Konservburk
Inlägg: 5919 Blev medlem: 07 apr 2007, 22:28
Inlägg
av Konservburk » 13 okt 2008, 11:28
Jag ser inget fel i ~/.talsynes/.
Nu har jag lagt in lite kod så att den visar exakt vilket kommando den kör vid själva uppläsningen, så att vi sedan kan testa det kommandot löst:
#!/bin/sh
# r3-test
case "$-" in *i*) return ;; esac
export LC_ALL=C
exec 2>&-
APP="Talsyntes"
DIR=~/".talsyntes"
SCRIPT="$DIR/talsyntes.sh"
mkdir -p "$DIR/data" "$DIR/voices"
test "x$SCRIPT" != "x$0" &&
cp -f "$0" "$SCRIPT" 2>&- &&
exec "$SCRIPT" "$@"
XDIALOG="Xdialog --wmclass '$APP' --cancel-label Avbryt --no-tags --stdout"
find -L "$DIR" -maxdepth 1 -name voice -type l -exec rm {} \;
test -h "$DIR/voice" || test "$1" = install || set voice
ls "$DIR"/voices/[a-z][a-z][1-9]:* >/dev/null 2>&- &&
test -x "$SCRIPT" &&
test -x "$DIR/mbrola" ||
set install
cd "$DIR"
case "$1" in
stop)
pkill -P $(pgrep -d, "${SCRIPT##*/}") mplayer
pause)
find "$DIR" -name mplayer.\*.fifo -type p -exec sh -c 'echo pause >{}' \;
start)
"$SCRIPT" stop
find "$DIR" -name mplayer.\*.fifo -type p -exec rm -f {} \;
FIFO="$DIR/mplayer.$$.fifo"
trap 'rm -f "$FIFO"' EXIT
test -p "$FIFO" || mkfifo "$FIFO"
if voice=$(ls voices/"$2":* 2>&-)
then shift
else voice="$(readlink voice)"
fi
voice="${voice#voices/}"
speed="$2"
freq="$3"
volume="$4"
rate="$5"
test -z "$speed" && test -f speed &&
speed=$(awk '{printf("%f",exp(0.01*log(1/5)*$1))}' <speed)
test -z "$freq" && test -f freq &&
freq=$(awk '{printf("%f",exp(-0.01*log(1/5)*$1))}' <freq)
test -z "$volume" && test -f volume &&
volume=$(awk '{printf("%f",exp(-0.01*log(1/5)*$1))}' <volume)
test -z "$rate" && test -f rate &&
rate=$(awk '{printf("%f",16000*exp(-0.01*log(1/3)*$1))}' <rate)
echo xclip -o \|
echo espeak -v mb-"${voice%:*}" \|
echo "$DIR/mbrola" -e \
-t "${speed:-1}" \
-f "${freq:-1}" \
-v "${volume:-1}" \
-l "${rate:-16000}" \
"$DIR/voices/$voice" - -.wav \|
echo mplayer -input file="$FIFO" -really-quiet -demuxer audio -
xclip -o |
espeak -v mb-"${voice%:*}" |
"$DIR/mbrola" -e \
-t "${speed:-1}" \
-f "${freq:-1}" \
-v "${volume:-1}" \
"$DIR/voices/$voice" - -.wav |
reset)
case "$2" in
'') rm -f speed freq volume rate ;;
speed|freq|volume|rate) rm -f "$2" ;;
esac
adjust)
case "$2" in
test -f speed && speed=$(cat speed) || speed=0
test -f freq && freq=$(cat freq) || freq=0
test -f rate && rate=$(cat rate) || rate=0
set -- $(
$XDIALOG --title "$APP" --separator " " \
--3rangesbox "Röstparametrar" 22 60 \
"Uppläsningshastighet" -100 100 "$speed" \
"Röstläge" -100 100 "$freq" \
"Rösttäthet" -100 100 "$rate"
if test $# -eq 3
then
echo "$1" >speed
echo "$2" >freq
echo "$3" >rate
fi
exit
speed) TITLE="Uppläsningshastighet" ;;
freq) TITLE="Röstläge" ;;
volume) TITLE="Uppläsningsvolym" ;;
rate) TITLE="Rösttäthet" ;;
*) exit ;;
esac
test -f "$2" && value=$(cat "$2") || value=0
case "$3" in
value=$(
$XDIALOG --title "$APP" --rangebox "$TITLE" 10 60 -100 100 "$value"
test -n "$value" &&
echo "$value" >"$2"
echo "$3" |
awk -vvalue="$value" '{
if($1) value+=$1
else value=0
if(value>100) value=100
if(value<-100) value=-100
print(value)
}' >"$2"
esac
voice)
case "$2" in
voice=$(
eval $XDIALOG --title "'$APP'" --no-close --no-cancel \
--radiolist "'Välj röst'" 20 60 0 $(
ls voices/[a-z][a-z][1-9]:* 2>&- |
while read voice
do test "x$voice" = "x$(readlink voice)" &&
radiobox=on ||
radiobox=off
printf "%s " "'$voice'" "'${voice#voices/}'" "$radiobox"
done
voice=$(ls "voices/$2":* 2>&-)
esac
test -n "$voice" &&
ln -sf "$voice" voice
install)
URL="http://tcts.fpms.ac.be/synthesis/mbrola"
TMP=$(mktemp)
trap 'rm -f "$TMP"' EXIT
wget -qO- "$URL"/mbrcopybin.html |
sed -n '
s|.*"\(bin/[^"]*.zip\)"[^>]*>[^<]*LINUX i386.*|\1 (0.3Mb)|p
s|.*"\(dba/[^/]*/[^"]*\)"[^>]*>\([^:]*:\s*[^<]*\).*|\1\t\2|p
' >"$TMP"
cd "$DIR"
voices=$(
cd /usr/share/espeak-data/voices/mb &&
echo mb-[a-z][a-z][1-9] |
sed 's/mb-//g;s/\(.\)\s\(.\)/\1|\2/g'
voices=$(
eval $XDIALOG --title "'$APP: Installation'" --separator "'|'" \
--checklist "'Välj språk'" 20 60 0 $(
grep -E "/($voices)/" <"$TMP" |
while read file voice
do case "$voice" in
sw*|us*|en*) checkbox=on ;;
*) checkbox=off ;;
esac
printf "%s " "${voice%:*}" "'$voice'" "$checkbox"
done
test -z "$voices" && exit
rm -f voices/[a-z][a-z][1-9]:* 2>&-
cd data
grep -E "(^bin|/$voices/)" <"$TMP" |
awk '{
size[NR]=size[NR-1]+substr($NF,2,length($NF)-4)
$NF=""
voice[NR]=$0
} END {
for(i=1; i<=NR; i++) {
print(100*size[i]/size[NR],voice[i])
while read progress file voice
do test -f "${file##*/}" ||
wget -q "$URL/$file" 2>&1
if test -z "$voice"
then
unzip -p "${file##*/}" mbrola-linux-i386 >"$DIR"/mbrola
chmod +x "$DIR"/mbrola
else
unzip -p "${file##*/}" "${voice%%:*}" >"$DIR/voices/$voice" 2>&- ||
unzip -p "${file##*/}" "${voice%%:*}/${voice%%:*}" \
fi
echo $progress
done |
$XDIALOG --title "$APP: Installation" \
--no-close --gauge "Hämtar Röster..." 10 60
bind_key() {
case "$1" in
metacity)
KEY="/apps/metacity/global_keybindings"
CMD="/apps/metacity/keybinding_commands"
PREFIX="run_command_"
SUFFIX=""
compiz)
KEY="/apps/compiz/general/allscreens/options"
CMD="/apps/compiz/general/allscreens/options"
PREFIX="run_command"
SUFFIX="_key"
esac
gconftool-2 -a "$KEY" |
awk '$1~/^'"$PREFIX"'[0-9]+'"$SUFFIX"'$/ && $3~/^'"$2"'$/{print($1)}' |
while read binding
do gconftool-2 -u "$KEY/$binding"
done
ID=$(
sed -n "s/^\s*$PREFIX\([0-9]\+\)$SUFFIX\s*=\s*/\1\t/p" |
sort -n |
awk '{if($1-prev>1)exit;prev=$1}END{print(prev+1)}'
gconftool-2 \
-s -t str "$KEY/$PREFIX${ID:-1}$SUFFIX" "$2" \
-s -t str "$CMD/${PREFIX#run_}${ID:-1}" "$3"
for wm in metacity compiz
do bind_key "$wm" "F1" "$SCRIPT stop"
bind_key "$wm" "F2" "$SCRIPT pause"
bind_key "$wm" "F3" "$SCRIPT start"
bind_key "$wm" "F4" "$SCRIPT start 0.5"
bind_key "$wm" "F5" "$SCRIPT start sw1 0.5"
bind_key "$wm" "F6" "$SCRIPT speed 0"
bind_key "$wm" "F7" "$SCRIPT speed -10"
bind_key "$wm" "F8" "$SCRIPT speed +10"
bind_key "$wm" "F9" "$SCRIPT adjust"
bind_key "$wm" "F10" "$SCRIPT voice"
bind_key "$wm" "F11" "$SCRIPT voice sw1"
bind_key "$wm" "F12" "$SCRIPT voice en1"
done
$XDIALOG --title "$APP" --msgbox "$APP installerad" 10 60
exec "$SCRIPT" voice
speed|freq|volume|rate) exec "$SCRIPT" adjust "$@" ;;
*) exec "$SCRIPT" start "$@" ;;
esac
Hans Linde
Inlägg: 3375 Blev medlem: 06 sep 2008, 07:46
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 11:36
hans@hans-ubuntu:~$ ~/bin/talsyntes.sh start
xclip -o |
espeak -v mb-sw1 |
/home/hans/.talsyntes/mbrola -e -t 1.000000 -f 1.000000 -v 1 -l 16000.000000 /home/hans/.talsyntes/voices/sw1: Swedish Male - -.wav |
mplayer -input file=/home/hans/.talsyntes/mplayer.25579.fifo -really-quiet -demuxer audio -
hans@hans-ubuntu:~$
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 11:40
Hans Linde skrev: hans@hans-ubuntu:~$ ~/bin/talsyntes.sh start
xclip -o |
espeak -v mb-sw1 |
hans@hans-ubuntu:~$
Då kör du löst från en terminal:
mkfifo "/home/hans/.talsyntes/mplayer.$$.fifo"
espeak -v mb-sw1 |
"/home/hans/.talsyntes/mbrola" -e -t 1.000000 -f 1.000000 -v 1 -l 16000.000000 "/home/hans/.talsyntes/voices/sw1: Swedish Male - -.wav" |
mplayer -input file="/home/hans/.talsyntes/mplayer.$$.fifo" -really-quiet -demuxer audio -
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 11:43
hans@hans-ubuntu:~$ mkfifo "/home/hans/.talsyntes/mplayer.$$.fifo"
hans@hans-ubuntu:~$ espeak -v mb-sw1 |
FATAL ERROR : cannot find file /home/hans/.talsyntes/voices/sw1: Swedish Male - -.wav !
mplayer: could not connect to socket
mplayer: No such file or directory
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 11:44
Hans Linde skrev: FATAL ERROR : cannot find file /home/hans/.talsyntes/voices/sw1: Swedish Male - -.wav !
Klippa-klistra-fel... vi testar en gång till:
rm -f "/home/hans/.talsyntes/mplayer.$$.fifo"
espeak -v mb-sw1 |
"/home/hans/.talsyntes/mbrola" -e -t 1.000000 -f 1.000000 -v 1 -l 16000.000000 "/home/hans/.talsyntes/voices/sw1: Swedish Male" - -.wav |
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 11:49
hans@hans-ubuntu:~$ rm -f "/home/hans/.talsyntes/mplayer.$$.fifo"
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 11:59
Hans Linde skrev: hans@hans-ubuntu:~$ rm -f "/home/hans/.talsyntes/mplayer.$$.fifo"
Fler klippa-klistra-fel ser jag nu. Vi glömde ju att skicka något som ska läsas upp till espeak!
echo något som ska läsas upp |
espeak -v mb-sw1 |
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 12:04
Klockrent: "något som ska läsas upp"
hans@hans-ubuntu:~$ echo något som ska läsas upp |
> espeak -v mb-sw1 |
hans@hans-ubuntu:~$
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 12:11
Hans Linde skrev: Klockrent: "något som ska läsas upp"
Enda problemet nu är ju att vi fortfarande inte vet varför ~/bin/talsyntes.sh inte vill läsa upp något. Nu gjorde vi ju på exakt samma sätt som den gör. Eller nästan... vi skickade inte texten från utklippet.
Funkar det verkligen inte med
~/bin/talsyntes.sh start om du har något vettigt i utklippet?
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 12:17
Nej tyvärr, inget ljud.
och det här maskerat....ej ctlC....det har vi inte gjort tidigare....med så funkar det andra programmmen, men det är sämre.
" Enda problemet nu är ju att vi fortfarande inte vet varför ~/bin/talsyntes.sh inte vill läsa upp något. Nu gjorde vi ju på exakt samma sätt som den gör. Eller nästan... vi skickade inte texten från utklippet."
xclip -o |
espeak -v mb-sw1 |
mplayer -input file=/home/hans/.talsyntes/mplayer.7428.fifo -really-quiet -demuxer audio -
hans@hans-ubuntu:~$
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 12:28
Blir det bättre om du byter ut raden:
xclip -o |
mot
Det är någonstans runt rad 50.
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 12:39
De tala fint nu.
Jag bytte
echo xclip -o |
till
Sedan körde jag:
espeak -v mb-sw1 |
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 12:50
Du skulle byta raden i filen ~/bin/talsyntes.sh och sedan köra:
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 12:53
Det var den filen jag redigerad,
men det här är tyst.
espeak -v mb-sw1 |
mplayer -input file=/home/hans/.talsyntes/mplayer.6473.fifo -really-quiet -demuxer audio -
hans@hans-ubuntu:~$
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 12:56
Något knivigt , för en gång skull.
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 13:04
Hans Linde skrev: Det var den filen jag redigerad,
espeak -v mb-sw1 |
hans@hans-ubuntu:~$
Nu har jag skalat bort precis allting som inte har med själva uppspelningen att göra:
#!/bin/sh
DIR=~/".talsyntes"
cd "$DIR"
xclip -o |
"$DIR/mbrola" -e \
mplayer -really-quiet -demuxer audio -
Om det här inte funkar så har vi hittat var felet ligger. Om det däremot funkar så får vi utvidga tills vi hittar exakt var det går åt skogen. Alltid lika spännande med felsöknig.
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 13:15
Då får jag säga Grattis.
Det är tyst. Följande är market:
"Om det här inte funkar så har vi hittat var felet ligger. Om det däremot funkar så får vi utvidga tills vi hittar exakt var det går åt skogen. Alltid lika spännande med felsöknig."
/home/hans/bin/talsyntes.sh: 10: xclip: not found
hans@hans-ubuntu:~$
Konservburk
Inlägg
av Konservburk » 13 okt 2008, 13:16
Hans Linde skrev: /home/hans/bin/talsyntes.sh: 10: xclip: not found
Men se där... du verkar ju sakna
xclip på den datorn.
Hans Linde
OS: Crunchbang
Inlägg
av Hans Linde » 13 okt 2008, 13:20
och??
eller va bra??
ja ä lia klok
