Mavericks milstolpar
Re: Mavericks milstolpar
Första dagliga bygget ute idag....
http://cdimage.ubuntu.com/daily/current/
Än så länge utan Live-funktionalitet.
- Ulsak
läste på fejan att Jono Bacon lyckats att göra en Maverick..
Första riktiga paketsammanbrottet..... "be careful out there"....
samt om man sedan försöker installera mplayer
Misstänker att det är Zeitgeist som strulat till det.......
The following packages will be REMOVED:
boxee gnome-mplayer gstreamer0.10-plugins-bad libdirectfb-1.2-0 mencoder
mplayer mplayer-nogui smplayer smplayer-themes smplayer-translations
The following NEW packages will be installed:
dockmanager libdirectfb-1.2-9 python-dockmanager python-mutagen zeitgeist
zeitgeist-core zeitgeist-datahub
The following packages have been kept back:
docky
The following packages will be upgraded:
cpp-4.4 g++-4.4 gcc-4.4 gcc-4.4-base libdirectfb-dev libdirectfb-extra
libnih-dbus1 libnih1 libsdl1.2-dev libsdl1.2debian
libsdl1.2debian-pulseaudio libstdc++6-4.4-dev libxine1 libxine1-bin
libxine1-console libxine1-ffmpeg libxine1-misc-plugins libxine1-x
18 upgraded, 7 newly installed, 10 to remove and 1 not upgraded.
plun@plun-laptop:~$ sudo aptitude install mplayer
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reading extended state information
Initializing package states... Done
The following packages are BROKEN:
libdirectfb-1.2-9
libdirectfb-1.2-0{a} mplayer
0 packages upgraded, 2 newly installed, 0 to remove and 1 not upgraded.
Need to get 4,221kB of archives. After unpacking 8,471kB will be used.
The following packages have unmet dependencies:
libdirectfb-1.2-9: Conflicts: libdirectfb-1.2-0 but 1.2.8-5ubuntu2 is to be installed.
The following actions will resolve these dependencies:
Remove the following packages:
chromium
chromium-bsu
ffmpeg
gimp
gstreamer0.10-plugins-bad-multiverse
libdirectfb-1.2-9
libdirectfb-dev
libdirectfb-extra
libgegl-0.0-0
libmjpegtools-1.9
libsdl-image1.2
libsdl1.2-dev
libsdl1.2debian
libxine1
libxine1-console
libxine1-x
phonon-backend-xine
ubuntu-desktop
virtualbox-3.2
vlc
Keep the following packages at their current version:
mplayer [Not Installed]
Leave the following dependencies unresolved:
gimp-data recommends gimp
libgimp2.0 recommends gimp
ubuntu-restricted-extras recommends gstreamer0.10-plugins-bad-multiverse
Score is -12268
Accept this solution? [Y/n/q/?]
To be expected, det kan bli värre .. men det mesta fungerar fortfarande
Och så är det 2.6.34-5 som gäller nu ...
Maverick Meerkat 24/7
Jo jag fick loss knuten mha aptitude och att ta bort ffmpeg, jag har även Medibuntu inlagt som strulade till det.
Efter det gick det att installera ffmpeg igen med följande paket brutna
Felet för mig var även en "broken pipe" så det måste fixas annars står pakethanteringen still.
2.6.34-5 funkar fint...
ffmpeg libavdevice52{a}
apport-hooks-medibuntu{u} dockmanager{u} python-dockmanager{u}
python-mutagen{u} zeitgeist{u} zeitgeist-core{u} zeitgeist-datahub{u}
- vulfgar
- ung forumnörd
Råkade också ut för en "broken pipe" och avinstallerade ffmpeg mm. Verkar funka bra efter det, peppar peppar ....
- vulfgar
- ung forumnörd
Hmm, den kärnuppgraderingen har jag inte sett ännu. :sxeizo skrev:To be expected, det kan bli värre .. men det mesta fungerar fortfarandeOch så är det 2.6.34-5 som gäller nu ...
Metapaketet för kärnan är ute.vulfgar skrev:Hmm, den kärnuppgraderingen har jag inte sett ännu. :sxeizo skrev:To be expected, det kan bli värre .. men det mesta fungerar fortfarandeOch så är det 2.6.34-5 som gäller nu ...
https://lists.ubuntu.com/archives/maver ... 00887.html
Kör du med Main=Huvudservern som uppdateringskölla ? Meny System >Administration>Mjukvarukällor > i mitten, rullgardin
EDiT
sudo apt-get install libavcodec52 libavutil49 libavformat52
- vulfgar
- ung forumnörd
Jag kör med huvudservern, kör aldrig någon annan på utvecklingsversioner. Kör faktiskt ofta huvudservern annars också, av gammal vana.
Får fortfarande inte upp den nya kärnan, mycket märkligt.
Ska testa igen om en stund. Även om det vore en paketkonflikt att installera så borde den synas när jag söker på den, tycker jag.
Tydligen något problem med kernel 2.6.34-5.4, åtminstone för 32-bitars som jag inte lyckats installera pga beroendeproblem med saknade kärnpaket. Nu har man plockat bort den och 2.6.34-5.12 ligger i upload för godkännande så vi får se om den funkar bättre när den dyker upp.
- vulfgar
- ung forumnörd
Ok. jag kör visserligen 64-bitars, men den kanske är tillbakadragen där också. Jag får i alla fall meddelande att paketet inte finns när jag försöker installera via terminalen och den hittas (givetvis) inte heller av synaptic. Den dyker väl upp, det är bara jag som alltid är så otålig.Bowmore skrev:Tydligen något problem med kernel 2.6.34-5.4, åtminstone för 32-bitars som jag inte lyckats installera pga beroendeproblem med saknade kärnpaket. Nu har man plockat bort den och 2.6.34-5.12 ligger i upload för godkännande så vi får se om den funkar bättre när den dyker upp.
Kärnan version 2.6.34-5.12 har landat
https://launchpad.net/ubuntu/+source/linux/2.6.34-5.12
Fungerade att installera för mig men fick göra det manuellt.
I mitt fall var det dessa tre paket:
Vad är det dessa paket fixar?
- libavcodec52 vill avinstallera libavcodec-extra-52
- libavutil49 vill avinstallera libavutil49-extra-49
men det vill inte jag
EDIT2
Oops! De extra-paketen är ju tomma!
Så böjer mig denna gång och installerar Debians defaults
EDITlinux-headers-2.6.34-5
linux-headers-2.6.34-5-generic-pae
linux-image-2.6.34-5-generic-pae
- libavformat52 har jag redanpun skrev: sudo apt-get install libavcodec52 libavutil49 libavformat52
fixar några codecs
EDIT2
- vulfgar
- ung forumnörd
Ahh, nu håller jag på att uppdatera med den nya kärnan.
Den dök upp automatiskt.
Nåja, att dom drar in paket för att buggfixa är väl inte så underligt i en utvecklingsversion, jag får lära mej tålamod.
Jovisst.. extra-paketen utgår......Bowmore skrev: EDIT2
Nu restar libdirectfb... min Radio-Tray är broken med alla mms-stationer...
gstreamer0.10-plugins-bad: Depends: libdirectfb-1.2-0 but it is not going to be installed
E: Broken packages
@Vulfgar
Om man är otålig som jag själv är så behöver man inte vänta på meta-paketet av en kärna.
När man får en ny linux-libc-dev så är det signalen på att det finns en ny.
Man startar Synaptic, söker efter linux-image samt sedan linux-headers(2 filer) så är det bara att installera...
gstreamer0.10-plugins-bad har beroende till libdirectfb-1.2-0.pun skrev:Nu restar libdirectfb... min Radio-Tray är broken med alla mms-stationer...
The following packages have unmet dependencies: gstreamer0.10-plugins-bad: Depends: libdirectfb-1.2-0 but it is not going to be installed E: Broken packages
Jag antar att du försöker installera libdirectfb-1.2-9 som ersätter libdirectfb-1.2-0.
Så släpp taget om gstreamer0.10-plugins-bad och låt det avinstalleras
- vulfgar
- ung forumnörd
Jag gjorde så, både i synaptic och i terminalen, paketen fanns helt enkelt inte. Dom var väl indragna när jag letade. Vid senaste uppdateringaren fanns den och nu är kärnan installerad och klar. Tack för tipset i alla fall, det kan säkert vara till hjälp för någon annan.pun skrev: @Vulfgar
Mitt problem just nu är att min enda internetuppkoppling är via mobilen. Det är ibland hopplöst med både nerladdning och att söka eftersom hastigheten är så låg och dessutom ojämn. Jag trodde ett tag att det var mina problem med internetuppkopplingen som ställde till det hela, men så var det alltså inte.
Yep.... har redan gjort mig av med "bad"-paketet och aptitude första förslag är lite magstarkt....Bowmore skrev: Jag antar att du försöker installera libdirectfb-1.2-9 som ersätter libdirectfb-1.2-0.
plun@plun-laptop:~$ sudo aptitude install gstreamer0.10-plugins-bad
[sudo] password for plun:
Writing extended state information... Done
libdirectfb-1.2-9
freepats{a} gstreamer0.10-plugins-bad libcdaudio1{a} libcelt0-0{a}
libdirac-encoder0{a} libdirectfb-1.2-0{a} libflite1{a} libgme0{a}
libiptcdata0{a} libkate1{a} libmimic0{a} libmms0{a} libofa0{a}
liborc-0.4-0{a} libsoundtouch1c2{a} libwildmidi0{a}
akonadi-server{u} icoutils{u} kdebase-runtime-data{u}
kdepimlibs-kio-plugins{u} libakonadi-kabc4{u} libakonadi-kcal4{u}
libakonadi-kde4{u} libakonadi-kmime4{u} libakonadiprivate1{u} libkabc4{u}
libkcal4{u} libkimap4{u} libkldap4{u} libkmime4{u} libkpimutils4{u}
libkresources4{u} libmailtransport4{u} libmicroblog4{u}
libpackagekit-glib2-12{u} libpackagekit-qt-12{u} libpolkit-qt-1-0{u}
libssh-4{u} libvirtodbc0{u} mysql-client-core-5.1{u}
mysql-server-core-5.1{u} oxygen-icon-theme{u} packagekit{u}
packagekit-backend-apt{u} plasma-scriptengine-javascript{u}
python-packagekit{u} python-qt4{u} python-sip{u}
shared-desktop-ontologies{u} ttf-dejavu{u} ttf-dejavu-extra{u}
virtuoso-minimal{u} virtuoso-opensource-6.0-bin{u}
virtuoso-opensource-6.0-common{u}
0 packages upgraded, 16 newly installed, 38 to remove and 2 not upgraded.
Need to get 47.5MB of archives. After unpacking 44.6MB will be freed.
chromium
chromium-bsu
ffmpeg
gimp
libdirectfb-1.2-9
libdirectfb-dev
libdirectfb-extra
libgegl-0.0-0
libmjpegtools-1.9
libsdl-image1.2
libsdl1.2-dev
libsdl1.2debian
libxine1
libxine1-console
libxine1-x
phonon-backend-xine
ubuntu-desktop
virtualbox-3.2
vlc
Score is -2337
Japp, du får stå ut med gstreamer0.10-plugins-good/ugly ett tag
- Ulsak
alpha på gång snart?
( om inte mitt minne sviker mig)
Nja, temporärt i så fall ...pun skrev:Jovisst.. extra-paketen utgår......![]()
libavutil-extra-49 is empty (except /usr/share/doc)
