Ubuntu Geek rekommenderade följande för hotmail/Evolution:
sudo apt-get install hotway hotsmtp
This will install hotway, which allows you to read hotmail e-mails by simulating a POP3 server, and hotsmtp, which allows you to send e-mail through hotmail using SMTP.
By default, however, only hotway gets installed properly to your inet daemon, so let’s fix this.
sudo gedit /etc/inetd.conf
Look for the following line
pop3 stream tcp nowait nobody /usr/sbin/tcpd /usr/bin/hotwayd
By default, hotway leaves a copy of each message it downloads on the server but if you don’t feel like filling up your hotmail box, change the line to add “-r” to the end, complete line looks like below
pop3 stream tcp nowait nobody /usr/sbin/tcpd /usr/bin/hotwayd -r
And we also need to add a line to get hotsmtpd working, just paste the following line at the bottom of the file
2500 stream tcp nowait nobody /usr/sbin/tcpd /usr/bin/hotsmtpd
Ubuntu Geek rekommenderade följande:
This will set the inet daemon to listen to incoming calls on port 2500, and forward the connection to the hotsmtp daemon. Now, save your file, exit gedit, and restart your inetd server using the following command
sudo /etc/init.d/inetutils-inetd restart
If everything is working properly, you’ll see the following pop up on your screen
* Restarting internet superserver inetd [ ok ]
Now, close out of your terminal and start up Evolution. It may pop up the first-time use wizard, you can use that if you like. Or, you may have to go to Edit->Preferences and hit the Mail Accounts button on the left. However you choose to do it, here’s your information:
Email Address: xxx@hotmail.com (fill in your normal e-mail address that you use to login to hotmail)
Receive Server type: POP
Server: 127.0.0.1
Username: xxx@hotmail.com (same as above)
Security: No encryption
Authentication type: Password
(Remember password checkbox is up to you)
Send Server type: SMTP
Server: 127.0.0.1:2500
[X] Server requires authentication (check this box)
Use Secure Connection: No encryption
Authentication Type: PLAIN
(Optional Remember password checkbox)
Important Update
Re: HOWTO: Send and Receive Hotmail through Evolution
Installation of hotwayd as described in the first post is no longer needed. It is mentioned earlier in this thread, but that info gets snowed under because every time new posts are added…
Since some time now, you can use the following settings just like any regular POP account:
Code:
Incoming server: pop3.live.com
Username: your_username @hotmail.com
Use secure connection: SSL
Authentication type: password
Outgoing server: smtp.live.com
Server requires authentication: yes
Security: SSL
Authentication type: plain
With these settings, you should be able to get is working without going through the hotway daemon (on 127.0.0.1) …
Hotmail och Yahoo problem i Evolution
Re: Hotmail och Yahoo problem i Evolution
http://ubuntuforums.org/showthread.php?t=200408
har en liknande lösning på problemet.
Thanks. However, should be hotsmtp, not hotsmtpd as set out in the third code step in your original post.
Där hittade du en del..
Hoppas någon av dom, kanske båda fungerar oxå...
/MrT
/MrT
Märkligt att Hotmail skall vara så krångligt. Det är kanske förståeligt, då det kommer från en annan värld.
