hjälp med att skriva script [LÖST]
william
SV: hjälp med att skriva script
Inlägg av william »
och du ville kolla på loggfilen:
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Ubuntu (xorg-server 2:1.3.0.0.dfsg-12ubuntu8)
Current Operating System: Linux william-desktop 2.6.22-14-386 #1 Tue Dec 18 07:34:24 UTC 2007 i686
Build Date: 29 September 2007
	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan 15 13:43:10 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Videocard0"
(**) |-->Screen "Screen1" (1)
(**) |   |-->Monitor "Monitor1"
(**) |   |-->Device "Videocard1"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
(**) Option "Xinerama" "0"
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
	Entry deleted from font path.
(==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/75dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(**) RgbPath set to "/usr/lib/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81ea440
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 1.2
	X.Org XInput driver : 0.7
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.0.0
	ABI class: X.Org Video Driver, version 1.2
(++) using VT number 9
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3189 card 1106,3189 rev 80 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b198 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:0f:0: chip 1106,3149 card 1106,3149 rev 80 class 01,01,8f hdr 80
(II) PCI: 00:0f:1: chip 1106,0571 card 1106,0571 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 1106,3038 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 1106,3038 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 1106,3038 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3038 card 1106,3038 rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:4: chip 1106,3104 card 1106,3104 rev 86 class 0c,03,20 hdr 80
(II) PCI: 00:11:0: chip 1106,3227 card 1106,3227 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:5: chip 1106,3059 card 270f,7555 rev 60 class 04,01,00 hdr 00
(II) PCI: 00:12:0: chip 1106,3065 card 1106,0102 rev 78 class 02,00,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0253 card 0000,0000 rev a3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xec000000 - 0xedffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xd8000000 - 0xe7ffffff (0x10000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV25 [GeForce4 Ti 4200] rev 163, Mem @ 0xec000000/24, 0xd8000000/27, 0xe0000000/19
(II) Addressable bus resource ranges are
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe8000000 from 0xebffffff to 0xe7ffffff
(II) Active PCI resource ranges:
	[0] -1	0	0xee001000 - 0xee0010ff (0x100) MX[B]
	[1] -1	0	0xee000000 - 0xee0000ff (0x100) MX[B]
	[2] -1	0	0xe8000000 - 0xe7ffffff (0x0) MX[B]O
	[3] -1	0	0xe0000000 - 0xe007ffff (0x80000) MX[B](B)
	[4] -1	0	0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
	[5] -1	0	0xec000000 - 0xecffffff (0x1000000) MX[B](B)
	[6] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[7] -1	0	0x0000eb00 - 0x0000ebff (0x100) IX[B]
	[8] -1	0	0x0000ea00 - 0x0000ea1f (0x20) IX[B]
	[9] -1	0	0x0000e900 - 0x0000e91f (0x20) IX[B]
	[10] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
	[11] -1	0	0x0000e700 - 0x0000e71f (0x20) IX[B]
	[12] -1	0	0x0000e600 - 0x0000e60f (0x10) IX[B]
	[13] -1	0	0x0000e500 - 0x0000e5ff (0x100) IX[B]
	[14] -1	0	0x0000e400 - 0x0000e40f (0x10) IX[B]
	[15] -1	0	0x0000e300 - 0x0000e303 (0x4) IX[B]
	[16] -1	0	0x0000e200 - 0x0000e207 (0x8) IX[B]
	[17] -1	0	0x0000e100 - 0x0000e103 (0x4) IX[B]
	[18] -1	0	0x0000e000 - 0x0000e007 (0x8) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xee001000 - 0xee0010ff (0x100) MX[B]
	[5] -1	0	0xee000000 - 0xee0000ff (0x100) MX[B]
	[6] -1	0	0xe8000000 - 0xe7ffffff (0x0) MX[B]O
	[7] -1	0	0xe0000000 - 0xe007ffff (0x80000) MX[B](B)
	[8] -1	0	0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
	[9] -1	0	0xec000000 - 0xecffffff (0x1000000) MX[B](B)
	[10] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[11] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[12] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[13] -1	0	0x0000eb00 - 0x0000ebff (0x100) IX[B]
	[14] -1	0	0x0000ea00 - 0x0000ea1f (0x20) IX[B]
	[15] -1	0	0x0000e900 - 0x0000e91f (0x20) IX[B]
	[16] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
	[17] -1	0	0x0000e700 - 0x0000e71f (0x20) IX[B]
	[18] -1	0	0x0000e600 - 0x0000e60f (0x10) IX[B]
	[19] -1	0	0x0000e500 - 0x0000e5ff (0x100) IX[B]
	[20] -1	0	0x0000e400 - 0x0000e40f (0x10) IX[B]
	[21] -1	0	0x0000e300 - 0x0000e303 (0x4) IX[B]
	[22] -1	0	0x0000e200 - 0x0000e207 (0x8) IX[B]
	[23] -1	0	0x0000e100 - 0x0000e103 (0x4) IX[B]
	[24] -1	0	0x0000e000 - 0x0000e007 (0x8) IX[B]
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
	Module class: X.Org Server Extension
	ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(WW) Warning, couldn't open module type1
(II) UnloadModule: "type1"
(EE) Failed to load module "type1" (module does not exist, 0)
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
	compiled for 1.3.0, module version = 2.1.0
	Module class: X.Org Font Renderer
	ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
	compiled for 4.0.2, module version = 1.0.0
	ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module  96.43.01  Wed Sep  5 19:47:01 PDT 2007
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
	Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
	compiled for 1.3.0, module version = 1.2.1
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 0.7
william
Inlägg av william »
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
(II) NVIDIA dlloader X Driver  96.43.01  Wed Sep  5 19:14:11 PDT 2007
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
	ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
	[10] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
	[11] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
	[12] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
	[13] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[14] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[15] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[16] -1	0	0x0000eb00 - 0x0000ebff (0x100) IX[B]
	[17] -1	0	0x0000ea00 - 0x0000ea1f (0x20) IX[B]
	[18] -1	0	0x0000e900 - 0x0000e91f (0x20) IX[B]
	[19] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
	[20] -1	0	0x0000e700 - 0x0000e71f (0x20) IX[B]
	[21] -1	0	0x0000e600 - 0x0000e60f (0x10) IX[B]
	[22] -1	0	0x0000e500 - 0x0000e5ff (0x100) IX[B]
	[23] -1	0	0x0000e400 - 0x0000e40f (0x10) IX[B]
	[24] -1	0	0x0000e300 - 0x0000e303 (0x4) IX[B]
	[25] -1	0	0x0000e200 - 0x0000e207 (0x8) IX[B]
	[26] -1	0	0x0000e100 - 0x0000e103 (0x4) IX[B]
	[27] -1	0	0x0000e000 - 0x0000e007 (0x8) IX[B]
	[28] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
	[29] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Setting vga for screen 1.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "MetaModes" "CRT: nvidia-auto-select +0+0; CRT: 1024x768_75 +0+0"
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0):     enabled.
(II) NVIDIA(0): NVIDIA GPU GeForce4 Ti 4200 at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 131072 kBytes
(--) NVIDIA(0): VideoBIOS: 04.25.00.37.00
(II) NVIDIA(0): Detected AGP rate: 4X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce4 Ti 4200 at PCI:1:0:0:
(--) NVIDIA(0):     Lite-On e1770NSL/T (CRT-1)
(--) NVIDIA(0):     Philips 7102 TV Encoder (TV-0)
(--) NVIDIA(0): Lite-On e1770NSL/T (CRT-1): 350.0 MHz maximum pixel clock
(--) NVIDIA(0): Philips 7102 TV Encoder (TV-0): 165.0 MHz maximum pixel clock
(--) NVIDIA(0): TV encoder: Philips 7102
(II) NVIDIA(0): Display Device found referenced in MetaMode: CRT-1
(II) NVIDIA(0): Assigned Display Device: CRT-1
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):     "CRT:nvidia-auto-select+0+0"
(II) NVIDIA(0):     "CRT:1024x768_75+0+0"
(II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
(--) NVIDIA(0): DPI set to (81, 81); computed from "UseEdidDpi" X config
(--) NVIDIA(0):     option
(**) NVIDIA(1): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(1): RGB weight 888
(==) NVIDIA(1): Default visual is TrueColor
(==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(1): Option "MetaModes" "TV: nvidia-auto-select +0+0"
(**) NVIDIA(1): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(1): Enabling RENDER acceleration
(II) NVIDIA(1): NVIDIA GPU GeForce4 Ti 4200 at PCI:1:0:0 (GPU-0)
(--) NVIDIA(1): Memory: 131072 kBytes
(--) NVIDIA(1): VideoBIOS: 04.25.00.37.00
(II) NVIDIA(1): Detected AGP rate: 4X
(--) NVIDIA(1): Interlaced video modes are supported on this GPU
(--) NVIDIA(1): Connected display device(s) on GeForce4 Ti 4200 at PCI:1:0:0:
(--) NVIDIA(1):     Lite-On e1770NSL/T (CRT-1)
(--) NVIDIA(1):     Philips 7102 TV Encoder (TV-0)
(--) NVIDIA(1): Lite-On e1770NSL/T (CRT-1): 350.0 MHz maximum pixel clock
(--) NVIDIA(1): Philips 7102 TV Encoder (TV-0): 165.0 MHz maximum pixel clock
(--) NVIDIA(1): TV encoder: Philips 7102
(II) NVIDIA(1): Display Device found referenced in MetaMode: TV-0
(II) NVIDIA(1): Assigned Display Device: TV-0
(II) NVIDIA(1): Validated modes:
(II) NVIDIA(1):     "TV:nvidia-auto-select+0+0"
(II) NVIDIA(1): Virtual screen size determined to be 800 x 600
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) NVIDIA(0): Primary V_BIOS segment is: 0xc000
(==) NVIDIA(1): DPI set to (75, 75); computed from built-in default
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  Yes, I do.
(II) resource ranges after preInit:
	[0] 0	0	0xe0000000 - 0xe007ffff (0x80000) MX[B]
	[1] 0	0	0xd8000000 - 0xdfffffff (0x8000000) MX[B]
	[2] 0	0	0xec000000 - 0xecffffff (0x1000000) MX[B]
	[3] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[4] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[5] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[6] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[7] -1	0	0xee001000 - 0xee0010ff (0x100) MX[B]
	[8] -1	0	0xee000000 - 0xee0000ff (0x100) MX[B]
	[9] -1	0	0xe8000000 - 0xe7ffffff (0x0) MX[B]O
	[10] -1	0	0xe0000000 - 0xe007ffff (0x80000) MX[B](B)
	[11] -1	0	0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
	[12] -1	0	0xec000000 - 0xecffffff (0x1000000) MX[B](B)
	[13] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
	[14] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
	[15] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
	[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[17] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[18] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[19] -1	0	0x0000eb00 - 0x0000ebff (0x100) IX[B]
	[20] -1	0	0x0000ea00 - 0x0000ea1f (0x20) IX[B]
	[21] -1	0	0x0000e900 - 0x0000e91f (0x20) IX[B]
	[22] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
	[23] -1	0	0x0000e700 - 0x0000e71f (0x20) IX[B]
	[24] -1	0	0x0000e600 - 0x0000e60f (0x10) IX[B]
	[25] -1	0	0x0000e500 - 0x0000e5ff (0x100) IX[B]
	[26] -1	0	0x0000e400 - 0x0000e40f (0x10) IX[B]
	[27] -1	0	0x0000e300 - 0x0000e303 (0x4) IX[B]
	[28] -1	0	0x0000e200 - 0x0000e207 (0x8) IX[B]
	[29] -1	0	0x0000e100 - 0x0000e103 (0x4) IX[B]
	[30] -1	0	0x0000e000 - 0x0000e007 (0x8) IX[B]
	[31] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
	[32] 0	0	0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "CRT:nvidia-auto-select+0+0"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) NVIDIA(1): Setting mode "TV:nvidia-auto-select+0+0"
(II) NVIDIA(1): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(1): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(1): Backing store disabled
(==) NVIDIA(1): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(1): DPMS enabled
(==) RandR enabled
(II) Entity 0 shares no resources
(II) Entity 1 shares no resources
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "CoreKeyboard"
(**) Keyboard0: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard0: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/psaux"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Device" "/dev/psaux"
(**) Option "Emulate3Buttons" "no"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse0: ZAxisMapping: buttons 4 and 5
(**) Mouse0: Buttons: 9
(**) Mouse0: Sensitivity: 1
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(--) Mouse0: PnP-detected protocol: "ExplorerPS/2"
(II) Mouse0: ps2EnableDataReporting: succeeded
AUDIT: Tue Jan 15 13:43:13 2008: 6992 X: client 2 rejected from local host (uid 1000)
(II) Screen 0 shares mem & io resources
(II) Screen 1 shares mem & io resources
(II) NVIDIA(0): Setting mode "CRT:1024x768_75+0+0"
SetClientVersion: 0 9
(den var mer än 2000 tecken så jag delade upp den)
william
Inlägg av william »
det funkar fint förutom att det inte kommer något ljud.
vad ska jag göra för att ljudet ska fungera? det fungerar om jag startar en film vanligt på bildskärmen.
Konservburk
Inlägg av Konservburk »
Jag gissar att du kopierade mitt tv-alias rakt av?  Eftersom min tv står i ett
annat rum så måste jag se till att ljudet kommer till tv-högtalarna istället för
datorhögtalarna.  För att lyckas med det så har jag skapat en ny alsa-enhet
som jag kallat för "tv".  För att göra en lång historia kort... du måste ta bort
-ao alsa:device=tv från mitt alias för att ljudet ska fungera för dig.
william
Inlägg av william »
Nu funkgerar allt bättre än jag trodde det någonsin skulle!
Tack för all hjälp! Hyggligt.
