Talsyntes:____"För Folk I Tiden"
Hans Linde
OS: Crunchbang
Re: Talsyntes/Festival/Scaletempo/Ubuntu-AMD64
Inlägg av Hans Linde »
Lista enl önskemål:
hans@hl:~$ gconftool-2 -a /apps/metacity/global_keybindings
switch_panels_backward = disabled
switch_to_workspace_2 = disabled
switch_to_workspace_3 = disabled
switch_to_workspace_4 = disabled
run_command_10 = disabled
switch_to_workspace_5 = disabled
run_command_11 = disabled
switch_to_workspace_6 = disabled
switch_to_workspace_left = <Control><Alt>Left
run_command_12 = disabled
switch_to_workspace_7 = disabled
switch_to_workspace_8 = disabled
cycle_windows = <Alt>Escape
switch_to_workspace_9 = disabled
switch_to_workspace_right = <Control><Alt>Right
cycle_panels_backward = <Control><Alt>Escape
switch_windows = <Alt>Tab
run_command_window_screenshot = <Alt>Print
cycle_group = disabled
switch_to_workspace_up = <Control><Alt>Up
run_command_screenshot = Print
run_command_1 = disabled
run_command_2 = F12
run_command_3 = disabled
cycle_windows_backward = disabled
switch_to_workspace_down = <Control><Alt>Down
run_command_4 = disabled
run_command_5 = disabled
switch_to_workspace_10 = disabled
run_command_6 = disabled
switch_group = <Alt>F6
cycle_group_backward = disabled
switch_to_workspace_11 = disabled
run_command_7 = disabled
switch_to_workspace_12 = disabled
run_command_8 = disabled
panel_main_menu = <Alt>F1
run_command_9 = disabled
switch_panels = <Control><Alt>Tab
switch_group_backward = disabled
cycle_panels = <Control><Alt>Escape
switch_windows_backward = <Shift><Alt>Tab
show_desktop = <Control><Alt>d
panel_run_dialog = <Alt>F2
run_command_terminal = disabled
switch_to_workspace_1 = disabled
hans@hl:~$ gconftool-2 -a /apps/metacity/keybinding_commands
Hans Linde
OS: Crunchbang
Aaah det vanliga felet från min sida.
Nu trycker jag "enter" igen, och följande listas:
command_7 = /home/hans/bin/mbrola_start.sh us3 0.3 0.6
command1 =
command_8 = /home/hans/bin/mbrola_start.sh us3
command_screenshot = gnome-screenshot
command_9 = /home/hans/bin/mbrola_start.sh us3 1.4 1.3
command_10 = /home/hans/bin/mbrola_start.sh us3 0.4 0.7
command_11 = /home/hans/bin/mbrola_start.sh us3 0.6
command_12 = /home/hans/bin/mbrola_start.sh us3 0.4 1.1
command_1 = /home/hans/bin/mbrola_start.sh
command_2 = /home/hans/.talsyntes/talsyntes.sh voice en1
command_3 = /home/hans/bin/mbrola_start.sh sw1 0.5
command_4 = /home/hans/bin/mbrola_start.sh sw2 1.0 1.5
command_5 = /home/hans/bin/mbrola_start.sh en1
command_6 = /home/hans/bin/mbrola_start.sh us1
command_window_screenshot = gnome-screenshot --window
hans@hl:~$
Konservburk
Inlägg av Konservburk »
Av någon anledning verkar bara bindingen till F12 ha tagit. Här är ett första försök till en buggfix...
#!/bin/sh
# r2
case "$-" in *i*) return ;; esac
export LC_ALL=C
exec 2>&-
APP="Talsyntes"
DIR=~/".talsyntes"
SCRIPT="$DIR/talsyntes.sh"
mkdir -p "$DIR/data" "$DIR/voices"
test "x$SCRIPT" != "x$0" &&
cp -f "$0" "$SCRIPT" 2>&- &&
exec "$SCRIPT" "$@"
XDIALOG="Xdialog --wmclass '$APP' --cancel-label Avbryt --no-tags --stdout"
find -L "$DIR" -maxdepth 1 -name voice -type l -exec rm {} \;
test -h "$DIR/voice" || test "$1" = install || set voice
ls "$DIR"/voices/[a-z][a-z][1-9]:* >/dev/null 2>&- &&
test -x "$SCRIPT" &&
test -x "$DIR/mbrola" ||
set install
cd "$DIR"
case "$1" in
stop)
   pkill -P $(pgrep -d, "${SCRIPT##*/}") mplayer
pause)
   find "$DIR" -name mplayer.\*.fifo -type p -exec sh -c 'echo pause >{}' \;
start)
   "$SCRIPT" stop
   find "$DIR" -name mplayer.\*.fifo -type p -exec rm -f {} \;
   FIFO="$DIR/mplayer.$$.fifo"
   trap 'rm -f "$FIFO"' EXIT
   test -p "$FIFO" || mkfifo "$FIFO"
   if voice=$(ls voices/"$2":* 2>&-)
   then shift
   else voice="$(readlink voice)"
   fi
   voice="${voice#voices/}"
   speed="$2"
   freq="$3"
   volume="$4"
   rate="$5"
   test -z "$speed" && test -f speed &&
   speed=$(awk '{printf("%f",exp(0.01*log(1/5)*$1))}' <speed)
   test -z "$freq" && test -f freq &&
   freq=$(awk '{printf("%f",exp(-0.01*log(1/5)*$1))}' <freq)
   test -z "$volume" && test -f volume &&
   volume=$(awk '{printf("%f",exp(-0.01*log(1/5)*$1))}' <volume)
   test -z "$rate" && test -f rate &&
   rate=$(awk '{printf("%f",16000*exp(-0.01*log(1/3)*$1))}' <rate)
   xclip -o |
   espeak -v mb-${voice%:*} |
   "$DIR/mbrola" -e \
      -t "${speed:-1}" \
      -f "${freq:-1}" \
      -v "${volume:-1}" \
      -l "${rate:-16000}" \
      "$DIR/voices/$voice" - -.wav |
   mplayer -input file="$FIFO" -really-quiet -demuxer audio -
reset)
   case "$2" in
   '') rm -f speed freq volume rate ;;
   speed|freq|volume|rate) rm -f "$2" ;;
   esac
adjust)
   case "$2" in
      test -f speed && speed=$(cat speed) || speed=0
      test -f freq && freq=$(cat freq) || freq=0
      test -f rate && rate=$(cat rate) || rate=0
      set -- $(
         $XDIALOG --title "$APP" --separator " " \
            --3rangesbox "Röstparametrar" 22 60 \
            "Uppläsningshastighet" -100 100 "$speed" \
            "Röstläge" -100 100 "$freq" \
            "Rösttäthet" -100 100 "$rate"
      if test $# -eq 3
      then
         echo "$1" >speed
         echo "$2" >freq
         echo "$3" >rate
      fi
      exit
   speed) TITLE="Uppläsningshastighet" ;;
   freq) TITLE="Röstläge" ;;
   volume) TITLE="Uppläsningsvolym" ;;
   rate) TITLE="Rösttäthet" ;;
   *) exit ;;
   esac
   test -f "$2" && value=$(cat "$2") || value=0
   case "$3" in
      value=$(
         $XDIALOG --title "$APP" --rangebox "$TITLE" 10 60 -100 100 "$value"
      test -n "$value" &&
      echo "$value" >"$2"
      echo "$3" |
      awk -vvalue="$value" '{
         if($1) value+=$1
         else value=0
         if(value>100) value=100
         if(value<-100) value=-100
         print(value)
      }' >"$2"
   esac
voice)
   case "$2" in
      voice=$(
         eval $XDIALOG --title "'$APP'" --no-close --no-cancel \
            --radiolist "'Välj röst'" 20 60 0 $(
            ls voices/[a-z][a-z][1-9]:* 2>&- |
            while read voice
            do test "x$voice" = "x$(readlink voice)" &&
               radiobox=on ||
               radiobox=off
               printf "%s " "'$voice'" "'${voice#voices/}'" "$radiobox"
            done
      voice=$(ls "voices/$2":* 2>&-)
   esac
   test -n "$voice" &&
   ln -sf "$voice" voice
install)
   URL="http://tcts.fpms.ac.be/synthesis/mbrola"
   TMP=$(mktemp)
   trap 'rm -f "$TMP"' EXIT
   wget -qO- "$URL"/mbrcopybin.html |
   sed -n '
      s|.*"\(bin/[^"]*.zip\)"[^>]*>[^<]*LINUX i386.*|\1 (0.3Mb)|p
      s|.*"\(dba/[^/]*/[^"]*\)"[^>]*>\([^:]*:\s*[^<]*\).*|\1\t\2|p
   ' >"$TMP"
   cd "$DIR"
   voices=$(
      cd /usr/share/espeak-data/voices/mb &&
      echo mb-[a-z][a-z][1-9] |
      sed 's/mb-//g;s/\(.\)\s\(.\)/\1|\2/g'
   voices=$(
      eval $XDIALOG --title "'$APP: Installation'" --separator "'|'" \
         --checklist "'Välj språk'" 20 60 0 $(
         grep -E "/($voices)/" <"$TMP" |
         while read file voice
         do case "$voice" in
            sw*|us*|en*) checkbox=on ;;
            *) checkbox=off ;;
            esac
            printf "%s " "${voice%:*}" "'$voice'" "$checkbox"
         done
   test -z "$voices" && exit
   rm -f voices/[a-z][a-z][1-9]:* 2>&-
   cd data
   grep -E "(^bin|/$voices/)" <"$TMP" |
   awk '{
      size[NR]=size[NR-1]+substr($NF,2,length($NF)-4)
      $NF=""
      voice[NR]=$0
   } END {
      for(i=1; i<=NR; i++) {
         print(100*size[i]/size[NR],voice[i])
   while read progress file voice
   do test -f "${file##*/}" ||
      wget -q "$URL/$file" 2>&1
      if test -z "$voice"
      then
         unzip -p "${file##*/}" mbrola-linux-i386 >"$DIR"/mbrola
         chmod +x "$DIR"/mbrola
      else
         unzip -p "${file##*/}" "${voice%%:*}" >"$DIR/voices/$voice" 2>&- ||
         unzip -p "${file##*/}" "${voice%%:*}/${voice%%:*}" \
      fi
      echo $progress
   done |
   $XDIALOG --title "$APP: Installation" --progress "Hämtar Röster..." 10 60
   bind_key() {
      case "$1" in
      metacity)
         KEY="/apps/metacity/global_keybindings"
         CMD="/apps/metacity/keybinding_commands"
         PREFIX="run_command_"
         SUFFIX=""
      compiz)
         KEY="/apps/compiz/general/allscreens/options"
         CMD="/apps/compiz/general/allscreens/options"
         PREFIX="run_command"
         SUFFIX="_key"
      esac
      gconftool-2 -a "$KEY" |
      awk '$1~/^'"$PREFIX"'[0-9]+'"$SUFFIX"'$/ && $3~/^'"$2"'$/{print($1)}' |
      while read binding
      do echo gconftool-2 -u "$KEY/$binding"
      done
      ID=$(
         sed -n "s/^\s*$PREFIX\([0-9]\+\)$SUFFIX\s*=\s*/\1\t/p" |
         sort -n |
         awk '{if($1-prev>1)exit;prev=$1}END{print(prev+1)}'
      gconftool-2 \
         -s -t str "$KEY/$PREFIX${ID:-1}$SUFFIX" "$2" \
         -s -t str "$CMD/${PREFIX#run_}${ID:-1}" "$3"
   for wm in metacity compiz
   do bind_key "$wm" "F1" "$SCRIPT stop"
      bind_key "$wm" "F2" "$SCRIPT pause"
      bind_key "$wm" "F3" "$SCRIPT start"
      bind_key "$wm" "F4" "$SCRIPT start 0.5"
      bind_key "$wm" "F5" "$SCRIPT start sw1 0.5"
      bind_key "$wm" "F6" "$SCRIPT speed 0"
      bind_key "$wm" "F7" "$SCRIPT speed -10"
      bind_key "$wm" "F8" "$SCRIPT speed +10"
      bind_key "$wm" "F9" "$SCRIPT adjust"
      bind_key "$wm" "F10" "$SCRIPT voice"
      bind_key "$wm" "F11" "$SCRIPT voice sw1"
      bind_key "$wm" "F12" "$SCRIPT voice en1"
   done
   $XDIALOG --title "$APP" --msgbox "$APP installerad" 10 60
   exec "$SCRIPT" voice
speed|freq|volume|rate) exec "$SCRIPT" adjust "$@" ;;
*) exec "$SCRIPT" start "$@" ;;
esac
Kör ~/bin/talsyntes.sh install från en terminal. Lista därefter tangentbindningarna igen så jag kan se om det blev någon skillnad.
Hans Linde
OS: Crunchbang
Installation av rösterna funkar utmärkt.
Därefter list enl ök:
hans@hl:~$
hans@hl:~$ ~/bin/talsyntes.sh install
gconftool-2 -u /apps/metacity/global_keybindings/run_command_2
gconftool-2 -u /apps/compiz/general/allscreens/options/run_command1_key
hans@hl:~$
run_command_24 = F12
run_command_13 = F1
run_command_14 = F2
run_command_15 = F3
run_command_16 = F4
run_command_17 = F5
run_command_18 = F6
run_command_19 = F7
run_command_2 = F12
run_command_20 = F8
run_command_21 = F9
run_command_22 = F10
run_command_23 = F11
command_19 = /home/hans/.talsyntes/talsyntes.sh speed -10
command_20 = /home/hans/.talsyntes/talsyntes.sh speed +10
command1 =
command_21 = /home/hans/.talsyntes/talsyntes.sh adjust
command_22 = /home/hans/.talsyntes/talsyntes.sh voice
command_23 = /home/hans/.talsyntes/talsyntes.sh voice sw1
command_24 = /home/hans/.talsyntes/talsyntes.sh voice en1
command_13 = /home/hans/.talsyntes/talsyntes.sh stop
command_14 = /home/hans/.talsyntes/talsyntes.sh pause
command_15 = /home/hans/.talsyntes/talsyntes.sh start
command_16 = /home/hans/.talsyntes/talsyntes.sh start 0.5
command_17 = /home/hans/.talsyntes/talsyntes.sh start sw1 0.5
command_18 = /home/hans/.talsyntes/talsyntes.sh speed 0
hans@hl:~$
Konservburk
Nu kom det iaf en massa nya bindningar. Lustigt någ så verkar F12-bindningen finnas med två gånger, men det är möjligt att det fungerar ändå. De andra tangenterna borde gå att använda nu. Funkar även 12?
Hans Linde
OS: Crunchbang
Jag ska prova.
Men jag ska också se hur du tänkt att det ska bete sig.
Återkommer.
Konservburk
Hans Linde skrev:Jag ska prova.
Återkommer.
Minns inte om jag skrev hur jag tänkt. Men enligt din lista så är det kopplat så här:
run_command_13 = F1
run_command_14 = F2
run_command_15 = F3
run_command_16 = F4
run_command_17 = F5
run_command_18 = F6
run_command_19 = F7
run_command_20 = F8
run_command_21 = F9
F1 - stop
F2 - pause
F3 - start
F4 - start, snabb fart
F5 - start, rösten lukas, snabb fart
F6 - återställ standardfart
F7 - minska fart
F8 - öka fart
F9 - ställ in mbrola-parametrar
F10 - välj röst
F11 - välj rösten lukas
F12 - välj den brittiska rösten
Hans Linde
OS: Crunchbang
Jah.men du har ju stavat fel i meny.................... ;D ;D ;D ;D
Du är helt otroligt!! :)
Det här bara för bra!!
Javisst , svar på dina fråga: Ja, F12 funkar.
Har du en hel ingenjörsstab i fickan.
Jag behöver samma mig för att göra en seriös analys om vad eller om det är
något jag vill "peta på". Troligen har du redan lösningen innan jag ställ frågan.
Så vänta inte på mig .
Jag ska "leka" med det här ett tag.
Himla kul.
Minns du "uppfinnar-jokken" som för ca 3-års sedan fick ett pris där
han kombinera en läspenna och OCR och talsynten och hörlur. På det sättet
kund man "läsa" papper i fält. Det fick han ett pris för.
Mja, det kanske det var värt.
Att skapa en talsyntes protable till en Pc med Linux, som troligen skulle kunna
kosta skolor 100usd i volym ( då med överig funktion) det är "större".
Grattis!!!
Hans Linde
OS: Crunchbang
Jag gillar verkligen "F9". ;D
Konservburk
Hans Linde skrev:Javisst , svar på dina fråga: Ja, F12 funkar.
Jag hittade just varför det blev en dubbelbindning, så det är nu fixat:
#!/bin/sh
# r3
export LC_ALL=C
exec 2>&-
APP="Talsyntes"
DIR=~/".talsyntes"
exec "$SCRIPT" "$@"
set install
cd "$DIR"
case "$1" in
stop)
pause)
start)
   "$SCRIPT" stop
   then shift
   fi
   speed="$2"
   freq="$3"
   volume="$4"
   rate="$5"
   xclip -o |
   "$DIR/mbrola" -e \
      -t "${speed:-1}" \
      -f "${freq:-1}" \
      -v "${volume:-1}" \
reset)
   case "$2" in
   esac
adjust)
   case "$2" in
      set -- $(
      if test $# -eq 3
      then
         echo "$1" >speed
         echo "$2" >freq
         echo "$3" >rate
      fi
      exit
   *) exit ;;
   esac
   case "$3" in
      value=$(
      test -n "$value" &&
      echo "$value" >"$2"
      echo "$3" |
         if($1) value+=$1
         else value=0
         print(value)
      }' >"$2"
   esac
voice)
   case "$2" in
      voice=$(
            while read voice
               radiobox=on ||
               radiobox=off
            done
   esac
   test -n "$voice" &&
install)
   TMP=$(mktemp)
   sed -n '
   ' >"$TMP"
   cd "$DIR"
   voices=$(
   voices=$(
         do case "$voice" in
            *) checkbox=off ;;
            esac
         done
   cd data
   awk '{
      $NF=""
      voice[NR]=$0
   } END {
      if test -z "$voice"
      then
      else
      fi
      echo $progress
   done |
   $XDIALOG --title "$APP: Installation" \
      --no-close --gauge "Hämtar Röster..." 10 60
   bind_key() {
      case "$1" in
      metacity)
         SUFFIX=""
      compiz)
         SUFFIX="_key"
      esac
      while read binding
      do gconftool-2 -u "$KEY/$binding"
      done
      ID=$(
         sort -n |
      gconftool-2 \
   done
esac
Du borde även testa att installera på datorn med compiz. Tanken är att det ska fungera även där, men det kan ju ha smugit sig in något fel där också.
Exakt hur jag placerade bindningarna var ganska slumpmässigt utan någon vidare eftertanke. Jag antar att du har bättre koll på vad som är bra och dåligt när det gäller den biten. Det finns ju dessutom flera kommandon som inte är bundna, men som kanske borde vara det. Och kommandon som inte finns ännu, men som kanske borde finnas.
Konservburk
Hans Linde skrev:Jag gillar verkligen "F9". ;D
Jag vet inte riktigt om jag fick till skalorna helt bra. Som det är nu så kan man höja och sänka till nästan helt oanvändbara värden. Hugger man bort lite i kanterna så blir det istället lättare att finjustera i området som faktiskt är vettigt att använda. Frågan är isf hur mycket som är ok att hugga bort.
Hans Linde
OS: Crunchbang
Det första jag hittar, är av stor betydelse ur användarhänseende.
Kanske det finns annat handhavande sätt, att komma ikring det med,
men just nu ser jag inte det.
Jag markerar en stor text och vill justera något.
Trycker paus och gör justeringen, men den inträffar först om rösten stannas,
och då börjar den från början. Jag vet inte var i texten, jag är.
Om det gick att justera då rösten läste, också eller som alternativ,
vore det "bättre.
Det kanske är en utmaning även för dig?
Dock har vi fortfarande rösterna att fundera på.
De är okay, men "det finns bättre" och även på för dessa "finns det utrymme"
till förbättring. Jag har funderat på om det finns någon anledning till
att vi inte skulle överväga de röster som används av Acapella.
Koden för dessa röster kan ju inte vara platformsberoende,
så det är mera en frågan om de vill vara med "på resan" eller
"stå bredvid" med sin "high performance voice print".
Här finns några röster:
http://www.svensktalteknologi.se/wordreadplusPC.html
http://www.clarosoftware.com/index.php? ... 1f6tc4ddm7
Hans Linde
OS: Crunchbang
Den ny filen är installerad och testad litegrann.
Jag har inga invändningar. Jag har inte heller upptäckt
det fel du fixat med den här filen.
Jag kan titta nogrannare på röstjusteringen, om du vill
men jag antar att det kan påverkas av det nya synpunkterna kom med.
Vad önskas?
Skönt att jag slipper granska texten läsande (traglandes). :)
Konservburk
Hans Linde skrev:Jag markerar en stor text och vill justera något.
vore det "bättre.
Det är helt klart en utmaning eftersom mbrola-parametrarna skickas med när man startar själva mbrola. Vad förstår det som så finns det inget sätt att justera dessa i efterhand, utan du måste stoppa mbrola och starta den igen med nya parametrar.
Det är möjligt att man på något sätt kan hålla koll på hur långt i texten man har kommit, och starta om programmet från den punkten, men det känns inte som att det är speciellt enkelt att ordna. Det lättaste just nu är nog att försöka med en liknande hugga-upp-variant som vi gjorde med festival. Då startar en ny mbrola-process med möjlighet att skicka med nya parametrar vid varje klipp-punkt. Då skulle man även kunna hålla koll på var i texten man är och kanske till och med ha en tangent som backar en mening eller liknande.
Hans Linde
OS: Crunchbang
2a önskan:
Jag blir att mera nöjd med det grafiska en jag trott. Dock är det lite svårt med
precisionen, pga att rutans storlek och handens rörelse inte möter mina behov.
Istället för att göra en ruta som skymmer texten. Kan det gå att markera
reglaget med markören, fast justeringen kan också ske med "-"F7 allt "+" F8?
Nu börjar det bli svårt att inte önska, att det också ska vara dynamiskt( eller
är det bättre att säga , justerbart då rösten talar,)
Jag minns att du nämnde något om filstorlek för några dagar sedan. ;D ;D
Hans Linde
OS: Crunchbang
Finns det någon anledning att kontakta De som ligger bakom Acapela-rösterna?
Eller ligger det utanför det här "scoopet".
I fall det är intressant, men du inte har en stab mäniskor som kan tala med dem,
utan är förvisad till det som finns på www..... Hmm..nja, det iaf varit mitt yrke
övertala folk...och nu ser det ut som om jag kommer att få tid (tyvärr.)
Konservburk
Hans Linde skrev:Jag blir att mera nöjd med det grafiska en jag trott. Dock är det lite svårt med
Går det inte att reglera med piltangenterna? Tab för att byta reglage?
Eller menar du justering utan någon ruta alls? Som F7 och F8, fast för annat än uppläsningsfarten? Det går redan att göra med:
~/bin/talsyntes.sh freq +10
~/bin/talsyntes.sh rate +10
~/bin/talsyntes.sh volume +10
Fast de funktionerna är inte bundna till någon tangent för tillfället.
Konservburk
Hans Linde skrev:Finns det någon anledning att kontakta De som ligger bakom Acapela-rösterna?
Det känns som att det ligger lite bortom vad som är möjligt. En talsyntesröst är inte bara en röst, utan även en massa kod som tolkar text och gör om den till något fonetiskt på ett lämpligt sätt som sedan själva rösten kan arbeta med. Så även om man mot förmodan får tillgång till rösterna så krävs det antagligen en heltidstjänst för att kunna få till någonting som ens är i närheten av orginalprodukten.
Det vi har gjort hittils är inte mer än gränssnitt till redan färdiga lösningar.
Hans Linde
OS: Crunchbang
Jag som jag antog. Du har redan lösningen. Pilarna o tab är mycket bättre.
Ja så då är det bara det där dynamiska och trimmingen på
reglagens ändlägen.
Hans Linde
OS: Crunchbang
Ang Compiz och Metacityså har har tänkt flytta över något av detta till min "huvud-PC".
Den är också i386, som testverktyget vi använde först. Jag har dock inte klart för mig än
vilken grafik det är. Sa du att det berode på grafikkortet, dvs ATI eller Nvidia?
Som sedan kväver C alt M?
Nja behövs det, så röjer jag upp i TestPCn , så det kan testas där också.
Säg till när du vill ha det gjort.
