WebM, tretton år senare
Re: WebM, nio år senare
AV1-kodaren Rav1e 0.3.0 har släppts med följande ändringar:
Improvements
  • Faster and better Speed 10
  • Smaller binaries (Around 3MB stripped on x86_64/Linux)
  • Faster build times (About 14% faster build time)
  • Multi-threaded deblocking filter
  • Additional x86_64 SIMD code
  • More auto-vectorizable codepaths and bounds check elisions
  • ⅙ less memory allocations
  • Improvements on the intra-modes pruning logic in the RDO
  • More float to fixed-point conversions
  • Make an early-exit condition in RDO faster
  • Simplify logic in Counter/Recorder store method
  • Support wasm32-wasi as build target
  • 1–2% overall quality improvement (at speed level 2)
New tools
  • Intra edge filter
  • Switch frame support (use -S, --switch-frame-interval <SWITCH_FRAME_INTERVAL> to enable it from the CLI)
  • Fine directional intra prediction
  • Still Picture support with reduced still picture header (AVIF)
Changes
  • Upstream nasm-rs 0.1.7 can be used to build rav1e.
  • The C header produced is now C++-compatible
Fixes
  • #1930
  • #2055
https://github.com/xiph/rav1e/releases/tag/v0.3.0
Dav1d 0.6.0 ‘Gyrfalcon’:
0.6.0 is a major release for dav1d:
  • New ARM64 optimizations for the 10/12bit depth:
    • mc_avg, mc_w_avg, mc_mask
    • mc_put/mc_prep 8tap/bilin
    • mc_warp_8x8
    • wiener
    • cdef
  • New AVX-512 optimizations for prep_bilin, prep_8tap, cdef_filter
  • New SSSE3 optimizations for film grain
  • New AVX2 optimizations for msac_adapt16
  • Fix rare mismatches against the reference decoder, notably because of clipping
  • Improvements on ARM64 on msac, cdef optimizations
  • Improvements in the C version for itxfm, cdef_filter
https://code.videolan.org/videolan/dav1 ... aster/NEWS
AV1-kodaren Rav1e 0.3.1 har släppts med följande ändringar:
Improvements
  • 25–40% faster speed levels 2 to 5
    • This is accomplished by disabling costly coding tools
      • Fine directional prediction
      • Intra block transform splitting in inter frames
    • Encoding quality is slightly inferior (1–2%), but more in line with the target speed levels
https://github.com/xiph/rav1e/releases/tag/v0.3.1
SVT-AV1 v0.8.2
[0.8.2] - 2020-04-18
Encoder
  • Initial Super resolution support
  • Mode decision rate estimation enhancements
  • Altref improvements
  • Manual prediction structure support
  • Enhanced RDOQ support
  • Improved warp motion
  • Improved documentation and help menu
  • New command line parameters
  • Fix non-multiple of 8 resolution video corruption for 8bit
  • Improved multi-stage mode decision support
  • Added multi-stage motion estimation support
  • Chroma mode decision optimizations
  • Added 16bit pipeline support
  • Added Mode decision non-square partition weights
  • Enhanced qp-scaling assignment
  • Memory optimizations
  • Added AVX512 Optimizations
  • Added AVX2 Optimizations
Decoder
  • Improved multi-threading support
  • Updated documentation
  • Loop filter flow optimization
Encoder and Decoder
  • Encoder-Decoder-Common folder structure improvements
Build and Testing
Bug fixes
  • Improve CI
  • Improve Unit Test Coverage
  • Address C vs asm mismatches
  • Support C only builds (for platforms other than x86)
https://github.com/OpenVisualCloud/SVT- ... tag/v0.8.2
SVT-AV1 v0.8.3
[0.8.3] - 2020-04-24
Encoder
  • Presets optimization
Build and Testing
  • Bug fixes
  • Xcode build support
https://github.com/OpenVisualCloud/SVT- ... tag/v0.8.3
LibAOM 2.0 är på gång. RC1 har släppts: https://aomedia.googlesource.com/aom/+/ ... v2.0.0-rc1
Släppts har också SVT-VP9 0.2.0:
  • Fix ffmpeg plugin “Too many invisible frames” issue for mkv/webm/mp4/dash.
  • Fix video corruption for non-multiple-of-8 gop size.
  • Remove -irefresh-type option.
https://github.com/OpenVisualCloud/SVT- ... tag/v0.2.0
Re: WebM, tio år senare
I dag, på WebMs tioårsdag, släpptes libaom v2.0.0 Applejack, en större uppdatering av AV1-referensimplementeringen LibAOM.
https://aomedia.googlesource.com/aom/+/refs/tags/v2.0.0
Dav1d 0.7.0 ”Frigatebird” har släppts.
Changes for 0.7.0 ‘Frigatebird’:
0.7.0 is a major release for dav1d:
  • Faster refmv implementation gaining up to 12% speed while –25% of RAM (Single Thread)
  • 10b/12b ARM64 optimizations are mostly complete:
    • ipred (paeth, smooth, dc, pal, filter, cfl)
    • itxfm (only 10b)
  • AVX2/SSSE3 for non-4:2:0 film grain and for mc.resize
  • AVX2 for cfl4:4:4
  • AVX-512 CDEF filter
  • ARM64 8b improvements for cfl_ac and itxfm
  • ARM64 implementation for emu_edge in 8b/10b/12b
  • ARM32 implementation for emu_edge in 8b
  • Improvements on the dav1dplay utility player to support 10 bit, non-4:2:0 pixel formats and film grain on the GPU
Jean-Baptiste Kempf: dav1d 0.7.0: mobile focus
JoWa skrev:I dag, på WebMs tioårsdag, släpptes libaom v2.0.0 Applejack, en större uppdatering av AV1-referensimplementeringen LibAOM.
Mer om förbättringarna i 2.0.0: https://groups.google.com/a/webmproject ... Cf0oKnBwAJ
AV1 Turns 2.0 (Streaming Learning Center)
Dav1d 0.7.1 ‘Frigatebird’:
0.7.1 is a minor update on 0.7.0:
  • ARM32 NEON optimizations for itxfm, which can give up to 28 % speedup, and MSAC
  • SSE2 optimizations for prep_bilin and prep_8tap
  • AVX2 optimizations for MC scaled
  • Fix a clamping issue in motion vector projection
  • Fix an issue on some specific Haswell CPU on ipred_z AVX2 functions
  • Improvements on the dav1dplay utility player to support resizing
SVT-AV1 v0.8.4
[0.8.4] - 2020-06-26
Build and Testing
  • Bug fixes
  • Improve CI
  • Fix static analysis warnings / errors
  • Add address sanitizer
  • Various ffmpeg patch fixes
https://github.com/OpenVisualCloud/SVT- ... tag/v0.8.4
libVPX 1.9.0 ”Quacking Duck” är på gång. RC1 har släppts.
libvpx v1.9.0-rc1
https://chromium.googlesource.com/webm/ ... v1.9.0-rc1
libvpx v1.9.0 Quacking Duck Released
What’s new:
This release adds support for NV12, a separate library for rate control, as well as incremental improvements.
  • Upgrading:
    • NV12 support is added to this release.
    • A new interface is added for VP9 rate control. The new library libvp9rc.a must be linked by applications.
    • Googletest is updated to v1.10.0.
    • simple_encode.cc is compiled into a new library libsimple_encode.a with CONFIG_RATE_CTRL.
  • Enhancement:
    • Various changes to improve VP9 SVC, rate control, quality and speed to real time encoding.
  • Bug fixes:
    • Fix key frame update refresh simulcast flexible svc.
    • Fix to disable_16x16part speed feature for real time encoding.
    • Fix some signed integer overflows for VP9 rate control.
    • Fix initialization of delta_q_uv.
    • Fix condition in regulate_q for cyclic refresh.
    • Various fixes to dynamic resizing for VP9 SVC.
https://chromium.googlesource.com/webm/ ... ags/v1.9.0
Det är inte varje år som Vorbis-kodaren libvorbis uppdateras, men för drygt en månad sedan skedde det, då 1.3.7 släpptes:
libvorbis 1.3.7 (2020-07-04) — “Xiph.Org libVorbis I 20200704 (Reducing Environment)”
https://github.com/xiph/vorbis/releases
https://xiph.org/downloads/
Sedan jag senast skrev om AV1-kodaren Rav1e, har två nya versioner släppts, 0.32 och 0.33:
https://github.com/xiph/rav1e/releases/tag/v0.3.2
https://github.com/xiph/rav1e/releases/tag/v0.3.3
SVT-AV1 v0.8.5
[0.8.5] - 2020-09-04
Relicensing notice
  • Change the outbound license from BSD+Patent to the AOM license / patent
Encoder
  • Added tpl support to adaptively change lambda and quantization parameters within the frame
  • Added multi staged hme support
  • Quality speed trade-offs tuned to VOD use cases
  • Added first level non-optimized support for 2pass VBR and CRF
  • Added combined cli two pass support with options for stats being written to a memory buffer and a specified file
  • Added non square partitioning optimizations
  • Improved lambda generation
Build and Testing
  • Bug fixes
  • Improve CI
  • Fix symbol conflicts with libaom and libvpx when staticly lined to ffmpeg
https://github.com/OpenVisualCloud/SVT- ... tag/v0.8.5
Rav1e 0.3.4
Improvements
  • Android support
  • iOS support
  • Updated dependencies(dav1d, aom)
  • Fix Desync in some 4K Clips
  • Fix Desync with regard to inter-split bottom-up search
  • Fix compilation of AArch64 target with clang as assembler.
https://github.com/xiph/rav1e/releases/tag/v0.3.4
