Fixar inte lokalt nätverk hemmavid
Hej allesamman!
Till Ozamosi:
Nu försöker jag ytterligare en gång att skriva detta (jag tappade precis bort mitt "genomarbetade" inlägg vid förhandsgranskningen. Det fattades ett "code" i mitt kopiera och klistra in och originalet försvann. Här kommer ett nytt försök.
Så här ser det ut:
#======================= Share Definitions =======================
wins support = no
[homes]
   comment = Home Directories
   browseable = no
# By default, the home directories are exported read-only. Change next
# parameter to 'yes' if you want to be able to write to them.
   writable = no
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
   directory mask = 0700
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   writable = no
;   share modes = no
[printers]
   comment = All Printers
   browseable = no
   path = /tmp
   printable = yes
   public = no
   writable = no
   create mode = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# Replace 'ntadmin' with the name of the group your admin users are
# members of.
;   write list = root, @ntadmin
# A sample share for sharing your CD-ROM with others.
;[cdrom]
;   comment = Samba server's CD-ROM
;   writable = no
;   locking = no
;   path = /cdrom
;   public = yes
# The next two parameters show how to auto-mount a CD-ROM when the
#	cdrom share is accesed. For this to work /etc/fstab must contain
#	an entry like this:
#       /dev/scd0   /cdrom  iso9660 defaults,noauto,ro,user   0 0
# The CD-ROM gets unmounted automatically after the connection to the
# If you don't want to use auto-mounting/unmounting make sure the CD
#	is mounted on /cdrom
;   preexec = /bin/mount /cdrom
;   postexec = /bin/umount /cdrom
[Acermapppåskrivbordet]
path = /home/leif2b
available = yes
browseable = yes
public = yes
writable = yes
Jag gissar att ett och annat =no, skall tas bort/ändras. Men jag varken vågar eller vill göra det utan goda råd.
Därtill behöll jag det sista, bl.a. angående skrivaren. Dit har jag ännu inte hunnit, med att dela ut den i nätet, men idag har jag den ansluten till hustruns dator. Vilket inte behöver vara det slutgiltiga. Men jag noterade ett antal =no även där, så texten togs med.
Har Du förslag även på hur det bör se ut, så är det bra, om inte, så får det bli en senare fråga. Skrivaren behöver absolut inte vara ansluten via en dator utan den kan jag mycket väl tänka mig att koppla direkt till routern.
Nåväl, jag ser tacksamt emot förslag som kan fixa till det så, att utdelade mappar även i Pyttemjuk kan bli åtkomliga. Känn ingen stress med svaret. I natt har min semester börjat och förblir sålunda i fyra veckor.
Fjärran från stress och storstadsvimmel skall jag tillbringa mina dagar med hustru och två kattor i norrlands inland. I min lilla stuga. Dessvärre utan Internet-uppkoppling! :o Munken lär få abstinensbesvär gissar jag. :cool:
Jag kommer att sakna möjligheten att titta in här efter dagens vedermödor. I stället får jag nu sitta där i fattigdom och elände och lyssna på småfåglars skrän m.m. ;)
Till Er alla:
må Sherwood-skogens mjuka lövverk skydda och bevara Eder alla från den grymme Nottingham-sheriffens onda uppsåt och trakasserier och så ses och hörs vi igen i i månadens slut.
Hälsningar Broder Tuck
