WebM, tretton år senare
Re: WebM, tolv år senare
Bringing the best live video experience to Cloudflare Stream with AV1 (The Cloudflare Blog)
SVT-AV1 1.3.0 (2022-10-18)
Encoder
Encoder
- Port SIMD optimizations from libDav1D making the conformant path (Inv. Transform) faster
- Enabling smaller mini-GOP size configurations and tuning it for the low delay mode
- Tuning the low-latency mode in random access targeting latencies from 250ms to 1s
- Adding GOP-constrained Rate Control targeting low-latency streaming applications
- Optimize mode decision features levels for depth partitioning, RDOQ, MD stage0 pruning in-loop filtering temporal filtering and TPL adding more granularity and gaining further quality
- Preset tuning M0-M13 to smooth the spacing and utilize the quality improvements towards better tradeoffs
- Update preset and API documentation
- Various functional bug fixes
- Remove the use of GLOB in cmake and use file names
SVT-AV1 1.4.0 (2022-11-30)
Encoder
Rav1e 0.6.1 (2022-11-30)
Rav1e 0.6.0 (2022-11-30)
Encoder
- Adopted the 6L / 32-picture mini-GOP configuration as default and adjusted MD feature levels accordingly yielding higher compression efficiency gains
- Update the TPL model to account for the larger mini-gop size
- Re-tune presets M0-M12 using the gained coding efficiency for improved quality vs cycles tradeoffs
- Allow duplicate commandline parameters to be parsed and take into consideration the latter to allow AWCY integration
- Make include and lib paths friendly to abs and rel paths
- Remove manual prediction structure support
SVT-AV1 1.4.1 (2022-12-12)
Bugfixes:
Bugfixes:
- Fix CRF with maxrate bug causing bitrate to be significantly limited for CRF encodings
- Fix command line parsing forcing 1-pass in a 2-pass encoding mode when the --keyint=xs format is used
- Fix decoder segfault due to assuming aligned buffers in the inverse transform assembly
Rav1e 0.6.2 (2022-12-26)
HandBrake 1.6.0 har AV1-kodaren SVT-AV1 1.4.1.
LibVPX 1.12.0 för VP8 och VP9.
I en kommande version tas VP8 och Theora bort.
libvpx v1.13.0 Ugly Duckling Finalized
Release Note
This release includes more Neon and AVX2 optimizations, adds a new codec control to set per frame QP, upgrades GoogleTest to v1.12.1, and includes numerous bug fixes.
This release is available from the git repository and the v1.13.0 tarball, along with the asc file.
Release Note
- Upgrading:
- This release is ABI incompatible with the previous release.
- New codec control VP9E_SET_QUANTIZER_ONE_PASS to set per frame QP.
- GoogleTest is upgraded to v1.12.1.
- .clang-format is upgraded to clang-format-11.
- VPX_EXT_RATECTRL_ABI_VERSION was bumped due to incompatible changes to the feature of using external rate control models for vp9.
- Enhancement:
- Numerous improvements on Neon optimizations.
- Numerous improvements on AVX2 optimizations.
- Additional ARM targets added for Visual Studio.
- Bug fixes:
- Fix to calculating internal stats when frame dropped.
- Fix to segfault for external resize test in vp9.
- Fix to build system with replacing egrep with grep -E.
- Fix to a few bugs with external RTC rate control library.
- Fix to make SVC work with VBR.
- Fix to key frame setting in VP9 external RC.
- Fix to -Wimplicit-int (Clang 16).
- Fix to VP8 external RC for buffer levels.
- Fix to VP8 external RC for dynamic update of layers.
- Fix to VP9 auto level.
- Fix to off-by-one error of max w/h in validate_config.
- Fix to make SVC work for Profile 1.
Dav1d 1.1.0 “Arctic Peregrine Falcon”
Dav1d 1.1.0
1.1.0 is an important release of dav1d, fixing numerous bugs, and adding SIMD
https://code.videolan.org/videolan/dav1 ... ases/1.1.0
Dav1d 1.1.0
- New function dav1d_get_frame_delay to query the decoder frame delay
- Numerous fixes for strict conformity to the specs and samples
- NEON and AVX-512 misc fixes and improvements
- Partial AVX2 12bpc transform implementations
- AVX-512 high bit-depth cdef_filter, loopfilter, itx
- NEON z1/z3 optimization for 8bpc
- SSSE3 z1 optimization for 8bpc
Opus 1.4.
Opus 1.4 brings the following improvements and fixes:
bug fixes.
https://gitlab.xiph.org/xiph/opus/-/tags/v1.4
- Improved tuning of the Opus in-band FEC (LBRR). See the #2360 for details
- Added a OPUS_SET_INBAND_FEC(2) option that turns on FEC, but does not force SILK mode (FEC will be disabled in CELT mode)
- Improved tuning and various fixes to DTX
- Added Meson support, improved CMake support
bug fixes.
SVT-AV1 1.5.0 (2023-04-26)
Encoder
Encoder
- Optimize the tradeoffs for M0-M13 speeding up M5-M1 by 15-30% and improving the BDR of M6-M13 by 1-3%
- Create a new preset MR (--preset -1) to be the quality reference
- Optimize the tradeoffs for M8-M13 in the low delay encoding mode (!2052 !2096 and !2102) for SC and non-SC modes
- Add dynamic minigop support for the random access configuration enabled by default in M9 and below
- Add support to allow users to specify lambda scaling factors through the commandline
- Rewrite the gstreamer plugin and updating it to be uptodate with the latest API changes
- Add skip frames feature allowing the user to start encoding after n frames in the file
- Add ability to specify a smaller startup minigop size for every gop to enable faster prefetching
- Fix segmentation support and re-enable it with --aq-mode 1 to allow work on the region of interest API
- Add padding bytes to the EbSvtAv1EncConfiguration configuration structure keep its size unchanged until v2.0
- Major cleanups for unused variables, static functions, and comments formatting
- Reduce the size of variable names for an easier code read
- Refine app level parsing and reference scaling API calls in the application
- Add dynamic minigop documentation along with updating the documentation accordingly
LibAOM 3.6.0 finns nu i Chromium 113, för snabbare AV1-kodning vid videosamtal.
Improved video calling with faster AV1 encoding
dav1d 1.2.0 release (Jean-Baptiste Kempf)
Changes for 1.2.0 ‘Arctic Peregrine Falcon’:
1.2.0 is a small release of dav1d, adding more SIMD and fixes
https://code.videolan.org/videolan/dav1 ... ases/1.2.0
- Improvements on attachments of props and T.35 entries on output pictures
- NEON z1/z3 high bit-depth optimizations and improvements for 8bpc
- SSSE3 z2/z3 8bpc and SSSE3 z1/z3 high bit-depth optimziations
- refmvs.save_tmvs optimizations in SSSE3/AVX2/AVX-512
- AVX-512 optimizations for high bit-depth itx (16x64, 32x64, 64x16, 64x32, 64x64)
- AVX2 optimizations for 12bpc for 16x32, 32x16, 32x32 itx
Re: WebM, tretton år senare
En ny AV1-avkodare är under utveckling: Rav1d. Rav1d är Dav1d omskriven i Rust.
A Safer High Performance AV1 Decoder
AV1 Decoder
Utvecklingen sker inom projektet Prossimo, som drivs av ISRG, som också driver Let’s Encrypt.
AV1 Decoder
Dav1d 1.2.1 “Arctic Peregrine Falcon”
1.2.1 is a small release of dav1d, adding more SIMD and fixes
- Fix a threading race on task_thread.init_done
- NEON z2 8bpc and high bit-depth optimizations
- SSSE3 z2 high bit-depth optimziations
- Fix a desynced luma/chroma planes issue with Film Grain
- Reduce memory consumption
- Improve dav1d_parse_sequence_header() speed
- OBU: Improve header parsing and fix potential overflows
- OBU: Improve ITU-T T.35 parsing speed
- Misc buildsystems, CI and headers fixes
SVT-AV1 1.6.0 (2023-06-18)
Encoder
Encoder
- Improve the tradeoffs for the random access mode across presets M1–M13:
- Speeding up the higher quality presets by 30–40%
- Improving the BD-rate by 1–4% for the faster presets
- Improve the tradeoffs for the low delay mode for both screen content and non-screen content encoding modes
- Add a toggle to remove the legacy one-frame buffer at the input of the pipeline allowing the low delay mode to operate at sub-frame processing latencies
- Add a new API allowing the user to specify quantization offsets for a region of interest per frame
- Various cleanups and functional bug fixes
- Fix the startup minigop size BD-rate loss
- Add ability to run the ci-testing offline
SVT-AV1 1.7.0 (2023-08-24)
Encoder
Encoder
- Improve the tradeoffs for the random access mode across presets MR–M13:
- Quality improvements across all presets and metrics ranging from 0.3% to 4.5% in BD-rate (!2129)
- Spacing between presets [M1-M6] has been adjusted to account for the tradeoff improvements achieved
- As a user guidance when comparing v1.7 vs v1.6 in a convexhull encoding setup:
- v1.7.0 M2 is now at similar quality levels as v1.6.0 M1 while being ~50% faster
- v1.7.0 M3 is now at similar quality levels as v1.6.0 M2 while being ~50% faster
- v1.7.0 M4 is now at similar quality levels as v1.6.0 M3 while being ~40% faster
- v1.7.0 M5 is now at similar quality levels as v1.6.0 M4 while being ~30% faster
- v1.7.0 M6 is now at similar quality levels as v1.6.0 M5 while being ~25% faster
- Added an experimental tune SSIM mode yielding ~3–4% additional SSIM BD-rate gains (!2109)
- Fix build conflict with libaom
libaom v3.7.0 Iron Bark Released
This release includes new codec interfaces, compression efficiency and perceptual improvements, speedup and memory optimizations and many bug fixes.
https://aomedia.googlesource.com/aom/+/refs/tags/v3.7.0
