Clan - FPS (First Person Shooter) - Vilket spel?
- Smygis
SV: Clan - FPS (First Person Shooter) - Vilket spel?
Min röst ligger på urban Terror!
Det är kul att kolla på utskrifterna i terminalen efter att man kört en match. Speciellt då man stormar dom blåas flagga med en Negev precis innan man drar.
You hit Fr.BoomBoom.Debute.L in the Legs for 11% damage.
You hit Fr.BoomBoom.Debute.L in the Arms for 11% damage.
You hit Fr.BoomBoom.Debute.L in the Kevlar for 20% damage.
Fr.BoomBoom.Debute.L got shredded to pieces by Smygis's Negev
You hit L1nu$ in the Kevlar for 20% damage.
You hit L1nu$ in the Arms for 11% damage.
You hit L1nu$ in the Legs for 11% damage.
L1nu$ got shredded to pieces by Smygis's Negev
You hit tugaman in the Legs for 11% damage.
You hit tugaman in the Kevlar for 20% damage.
tugaman got shredded to pieces by Smygis's Negev
You hit ]SygZ.t[ SheiTaN in the Torso for 30% damage.
You were hit in the Kevlar by ]SygZ.t[ SheiTaN for 29% damage.
You hit Misfit in the Kevlar for 20% damage.
You hit [G] PIGGUTS in the Legs for 11% damage.
You were hit in the Kevlar by Misfit for 20% damage.
You were hit in the Legs by Misfit for 11% damage.
You hit [G] PIGGUTS in the Arms for 11% damage.
You were hit in the Kevlar by [G] PIGGUTS for 20% damage.
Smygis got shredded to pieces by [G] PIGGUTS's Negev
[G] PIGGUTS had 76% Health.
----- CL_Shutdown -----
Closing SDL audio device...
SDL audio device shut down.
RE_Shutdown( 1 )
RE_Shutdown( 1 )
Håller med
Nu ska jag röka sen in i Urban ett tag. Om nån får för sig att starta med, testa sök efter "Zinden" se om den hittar mig.
Jag hoppar in om ca 8 minuter.
Hehe... då ska jag jaga dig...Zinden skrev: Håller med
Vad händer via "Start a server"....
Urban Terror var fan riktigt kul.
Känns som att man börjar få tillbaka teh skillz från ze old days när man lirade CS och skrek och whineade. >_<
- zero gravity
- Wikiadmin
- OS: Arch Linux
Jadu, skoj är det men lite svårt o skrika med huvudet bortskjutet hela tidenNeme skrev: Urban Terror var fan riktigt kul.
Får definitivt träna upp färdigheterna.
Abusus non tollit usum
Jag vill också vara med...
Det var ett tag sen man lirade Clan spel men skoj var det på den tiden det begav sig...
Ska bara bekanta mig lite med dom olika spelen så är jag redo.
Hej, jag provade nyss Urban Terror och jag måste säga att det är grymt kul! Min röst går klart på det. Och jag håller med, skulle vara skoj om en Svensk Ubuntu clan kunde startas.
Boldly going nowhere
Ska vi dra igåg ett lir ikväll med dem som känner sig sugna på Urban Terror?
Tänkte runt 20:00 låter som en vettig tid att starta, då har minsta barnen somnat in iallefall
Vem isåfall kan hosta? Jag vågar inte, sitter med trådlöst. Alla vet att trådlöst lever sitt eget liv ibland.
porten som den använder är 27960, dem som har router måste släppa igenom den porten med UDP.
- DeepThought
- OS: Arch Linux
Fasen, jag som ville spela! Skall ju iväg ikväll, men jag är lätt på en annan dag/tid (inatt, någon?
Förbannat att man lovat bort sig till tv-spelskväll då ^^
Inatt alternativt imorgon kväll skulle funka bra. Jag har en teamspeak-server som bara står, så den kan vi hoppa in på. Någon som vet om det går att köra TS samtidigt som Urban Terror utan några ljudkonflikter?
edit: Ska kolla om min server pallar med en dedikerad server sen när jag kommer hem också.
slutar det med att ingen kan hosta för ikväll så kan jag ställa upp. Det är inget problem, men vad gillar ny för typ av genre i Urban terror?
Capture the flag, Team survivor etc......Jag har spelat mest Capture the flag och Team survivor bara.
- Smygis
Jag tycker CTF är skojigast om man är över 10 st.
Om det blir ett privat lir kanske survivor/DM är bäst.
Hur många blir det? 4-6 st spelare?
Jag kanske spelar.
Jag kanske spelar.
- zero gravity
- Wikiadmin
- OS: Arch Linux
Jag e lätt på, låter som de blir du zinden som får serva.
Ah, tyvärr kan jag inte vara med ikväll. WoW raid
Men, jag antar att det kommer fler tillfällen. Kollar in i denna tråd lite då och då. Skulle vara kul med en Ubuntu Sverige egen tråd avdelning på forumet. Antar att det kommer komma många fler inlägg när clanerna rullar. Lycka till ikväll!
Ställer samma fråga igen.......
Det bästa är ju om vi har någon med en riktig fiberlina helst en BBB 100/100.
Är det bara att klicka på "Start a server" för den som ev har det
ja nästan så plun, men jag tror att det tar ca 5 kb/s för 1 person.....eller var det bara 1 kb/s per person när man kör server.
Alltså inga större farter.....
Kan kolla upp det på urban terror sidan.....
640kbps = 80KB/s
80/8 = 10 players max.
1.5 mbits/s * 1024 / 8 = 192 kbytes/s
with a rate of 8000 bits/s ~ 8 kbit/s
192 / 8 = 24 players
Ungefär hur dem räknar. jag har ca 100 kb/s i upload och det ger 12,5 players
Skall väl inte stjäla så mycket bandbredd.. Skulle det gå åt skogen för Zinden, kan jag testa att hosta (har telia 24/2). Har två goda vänner med bbb 100mbit (windows förvisso) som kanske kan övertalas att hosta om det kniper ordentligt.
Angående att skapa samt confa server kan man läsa här:
http://www.urbanterror.net/urt_manual/server.htm
just, ja.. jag är fetingpå om det blir lir i afton. Har lurat iväg den bättre hälften på grillparty för damer
Ubuntu 10.04 x86 @ AMD Athlon 64 3200+, TwinMos 2048MB PC3200 DDR SDRAM, Nvidia GeForce 6600GT (256MB, PCI-E), SB Audigy 2.
- Smygis
Com'n Är det bara jag online nu då?
SpelaSpelaSpela! Kom igen nu, Det är ju bara detta som har kämpat mig igenom dagen!
Jag är här men måste vänta på ¤%%# FTP att bli klar med upload med min sida som ska bli ATI snart.
Hojtar till så fort jag startar en server ikväll. döper servern till ubuntu-se så att ni kanske ser den.
