ut med Windows 95!!
- OS: Crunchbang
Re: ut med Windows 95!!
Jag har gjort en djupdykning i HPs äldre-värld och tillslut funnit det som
redan sagt , men med viss ökad precision.
Author Subject: Compaq 575e Add to my favorites
Nan Gulotta
Feb 15, 2006 21:17:08 GMT
Im about ready to recycle.. if I don't get this old PC to boot floppy or cdrom, the hard drive always tries to boot and it has a problem
I cant find the key for the bios. I have tried everything. Including download a few bios updates. It will not let me in for anything.
I have been fighting with this for 2 weeks and Im tired
HELPPPPP
Note: If you are the author of this question and wish to assign points to any of the answers, please login first.For more information on assigning points ,click here
Sort Answers By: Date or Points
Jim Tully
Feb 16, 2006 21:29:50 GMT 2 pts
It looks to me like you should be able to get into setup via the F10 key: http://h18007.www1.hp.com/support/files ... d/303.html
If your monitor is a little slow to warm up, like mine, look for the green led on the monitor when you boot up and press the F10 key until you get the setup menu. If you can't get into it at all, and your PC refuses to boot to floppy or CD, it may be time to recycle. That would probably mean the motherboard is gone. I've had two of those in the past few months and they acted pretty much like what you're describing. Good luck!
John Kirk ???en_SE.forums.text.=beamingAlt???
Feb 17, 2006 08:46:31 GMT 8 pts
Nan
Try unplugging the ribbon cable from the hard drive. This should force the computer to boot from the floppy.
Hope this helps.
John K.
Jag tog w98 floppy och DSL-CD.
Iom att hålla ner tangenten efter att grön LCD på skärmen tänds och RAM-bank räknat ut.
Så boot ar PCn från Floppy.
Dock inträffar inte övergången till DSL. Trotts val "installation från CD".
PCn stannar i läge
A:\>
Jag ska prova med Puppy också.
Nan Gulotta
HELPPPPP
Jim Tully
Nan
Hope this helps.
John K.
PCn stannar i läge
A:\>
- OS: Crunchbang
Nix, det gick inte med Puppy heller............men , jag har bytt PC och den här har BARA 16M.
Ojj...ska prov att flytta 64M till den här.
"riktigt ingenjörjobb" mmmm trivs
Viktigt när du ska in i bios, du ska inte hålla F10 nedtryckt, utan tiptappa den...
- Konservburk
Om du har väldigt lite RAM och bara kan boota till DOS så kanske BasicLinux kan vara något...
http://distro.ibiblio.org/pub/linux/dis ... /baslinux/
- OS: Crunchbang
Hmmmm....då vet jag inte om första steget var rätt????Viktigt när du ska in i bios, du ska inte hålla F10 nedtryckt, utan tiptappa den...
Jag har nu iaf provat flera alternativ med samma resultat som tidigare.
Det är nu 49MB DRAM.
Men nu blir jag frågande varför CD inte startar alls.......(Där har jag inte pillat alls (på den här
Mao den stannar i
A:\>
- OS: Crunchbang
Menar du att CDn känner avi tidigt stadige vilken RAM-bank som krävs.Om du har väldigt lite RAM och bara kan boota till DOS så kanske BasicLinux kan vara något...
What is DSL?
Damn Small Linux is a very versatile 50MB mini desktop oriented Linux distribution.
Damn Small is small enough and smart enough to do the following things:
* Boot from a business card CD as a live linux distribution (LiveCD)
* Boot from a USB pen drive
* Boot from within a host operating system (that's right, it can run *inside* Windows)
* Run very nicely from an IDE Compact Flash drive via a method we call "frugal install"
* Transform into a Debian OS with a traditional hard drive install
* Run light enough to power a 486DX with 16MB of Ram
* Run fully in RAM with as little as 128MB (you will be amazed at how fast your computer can be!)
* Modularly grow -- DSL is highly extendable without the need to customize
Det här funkar iaf inte.
Jag ska prova en CD med BasicLinux
yesss en ny dist
Tryck en gång per sekund. Ta i vattenkran eller ett vattenburet element då du flyttar ram-minnen, för att ta bort statisk elektricitet. Tror inte det bara är att gå in på elgiganten för att köpa nya:)
- OS: Crunchbang
Då så har jag en folder med BasicLinux på Skrivbordet och det är avsedd för att Boota en PC från floppy.
Men då är det så att det är nytt (nygammalt) gör mig.
Ska jag koppiera innehållet av folder till Floppy'n och Boota PCn som tidigare (grön LED , f10/sek -> invänta Boot-från-Floppy)?
Eller ska min enda lösa/tomma Floppy prepareras på annat sätt?
- Konservburk
Jag tror du behöver två stycken. Men det skulle kunna gå att plocka ut den första när den har laddat och sedan skriva över med den andra och stoppa in den igen.Hans Linde skrev:Eller ska min enda lösa/tomma Floppy prepareras på annat sätt?
- OS: Crunchbang
Det för mycket på en Floppy.
Så hur gör jag med detta?
- bl3.png (18.54 KiB) Visad 2025 gånger
- OS: Crunchbang
I PCn med Floppy driveförsöker jag flytta DISK1.IMG från Skrivbord till Floppy men inget av de sätt jag känner till funkar.
Hur gör jag?
EDIT:
Den är 1,4MB stor......fixa en floppy det? Hmm..jag tror att jag minns 2.1M eller....
Hur gör jag?
EDIT:
- Konservburk
DISK1.IMG är en avbild. Den kopierar du så här:
Sedan bootar du från den, och när den ber om den andra så plockar du ut den första, formaterar om den, och kopierar in disk2.tgz på det vanliga sättet.
sudo dd if=DISK1.IMG of=/dev/fd0 bs=512 count=2880
- OS: Crunchbang
Steg 1 o 2 gick fint.
Dvs Info 1 till Floppy.....och Info 1 Boot'ar snällt i "PCäldre".
Dock har jag samma problem med nästa Floppy.
(hitta en till .........otroligt
Varken dne kompimerade eller de två foldrarna som DISK2.TGZ innehåller kan flyttas till Floppy.
På det viset som jag gör iaf.
- Konservburk
Du ska bara kopiera DISK2.TGZ direkt utan konstigheter. Menar du att den inte får plats?
sudo mkdosfs /dev/fd0
sudo mount /dev/fd0 /mnt
sudo cp DISK2.TGZ /mnt/disk2.tgz
sudo umount /mnt
- OS: Crunchbang
Nja ...Det är något i börja som gör att inget flyttas till Floppy'n.
se bild
EDIT.
Jag är den första i världen att missa det bifogade...men nu.
se bild
EDIT.
- disk2.png (66.94 KiB) Visad 1986 gånger
- OS: Crunchbang
Jo Uuupps........ursäkta ...skitbakom spakarna.
återkommer
återkommer
- OS: Crunchbang
Nähä.......inte iaf.
a@a:~/Skrivbord/bl3-50fd$
a@a:~/Skrivbord/bl3-50fd$ sudo mkdosfs /dev/fd0
mkdosfs 2.11 (12 Mar 2005)
mkdosfs: /dev/fd0 contains a mounted file system.
a@a:~/Skrivbord/bl3-50fd$ sudo mount /dev/fd0 /mnt
a@a:~/Skrivbord/bl3-50fd$ sudo cp DISK2.TZG /mnt/disk2.tgz
cp: kan inte ta status på "DISK2.TZG": Filen eller katalogen finns inte
a@a:~/Skrivbord/bl3-50fd$ sudo umount /mnt
Jag provar nu
Kvack............när jag försöker öppa Floppy med Nautilus för att Formatera och börja från börja.......
.....då blir den troligen monterad och då skrivs resten in tror jag.
Jaf provar iaf med den här Floppy
Jag provar nu
- disk2b.png (58.15 KiB) Visad 1980 gånger
- Konservburk
Du får inte ha den monterad när du gör ett nytt filsystem på den. Avmontera den först. Jag antar att du kan högerklicka på den i nautilus. Annars gör du så här från en terminal:Hans Linde skrev:mkdosfs: /dev/fd0 contains a mounted file system.
sudo umount /dev/fd0
Jag råkade stava fel. Det ska ju vara DISK2.TGZ (och inte .TZG).Hans Linde skrev:cp: kan inte ta status på "DISK2.TZG": Filen eller katalogen finns inte
- OS: Crunchbang
Nej tyvärr. Den Floppy var inte uppskattad.
Så här ser det ut på skärmen
Insert floppy 2 and press ENTER
mount: mounting /dev/fd0 on /fd failed: Device or resources busy
zcat: fd/disk2.tgz: No such file or directory
Insert flopppy 2 and pess ENTER
Kan det tagit för lång tid som jag bör göra om det?
Nu har jag två floppy klara.
Eller?
Eller?
- OS: Crunchbang
problem 2
Töm floppy 2 från felaktig "disk 2" info.
hur gör jag?
hur gör jag?
