Nvidia Drivers
kaapu
Nvidia Drivers
Inlägg av kaapu »
Kolla via Program > Systemverktyg > nVidia X server ....
Har du någon kontrollpanel....?
Japp har en nVidia X server kontrollpanel.
Vad kör du för upplösning ? färgdjupet sedan bör vara minst 24ppb.
Har 1024*768 . Färgdjupet är 32bpp.
Via terminalen är glx igång ? glxinfo
Här e vad jag får upp :
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
    GLX_EXT_texture_from_pixmap
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
    GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap
GLX version: 1.3
GLX extensions:
    GLX_EXT_texture_from_pixmap, GLX_ARB_get_proc_address
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce4 MX 420/AGP/SSE2
OpenGL version string: 1.5.8 NVIDIA 96.29
OpenGL extensions:
    GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_pixel_buffer_object,
    GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects,
    GL_ARB_shading_language_100, GL_ARB_texture_compression,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
    GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
    GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
    GL_S3_s3tc, GL_EXT_texture_env_add, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_clip_volume_hint, GL_EXT_compiled_vertex_array, GL_EXT_Cg_shader,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord,
    GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shared_texture_palette,
    GL_EXT_stencil_wrap, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod,
    GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_vertex_array,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_fence,
    GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_register_combiners,
    GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
    GL_NV_texture_rectangle, GL_NV_vertex_array_range,
    GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
    GL_SGIS_generate_mipmap, GL_SGIS_multitexture, GL_SGIS_texture_lod,
    GL_SUN_slice_accum
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x2a 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2f 24 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x30 24 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x31 24 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x32 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x33 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x34 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x35 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x36 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x37 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x38 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x39 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x3a 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x3b 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x3c 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x3d 24 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x3e 24 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x3f 24 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x40 24 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0xa0 32 tc  1  0  0 c  .  .  0  0  0  0  0  0  0  0  0  0  0  0 0 None
Kanske bra att skicka med sin xorg.conf fil också :
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Wed Nov  1 19:47:17 PST 2006
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
    Identifier     "Default Layout"
    Screen         "Default Screen" 0 0
    InputDevice    "Generic Keyboard"
    InputDevice    "Configured Mouse"
    InputDevice    "stylus" "SendCoreEvents"
    InputDevice    "cursor" "SendCoreEvents"
    InputDevice    "eraser" "SendCoreEvents"
EndSection
Section "Files"
	# path to defoma fonts
    FontPath        "/usr/share/X11/fonts/misc"
    FontPath        "/usr/share/X11/fonts/cyrillic"
    FontPath        "/usr/share/X11/fonts/100dpi/:unscaled"
    FontPath        "/usr/share/X11/fonts/75dpi/:unscaled"
    FontPath        "/usr/share/X11/fonts/Type1"
    FontPath        "/usr/share/X11/fonts/100dpi"
    FontPath        "/usr/share/X11/fonts/75dpi"
    FontPath        "/usr/share/fonts/X11/misc"
    FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
    Load           "i2c"
    Load           "bitmap"
    Load           "ddc"
    Load           "extmod"
    Load           "freetype"
    Load           "glx"
    Load           "int10"
    Load           "type1"
    Load           "vbe"
EndSection
Section "InputDevice"
    Identifier     "Generic Keyboard"
    Driver         "kbd"
    Option         "CoreKeyboard"
    Option         "XkbRules" "xorg"
    Option         "XkbModel" "pc105"
    Option         "XkbLayout" "se"
    Option         "XkbOptions" "lv3:ralt_switch"
EndSection
    Identifier     "Configured Mouse"
    Driver         "mouse"
    Option         "CorePointer"
    Option         "Device" "/dev/input/mice"
    Option         "Protocol" "ExplorerPS/2"
    Option         "ZAxisMapping" "4 5"
    Option         "Emulate3Buttons" "true"
EndSection
                                                      # /dev/input/event
                                                      # for USB
    Identifier     "stylus"
    Driver         "wacom"
    Option         "Device" "/dev/wacom"          # Change to
    Option         "Type" "stylus"
    Option         "ForceDevice" "ISDV4"               # Tablet PC ONLY
EndSection
                                                      # /dev/input/event
                                                      # for USB
    Identifier     "eraser"
    Driver         "wacom"
    Option         "Type" "eraser"
EndSection
                                                      # /dev/input/event
                                                      # for USB
    Identifier     "cursor"
    Driver         "wacom"
    Option         "Type" "cursor"
EndSection
Section "Monitor"
    Identifier     "LS704U"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "NVIDIA Corporation NV17 [GeForce4 MX 420]"
    Driver         "nvidia"
 "RenderAccel" "true"
    Option         "AllowGLXWithComposite" "true"
#    Option         "backingstore" "true"
    Option          "TripleBuffer" "true"
    Option      "AddARGBGLXVisuals" "True"
EndSection
Section "Screen"
    Identifier     "Default Screen"
    Device         "NVIDIA Corporation NV17 [GeForce4 MX 420]"
    Monitor        "LS704U"
    DefaultDepth    24
    SubSection     "Display"
        Depth       1
        Modes      "1024x768" "800x600" "640x480"
    EndSubSection
        Depth       4
    EndSubSection
        Depth       8
    EndSubSection
        Depth       15
    EndSubSection
        Depth       16
    EndSubSection
        Depth       24
 'Option "AddARGBGLXVisuals" "True"'
    EndSubSection
EndSection
Hoppas det finns någon lösning till problemet! Vill gärna få Beryl att fungera. :)
Okänd
Nvidia Drivers
Inlägg av Okänd »
Du har skräp kring
Ska vara
Annars ser det rätt ut.
kaapu
Nvidia Drivers
Inlägg av kaapu »
Jag tog o installerade om hela systemet och testade att följa guiden igen ! Och hör och häpna nu funkar allting perfekt ! :D WEEHOO! tack så mkt för all hjälp jag har fått!
