SuperKaramba). Fick iallafall samma symptom: bakgrundsbilden syntes inte igenom och texten uppdaterades inte, utan skrev istället över. Tyvärr har jag ingen lösning, men jag tror det har med dubbelbuffring att göra
Öppna xorg.conf (/etc/X11/xorg.conf) och leta reda på delen Section "Module"
Där under lägger man bara till:
Starta sedan bara om X.Kod: Markera allt
Load "dbe"
Du menar dom nedersta raderna?jabbadoo skrev: jaha... man installerar conky på gamla burken, men jag tror att jag fick lite errors... bifogar...
- Jag hatar Snigel
Load "dbe"
Load "dbe"
JA!Hund skrev:Du menar dom nedersta raderna?jabbadoo skrev: jaha... man installerar conky på gamla burken, men jag tror att jag fick lite errors... bifogar...
Nu funkar det, men jag får annan test längst ner... vet inte omdet är error, men...Jag hatar Snigel skrev: Öppna xorg.conf (/etc/X11/xorg.conf) och leta reda på delen Section "Module"
Load "dbe"
Bifogar...
Skulle jag kunna få se din Conky-konfiguration? Skulle tro du har med att lite information visas i din Conky bara.jabbadoo skrev:JA!Hund skrev:Du menar dom nedersta raderna?jabbadoo skrev: jaha... man installerar conky på gamla burken, men jag tror att jag fick lite errors... bifogar...
Load "dbe"
Bifogar...
[img width=133 height=452]http://fc01.deviantart.com/fs19/i/2007/ ... ebupof.png[/img]
Tanka: http://ebupof.deviantart.com/art/My-Con ... 4-62287028
Mindre och bantad version av min förra.
- Dimi
Jag försöker få fram temperaturen av hårddiskarna och skriver in följande:
HDDtemp: ${hddtemp /dev/hda1}
men jag får inte upp någon temperatur, Det står enbart N/A där tempen skulle stått. Vad gör jag för fel?
Samma sak för cpu tempen:
CPUTemp: ${acpitemp}
här står bara temperaturen 0.
- Beakon
Finns det något sätt att formatera texten på bättre sätt ?
Vill ha en config som är ett par rader hög och ligger över hela skärmens bredd.
Problemet är bara att flera värden ändrar längd och då flyttar hela raden i sidled.
Processlistorna (top) gör ju inte detta utan dom fälten är ju fasta i sin bredd oavsett värdet i dom. däremot t.ex. fs_used skiftar ju i bredd beroende på värdet. Går det att komma runt ??
Linux - Bringing back the joy of computing
Nån som kan förklara till mig hur jag får min conky att hålla sig till bakgrunden?? Den är nämligen ovanför alla fönster nu..:S (vilket script är det frågan om?)
Hur ser din konfiguration ut? Filen finner du här: ~/.conkyrcmathoglu skrev: Nån som kan förklara till mig hur jag får min conky att hålla sig till bakgrunden?? Den är nämligen ovanför alla fönster nu..:S (vilket script är det frågan om?)
# set to yes if you want Conky to be forked in the background
background no
cpu_avg_samples 2
net_avg_samples 2
out_to_console no
# X font when Xft is disabled, you can pick one with program xfontsel
#font 7x12
#font 6x10
#font 7x13
#font 8x13
#font 7x12
#font *mintsmild.se*
#font -*-*-*-*-*-*-34-*-*-*-*-*-*-*
#font -artwiz-snap-normal-r-normal-*-*-100-*-*-p-*-iso8859-1
# Use Xft?
use_xft yes
# Xft font when Xft is enabled
xftfont Bitstream Vera Sans Mono:size=8
own_window_transparent no
#own_window_colour hotpink
# Text alpha when using Xft
xftalpha 0.8
on_bottom yes
# mail spool
mail_spool $MAIL
# Update interval in seconds
update_interval 1
# Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_transparent yes
own_window_hints undecorated,below,skip_taskbar
own_window_type override
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# Minimum size of text area
minimum_size 260 5
maximum_width 260
# Draw shades?
draw_shades no
# Draw outlines?
draw_outline no
# Draw borders around text
draw_borders no
# Stippled borders?
stippled_borders no
# border margins
border_margin 4
# border width
border_width 1
# Default colors and also border colors
default_color white
default_shade_color white
default_outline_color white
# Text alignment, other possible values are commented
#alignment top_left
#minimum_size 10 10
gap_x 15
gap_y 70
alignment top_right
#alignment bottom_left
#alignment bottom_right
# Gap between borders of screen and text
# Add spaces to keep things from moving about? This only affects certain objects.
use_spacer no
# Subtract file system buffers from used memory?
no_buffers yes
# set to yes if you want all text to be in uppercase
uppercase no
# none, xmms, bmp, audacious, infopipe (default is none)
xmms_player bmp
# boinc (seti) dir
# seti_dir /opt/seti
# Possible variables to be used:
# Variable Arguments Description
# acpiacadapter ACPI ac adapter state.
# acpifan ACPI fan state
# acpitemp ACPI temperature.
# adt746xcpu CPU temperature from therm_adt746x
# adt746xfan Fan speed from therm_adt746x
# battery (num) Remaining capasity in ACPI or APM
# battery. ACPI battery number can be
# given as argument (default is BAT0).
# buffers Amount of memory buffered
# cached Amount of memory cached
# color (color) Change drawing color to color
# cpu CPU usage in percents
# cpubar (height) Bar that shows CPU usage, height is
# bar's height in pixels
# downspeed net Download speed in kilobytes
# downspeedf net Download speed in kilobytes with one
# decimal
# exec shell command Executes a shell command and displays
# the output in torsmo. warning: this
# takes a lot more resources than other
# variables. I'd recommend coding wanted
# behaviour in C and posting a patch :-).
# execi interval, shell Same as exec but with specific interval.
# command Interval can't be less than
# update_interval in configuration.
# fs_bar (height), (fs) Bar that shows how much space is used on
# a file system. height is the height in
# pixels. fs is any file on that file
# system.
# fs_free (fs) Free space on a file system available
# for users.
# fs_free_perc (fs) Free percentage of space on a file
# system available for users.
# fs_size (fs) File system size
# fs_used (fs) File system used space
# hr (height) Horizontal line, height is the height in
# pixels
# i2c (dev), type, n I2C sensor from sysfs (Linux 2.6). dev
# may be omitted if you have only one I2C
# device. type is either in (or vol)
# meaning voltage, fan meaning fan or temp
# meaning temperature. n is number of the
# sensor. See /sys/bus/i2c/devices/ on
# your local computer.
# kernel Kernel version
own_window yes
background yes
double_buffer yes
# fiddle with window
use_spacer yes
use_xft yes
xftfont dejavu Sans:size=7
update_interval 0.75
minimum_size 200 5
# Draw shades?
draw_shades no
# Text stuff
draw_outline no # amplifies text if yes
draw_borders no
uppercase no # set to yes if you want all text to be in uppercase
# Stippled borders?
stippled_borders 3
# border margins
border_margin 9
# border width
border_width 10
own_window_colour brown
alignment top_left
#alignment top_right
gap_x 10
gap_y 85
# stuff after 'TEXT' will be formatted on screen
TEXT
${color #EE041F}CPU:$color ${color #8A8A8A}$cpu%$color
${color #FFFFFF}$cpubar
${color #FFFFFF}${cpugraph 8A8A8A FFFFFF}
${color #EE041F}RAM:$color ${color #8A8A8A}$memperc%$color ${color #FFFFFF}${membar 6}${color}
${color #EE041F}Swap:$color ${color #8A8A8A}$swapperc%$color ${color #FFFFFF}${swapbar 6}$color
${color #EE041F}root:$color ${color #8A8A8A}${fs_free_perc /}% ${fs_free /} ledigt$color
${color #FFFFFF}${fs_bar 6 /}$color
${color #EE041F}home:$color ${color #8A8A8A}${fs_free_perc /home}% ${fs_free /home} ledigt$color
${color #FFFFFF}${fs_bar 6 /home}$color
${color #EE041F}eth0
${color #EE041F}DOWN: ${color #8A8A8A}${downspeed eth0} k/s
${color #EE041F}UP: ${color #8A8A8A}${upspeed eth0} k/s
${color #FFFFFF}${downspeedgraph eth0 8A8A8A FFFFFF}
${color #FFFFFF}${upspeedgraph eth0 8A8A8A FFFFFF}
${color #EE041F}TOTAL: ${color #8A8A8A}${totaldown eth0}
${color #EE041F}eth1
${color #EE041F}DOWN: ${color #8A8A8A}${downspeed eth1} k/s
${color #EE041F}UP: ${color #8A8A8A}${upspeed eth1} k/s
${color #FFFFFF}${downspeedgraph eth1 8A8A8A FFFFFF}
${color #FFFFFF}${upspeedgraph eth1 8A8A8A FFFFFF}
${color #EE041F}TOTAL: ${color #8A8A8A}${totaldown eth1}
Har kikat men kan inte se något? Du hade en väldigt lång och stökig config dock.
Tror du hade någon dubeltt där med.
ok! Nått som kanske kan bidra till felet?
Jag är ingen expert men jag jämförde ditt och mitt lite och det första jag såg som var annorlunda var lite om fönstret. Så här har jag:mathoglu skrev: ok! Nått som kanske kan bidra till felet?
own_window yes
own_window_type normal
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
- Ulsak
ha ha, jag tycker att det här var kul !
men jag fick två outputs som inte hänger kvar efter att redigerat i .conkyrc
dom till vänster...
dom till vänster...
