super_pi -ett benchmarkprogram, posta resultat
SV: super_pi -ett benchmarkprogram, posta resultat
AMD Athlon 64 X2 4400+  2GB RAM
$ ./super_pi 20
 Version 2.0 of the super_pi for Linux OS
 Fortran source program was translated into C program with version 19981204 of
 f2c, then generated C source program was optimized manually.
 pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minline=size:1000 -Mnoframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used for the
 compilation.
 ------ Started super_pi run : Mon Jan 28 22:58:53 CET 2008
 Start of PI calculation up to 1048576 decimal digits
 End of initialization. Time=       0.644 Sec.
 I= 1 L=       0        Time=       1.392 Sec.
 I= 2 L=       0        Time=       1.576 Sec.
 I= 3 L=       1        Time=       1.580 Sec.
 I= 4 L=       2        Time=       1.596 Sec.
 I= 5 L=       5        Time=       1.588 Sec.
 I= 6 L=      10        Time=       1.592 Sec.
 I= 7 L=      21        Time=       1.600 Sec.
 I= 8 L=      43        Time=       1.584 Sec.
 I= 9 L=      87        Time=       1.600 Sec.
 I=10 L=     174        Time=       1.580 Sec.
 I=11 L=     349        Time=       1.580 Sec.
 I=12 L=     698        Time=       1.588 Sec.
 I=13 L=    1396        Time=       1.596 Sec.
 I=14 L=    2794        Time=       1.588 Sec.
 I=15 L=    5588        Time=       1.604 Sec.
 I=16 L=   11176        Time=       1.580 Sec.
 I=17 L=   22353        Time=       1.552 Sec.
 I=18 L=   44707        Time=       1.504 Sec.
 I=19 L=   89415        Time=       1.388 Sec.
 End of main loop
 End of calculation.    Time=      31.554 Sec.
 End of data output.    Time=       0.160 Sec.
 Total calculation(I/O) time=      31.714(       0.992) Sec.
 ------ Ended super_pi run : Mon Jan 28 22:59:26 CET 2008
nire
Inlägg av nire »
Kan inte någon med dual-boot skicka ett test gjort under ubuntu resp. windows? Som en jämförelse tänkte jag.  :)
Cadryc
Inlägg av Cadryc »
Intel Core 2 Quad 2,4GHz (Q6600), testet till ära klockad till 3,0GHz. 3GiB RAM. 32bit Ubuntu 7.10
I=13 L=    1396        Time=       0.636 Sec.
 I=14 L=    2794        Time=       0.636 Sec.
 I=15 L=    5588        Time=       0.640 Sec.
 I=16 L=   11176        Time=       0.628 Sec.
 I=17 L=   22353        Time=       0.616 Sec.
 I=18 L=   44707        Time=       0.600 Sec.
 I=19 L=   89415        Time=       0.552 Sec.
 End of main loop
 End of calculation.    Time=      12.605 Sec.
 End of data output.    Time=       0.084 Sec.
 Total calculation(I/O) time=      12.689(       0.532) Sec.
 ------ Ended super_pi run : tor feb 14 13:24:05 CET 2008
Kan tillägga att jag dödade alla processer jag vågade för att optimera, men det gjorde inte så stor skillnad. Resultaten pendlade mellan 15-12 sekunder (20-16 sekunder vid 2,4GHz) även när Compiz och massa andra program kördes som vanligt, antar att det är tack vare att det är flera kärnor. Appropå det så verkade det som att bara en kärna användes till Super-pi, enligt Systemövervakaren var det en kärna som gick på 100% och de andra låg mellan 0-10%
Prövade även i xp (dualboot), där låg det stadigt på 17s vid 3,0GHz respektive 19s vid 2,4GHz. Här var det dock ingen kärna som gick upp till 100%, antar att xp och Ubuntu behandlar flerkärniga processorer olika. Prövade även i virtuellt xp i Virtualbox (1GiB RAM) och där låg det stadigt på 24s vid 2,4GHz
zenbios
Inlägg av zenbios »
Var tvungen att bräcka Cadryc bara. :)
quad Q6700@3424MHz 4x1G RAM ratio 1:2 (så det kommer bättre resultat när det ligger 1:1)
En kärna gick bara fullt, men bättre resultat här än i vista.
 ------ Started super_pi run : tis feb 26 17:20:06 CET 2008
 End of initialization. Time=       0.188 Sec.
 I= 1 L=       0        Time=       0.500 Sec.
 I= 2 L=       0        Time=       0.572 Sec.
 I= 3 L=       1        Time=       0.572 Sec.
 I= 4 L=       2        Time=       0.572 Sec.
 I= 5 L=       5        Time=       0.588 Sec.
 I= 6 L=      10        Time=       0.572 Sec.
 I= 7 L=      21        Time=       0.568 Sec.
 I= 8 L=      43        Time=       0.568 Sec.
 I= 9 L=      87        Time=       0.572 Sec.
 I=10 L=     174        Time=       0.568 Sec.
 I=11 L=     349        Time=       0.568 Sec.
 I=12 L=     698        Time=       0.568 Sec.
 I=13 L=    1396        Time=       0.568 Sec.
 I=14 L=    2794        Time=       0.572 Sec.
 I=15 L=    5588        Time=       0.564 Sec.
 I=16 L=   11176        Time=       0.560 Sec.
 I=17 L=   22353        Time=       0.552 Sec.
 I=18 L=   44707        Time=       0.536 Sec.
 I=19 L=   89415        Time=       0.496 Sec.
 End of main loop
 End of calculation.    Time=      11.257 Sec.
 End of data output.    Time=       0.076 Sec.
 Total calculation(I/O) time=      11.333(       0.464) Sec.
 ------ Ended super_pi run : tis feb 26 17:20:17 CET 2008
nicefinger
Re: super_pi -ett benchmarkprogram, posta resultat
Inlägg av nicefinger »
Celeron D 3.06 GHz 1 GB Ram
 I=19 L=   89415        Time=       1.944 Sec.
 End of main loop
 End of calculation.    Time=      43.339 Sec.
 End of data output.    Time=       0.168 Sec.
 Total calculation(I/O) time=      43.507(       1.000) Sec.
 ------ Ended super_pi run : sön mar 16 11:29:34 CET 2008
Nya datorn som provkörs .. sladdarna hänger utanför och hårdisken ligger lös.
(Jag min stolle installerade Linux Mint Cassandra 3.0 på den .. bygger på Ubuntu 7.04.
Grep en skiva det stod "Mint" på bara :()
Bossieman
Inlägg av Bossieman »
Har jag snabbaste laptopen?
leif@ubuntu:~/super_pi$ ./super_pi 20
compilation.
------ Started super_pi run : tis apr 1 21:25:23 CEST 2008
End of initialization. Time= 0.252 Sec.
I= 1 L= 0 Time= 0.644 Sec.
I= 2 L= 0 Time= 0.736 Sec.
I= 3 L= 1 Time= 0.728 Sec.
I= 4 L= 2 Time= 0.732 Sec.
I= 5 L= 5 Time= 0.736 Sec.
I= 6 L= 10 Time= 0.728 Sec.
I= 7 L= 21 Time= 0.732 Sec.
I= 8 L= 43 Time= 0.732 Sec.
I= 9 L= 87 Time= 0.740 Sec.
I=10 L= 174 Time= 0.728 Sec.
I=11 L= 349 Time= 0.732 Sec.
I=12 L= 698 Time= 0.732 Sec.
I=13 L= 1396 Time= 0.728 Sec.
I=14 L= 2794 Time= 0.732 Sec.
I=15 L= 5588 Time= 0.736 Sec.
I=16 L= 11176 Time= 0.724 Sec.
I=17 L= 22353 Time= 0.712 Sec.
I=18 L= 44707 Time= 0.692 Sec.
I=19 L= 89415 Time= 0.640 Sec.
End of main loop
End of calculation. Time= 14.473 Sec.
End of data output. Time= 0.088 Sec.
Total calculation(I/O) time= 14.561( 0.688) Sec.
------ Ended super_pi run : tis apr 1 21:25:38 CEST 2008
Core 2 Duo T9300@2.5 GHz 2GB ram
weaver73
Inlägg av weaver73 »
Sempron 2600+, 768 RAM
 ------ Started super_pi run : ons apr 2 10:20:17 CEST 2008
 End of initialization. Time=       0.780 Sec.
 I= 1 L=       0        Time=       2.500 Sec.
 I= 2 L=       0        Time=       2.852 Sec.
 I= 3 L=       1        Time=       2.860 Sec.
 I= 4 L=       2        Time=       2.856 Sec.
 I= 5 L=       5        Time=       2.868 Sec.
 I= 6 L=      10        Time=       2.848 Sec.
 I= 7 L=      21        Time=       2.860 Sec.
 I= 8 L=      43        Time=       2.860 Sec.
 I= 9 L=      87        Time=       2.856 Sec.
 I=10 L=     174        Time=       2.872 Sec.
 I=11 L=     349        Time=       2.856 Sec.
 I=12 L=     698        Time=       2.856 Sec.
 I=13 L=    1396        Time=       2.852 Sec.
 I=14 L=    2794        Time=       2.852 Sec.
 I=15 L=    5588        Time=       2.848 Sec.
 I=16 L=   11176        Time=       2.832 Sec.
 I=17 L=   22353        Time=       2.800 Sec.
 I=18 L=   44707        Time=       2.720 Sec.
 I=19 L=   89415        Time=       2.512 Sec.
 End of main loop
 End of calculation.    Time=      56.432 Sec.
 End of data output.    Time=       0.228 Sec.
 Total calculation(I/O) time=      56.660(       1.412) Sec.
 ------ Ended super_pi run : ons apr 2 10:21:17 CEST 2008
Geraner
Inlägg av Geraner »
My server = Pentium II - 400 MHz - 324 MB RAM
 ------ Started super_pi run : Tue Apr 8 21:54:07 CEST 2008
 End of initialization. Time=       3.240 Sec.
 I= 1 L=       0        Time=      10.000 Sec.
 I= 2 L=       0        Time=      11.370 Sec.
 I= 3 L=       1        Time=      11.440 Sec.
 I= 4 L=       2        Time=      11.410 Sec.
 I= 5 L=       5        Time=      11.330 Sec.
 I= 6 L=      10        Time=      11.400 Sec.
 I= 7 L=      21        Time=      11.350 Sec.
 I= 8 L=      43        Time=      11.380 Sec.
 I= 9 L=      87        Time=      11.380 Sec.
 I=10 L=     174        Time=      11.370 Sec.
 I=11 L=     349        Time=      11.400 Sec.
 I=12 L=     698        Time=      11.410 Sec.
 I=13 L=    1396        Time=      11.320 Sec.
 I=14 L=    2794        Time=      11.330 Sec.
 I=15 L=    5588        Time=      11.310 Sec.
 I=16 L=   11176        Time=      11.250 Sec.
 I=17 L=   22353        Time=      11.110 Sec.
 I=18 L=   44707        Time=      10.750 Sec.
 I=19 L=   89415        Time=       9.980 Sec.
 End of main loop
 End of calculation.    Time=     224.430 Sec.
 End of data output.    Time=       1.090 Sec.
 Total calculation(I/O) time=     225.520(       8.060) Sec.
 ------ Ended super_pi run : Tue Apr 8 21:57:54 CEST 2008
Min stationär dator - AMD Athlon(tm) XP 2500+ - 1 GB RAM
 ------ Started super_pi run : Sun Apr 27 18:58:34 CEST 2008
 End of initialization. Time=       0.732 Sec.
 I= 1 L=       0        Time=       2.404 Sec.
 I= 2 L=       0        Time=       2.780 Sec.
 I= 3 L=       1        Time=       2.756 Sec.
 I= 4 L=       2        Time=       2.776 Sec.
 I= 5 L=       5        Time=       2.780 Sec.
 I= 6 L=      10        Time=       2.772 Sec.
 I= 7 L=      21        Time=       2.748 Sec.
 I= 8 L=      43        Time=       2.772 Sec.
 I= 9 L=      87        Time=       2.784 Sec.
 I=10 L=     174        Time=       2.760 Sec.
 I=11 L=     349        Time=       2.792 Sec.
 I=12 L=     698        Time=       2.760 Sec.
 I=13 L=    1396        Time=       2.756 Sec.
 I=14 L=    2794        Time=       2.780 Sec.
 I=15 L=    5588        Time=       2.736 Sec.
 I=16 L=   11176        Time=       2.764 Sec.
 I=17 L=   22353        Time=       2.712 Sec.
 I=18 L=   44707        Time=       2.644 Sec.
 I=19 L=   89415        Time=       2.484 Sec.
 End of main loop
 End of calculation.    Time=      54.719 Sec.
 End of data output.    Time=       0.212 Sec.
 Total calculation(I/O) time=      54.931(       1.760) Sec.
 ------ Ended super_pi run : Sun Apr 27 18:59:31 CEST 2008
Min gamla bärbara dator - Intel(R) Pentium(R) M processor 1.80GHz - 1 GB RAM
 ------ Started super_pi run : Tue Apr 8 22:18:47 CEST 2008
 End of initialization. Time=       0.460 Sec.
 I= 1 L=       0        Time=       1.572 Sec.
 I= 2 L=       0        Time=       1.836 Sec.
 I= 3 L=       1        Time=       1.840 Sec.
 I= 4 L=       2        Time=       1.836 Sec.
 I= 5 L=       5        Time=       1.884 Sec.
 I= 6 L=      10        Time=       1.848 Sec.
 I= 7 L=      21        Time=       1.844 Sec.
 I= 8 L=      43        Time=       1.832 Sec.
 I= 9 L=      87        Time=       1.828 Sec.
 I=10 L=     174        Time=       1.872 Sec.
 I=11 L=     349        Time=       1.824 Sec.
 I=12 L=     698        Time=       1.828 Sec.
 I=13 L=    1396        Time=       1.852 Sec.
 I=14 L=    2794        Time=       1.828 Sec.
 I=15 L=    5588        Time=       1.848 Sec.
 I=16 L=   11176        Time=       1.832 Sec.
 I=17 L=   22353        Time=       1.796 Sec.
 I=18 L=   44707        Time=       1.764 Sec.
 I=19 L=   89415        Time=       1.652 Sec.
 End of main loop
 End of calculation.    Time=      36.302 Sec.
 End of data output.    Time=       0.208 Sec.
 Total calculation(I/O) time=      36.510(       0.932) Sec.
 ------ Ended super_pi run : Tue Apr 8 22:19:27 CEST 2008
Min nya LG Laptop - Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz - 2 GB RAM - Ubuntu Gutsy
------ Started super_pi run : Tue Apr 8 22:02:10 CEST 2008
 End of initialization. Time=       0.280 Sec.
 I= 1 L=       0        Time=       0.852 Sec.
 I= 2 L=       0        Time=       0.972 Sec.
 I= 3 L=       1        Time=       0.996 Sec.
 I= 4 L=       2        Time=       1.132 Sec.
 I= 5 L=       5        Time=       1.040 Sec.
 I= 6 L=      10        Time=       1.064 Sec.
 I= 7 L=      21        Time=       1.012 Sec.
 I= 8 L=      43        Time=       0.992 Sec.
 I= 9 L=      87        Time=       1.076 Sec.
 I=10 L=     174        Time=       0.996 Sec.
 I=11 L=     349        Time=       0.988 Sec.
 I=12 L=     698        Time=       0.996 Sec.
 I=13 L=    1396        Time=       0.988 Sec.
 I=14 L=    2794        Time=       0.976 Sec.
 I=15 L=    5588        Time=       0.972 Sec.
 I=16 L=   11176        Time=       0.960 Sec.
 I=17 L=   22353        Time=       0.956 Sec.
 I=18 L=   44707        Time=       0.916 Sec.
 I=19 L=   89415        Time=       0.872 Sec.
 End of main loop
 End of calculation.    Time=      19.777 Sec.
 End of data output.    Time=       0.124 Sec.
 Total calculation(I/O) time=      19.901(       0.732) Sec.
 ------ Ended super_pi run : Tue Apr 8 22:02:32 CEST 2008
Min nya LG Laptop - Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz - 2 GB RAM - Ubuntu Hardy
 ------ Started super_pi run : Thu May 1 10:24:39 CEST 2008
 End of initialization. Time=       0.320 Sec.
 I= 1 L=       0        Time=       0.876 Sec.
 I= 2 L=       0        Time=       0.920 Sec.
 I= 3 L=       1        Time=       0.928 Sec.
 I= 4 L=       2        Time=       0.924 Sec.
 I= 5 L=       5        Time=       0.928 Sec.
 I= 6 L=      10        Time=       0.952 Sec.
 I= 7 L=      21        Time=       0.940 Sec.
 I= 8 L=      43        Time=       0.920 Sec.
 I= 9 L=      87        Time=       0.920 Sec.
 I=10 L=     174        Time=       0.924 Sec.
 I=11 L=     349        Time=       0.928 Sec.
 I=12 L=     698        Time=       0.920 Sec.
 I=13 L=    1396        Time=       0.924 Sec.
 I=14 L=    2794        Time=       0.916 Sec.
 I=15 L=    5588        Time=       0.916 Sec.
 I=16 L=   11176        Time=       0.908 Sec.
 I=17 L=   22353        Time=       0.900 Sec.
 I=18 L=   44707        Time=       0.868 Sec.
 I=19 L=   89415        Time=       0.804 Sec.
 End of main loop
 End of calculation.    Time=      18.345 Sec.
 End of data output.    Time=       0.120 Sec.
 Total calculation(I/O) time=      18.465(       0.736) Sec.
 ------ Ended super_pi run : Thu May 1 10:24:57 CEST 2008
Min nya stationära dator - Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz - 2 GB RAM - Ubuntu Hardy
 ------ Started super_pi run : Fri May 9 19:25:56 CEST 2008
 End of initialization. Time=       0.212 Sec.
 I= 1 L=       0        Time=       0.548 Sec.
 I= 2 L=       0        Time=       0.624 Sec.
 I= 3 L=       1        Time=       0.620 Sec.
 I= 4 L=       2        Time=       0.628 Sec.
 I= 5 L=       5        Time=       0.624 Sec.
 I= 6 L=      10        Time=       0.624 Sec.
 I= 7 L=      21        Time=       0.624 Sec.
 I= 8 L=      43        Time=       0.628 Sec.
 I= 9 L=      87        Time=       0.624 Sec.
 I=10 L=     174        Time=       0.624 Sec.
 I=11 L=     349        Time=       0.624 Sec.
 I=12 L=     698        Time=       0.624 Sec.
 I=13 L=    1396        Time=       0.624 Sec.
 I=14 L=    2794        Time=       0.628 Sec.
 I=15 L=    5588        Time=       0.620 Sec.
 I=16 L=   11176        Time=       0.616 Sec.
 I=17 L=   22353        Time=       0.608 Sec.
 I=18 L=   44707        Time=       0.580 Sec.
 I=19 L=   89415        Time=       0.540 Sec.
 End of main loop
 End of calculation.    Time=      12.321 Sec.
 End of data output.    Time=       0.072 Sec.
 Total calculation(I/O) time=      12.393(       0.432) Sec.
 ------ Ended super_pi run : Fri May 9 19:26:08 CEST 2008
Kassör i Föreningen Ubuntu Sverige
Vi hjälper Ubuntu Sverige att marknadsföra användningen av fri och öppen programvara!
Köp klistermärken, böcker och installations-/Live-skivor hos oss.
Tompalaz
OS: RHEL/CentOS
Inlägg av Tompalaz »
Core 2 Duo/Conroe E6750 @ 2.66Ghz
2gb RAM (XMS2)
------ Started super_pi run : fre apr 11 17:30:03 CEST 2008
Parameter(%i) to super_pi is missing. Parameter value ? 20
End of initialization. Time= 0.224 Sec.
I= 1 L= 0 Time= 0.688 Sec.
I= 2 L= 0 Time= 0.788 Sec.
I= 3 L= 1 Time= 0.784 Sec.
I= 4 L= 2 Time= 0.768 Sec.
I= 5 L= 5 Time= 0.812 Sec.
I= 6 L= 10 Time= 0.792 Sec.
I= 7 L= 21 Time= 0.772 Sec.
I= 8 L= 43 Time= 0.768 Sec.
I= 9 L= 87 Time= 0.756 Sec.
I=10 L= 174 Time= 0.788 Sec.
I=11 L= 349 Time= 0.772 Sec.
I=12 L= 698 Time= 0.784 Sec.
I=13 L= 1396 Time= 0.772 Sec.
I=14 L= 2794 Time= 0.760 Sec.
I=15 L= 5588 Time= 0.768 Sec.
I=16 L= 11176 Time= 0.756 Sec.
I=17 L= 22353 Time= 0.728 Sec.
I=18 L= 44707 Time= 0.728 Sec.
I=19 L= 89415 Time= 0.676 Sec.
End of main loop
End of calculation. Time= 15.265 Sec.
End of data output. Time= 0.096 Sec.
Total calculation(I/O) time= 15.361( 0.588) Sec.
------ Ended super_pi run : fre apr 11 17:30:56 CEST 2008
Bossieman
Knepiga siffror här med en splirans ny Zepto Nox med en Core2Duo P9500@2.53GHz och 4GB RAM
  • ubuntu@ubuntu:~/super_pi$ ./super_pi 20
    compilation.
    ------ Started super_pi run : Sun Sep 14 20:19:05 UTC 2008
    End of initialization. Time= 0.228 Sec.
    I= 1 L= 0 Time= 0.652 Sec.
    I= 2 L= 0 Time= 0.748 Sec.
    I= 3 L= 1 Time= 0.744 Sec.
    I= 4 L= 2 Time= 0.744 Sec.
    I= 5 L= 5 Time= 0.744 Sec.
    I= 6 L= 10 Time= 0.744 Sec.
    I= 7 L= 21 Time= 0.744 Sec.
    I= 8 L= 43 Time= 0.740 Sec.
    I= 9 L= 87 Time= 0.744 Sec.
    I=10 L= 174 Time= 0.744 Sec.
    I=11 L= 349 Time= 0.740 Sec.
    I=12 L= 698 Time= 0.744 Sec.
    I=13 L= 1396 Time= 0.744 Sec.
    I=14 L= 2794 Time= 0.740 Sec.
    I=16 L= 11176 Time= 0.736 Sec.
    I=17 L= 22353 Time= 0.720 Sec.
    I=18 L= 44707 Time= 0.696 Sec.
    I=19 L= 89415 Time= 0.644 Sec.
    End of main loop
    End of calculation. Time= 14.641 Sec.
    Total calculation(I/O) time= 14.725( 0.544) Sec.
    ------ Ended super_pi run : Sun Sep 14 20:19:19 UTC 2008
Detta värde är något lägre än vad en Core2Duo T9300@2.5GHz och 2GB Ram
P9500 är även bra mycket dyrare +700 SEK
Kanske minnet som är sämre?
Bossieman
Hund skrev:Kanske minnet som är sämre?
Noxen har 4 GB (2x2GB) DDR2 PC6400 800MHZ och GGS-datan har 2 x Kingston SODIMM DDR2 667MHz 1GB
Tror att p9500 bara är en strömsnålare T9300 som de kört upp lite i klocks för att kompensera. L2 cache är identiskt. ???
jonke
Inlägg av jonke »
6000+, 2GB ram
 compilation.
 ------ Started super_pi run : mån sep 15 11:22:42 CEST 2008
 End of initialization. Time=       0.328 Sec.
 I= 1 L=       0        Time=       1.036 Sec.
 I= 2 L=       0        Time=       1.188 Sec.
 I= 3 L=       1        Time=       1.196 Sec.
 I= 4 L=       2        Time=       1.208 Sec.
 I= 5 L=       5        Time=       1.196 Sec.
 I= 6 L=      10        Time=       1.200 Sec.
 I= 7 L=      21        Time=       1.200 Sec.
 I= 8 L=      43        Time=       1.200 Sec.
 I= 9 L=      87        Time=       1.204 Sec.
 I=10 L=     174        Time=       1.200 Sec.
 I=11 L=     349        Time=       1.216 Sec.
 I=12 L=     698        Time=       1.212 Sec.
 I=13 L=    1396        Time=       1.200 Sec.
 I=14 L=    2794        Time=       1.192 Sec.
 I=15 L=    5588        Time=       1.188 Sec.
 I=16 L=   11176        Time=       1.208 Sec.
 I=17 L=   22353        Time=       1.192 Sec.
 I=18 L=   44707        Time=       1.152 Sec.
 I=19 L=   89415        Time=       1.080 Sec.
 End of main loop
 End of calculation.    Time=      23.753 Sec.
 Total calculation(I/O) time=      23.877(       0.680) Sec.
 ------ Ended super_pi run : mån sep 15 11:23:09 CEST 2008
diff
Inlägg av diff »
Vad ska man ange här?
Cadryc
Inlägg av Cadryc »
20 om jag minns rätt
EDIT jepp jag mindes rätt :)
diff
Inlägg av diff »
Cadryc skrev:20 om jag minns rätt
Det ser rätt ut! :-D
 ------ Started super_pi run : Mon Sep 15 15:46:11 CEST 2008
 End of initialization. Time=       0.456 Sec.
 I= 2 L=       0        Time=       1.604 Sec.
 I= 3 L=       1        Time=       1.596 Sec.
 I= 4 L=       2        Time=       1.608 Sec.
 I= 6 L=      10        Time=       1.608 Sec.
 I= 8 L=      43        Time=       1.596 Sec.
 I= 9 L=      87        Time=       1.596 Sec.
 I=10 L=     174        Time=       1.596 Sec.
 I=11 L=     349        Time=       1.584 Sec.
 I=12 L=     698        Time=       1.596 Sec.
 I=13 L=    1396        Time=       1.592 Sec.
 I=15 L=    5588        Time=       1.592 Sec.
 I=16 L=   11176        Time=       1.576 Sec.
 I=17 L=   22353        Time=       1.564 Sec.
 I=18 L=   44707        Time=       1.520 Sec.
 I=19 L=   89415        Time=       1.416 Sec.
 End of main loop
 End of calculation.    Time=      31.526 Sec.
 End of data output.    Time=       0.164 Sec.
 Total calculation(I/O) time=      31.690(       1.100) Sec.
 ------ Ended super_pi run : Mon Sep 15 15:46:44 CEST 2008
2 GB RAM
4200+
32 bitars installerat nu tyvärr
webaake
Inlägg av webaake »
 End of initialization. Time=       1.220 Sec.
 I= 1 L=       0        Time=       3.488 Sec.
 I= 2 L=       0        Time=       4.032 Sec.
 I= 3 L=       1        Time=       4.080 Sec.
 I= 4 L=       2        Time=       4.032 Sec.
 I= 5 L=       5        Time=       4.012 Sec.
 I= 6 L=      10        Time=       4.060 Sec.
 I= 7 L=      21        Time=       4.056 Sec.
 I= 8 L=      43        Time=       4.096 Sec.
 I= 9 L=      87        Time=       3.896 Sec.
 I=10 L=     174        Time=       3.960 Sec.
 I=11 L=     349        Time=       3.968 Sec.
 I=12 L=     698        Time=       4.012 Sec.
 I=13 L=    1396        Time=       4.020 Sec.
 I=14 L=    2794        Time=       4.008 Sec.
 I=15 L=    5588        Time=       4.064 Sec.
 I=16 L=   11176        Time=       3.940 Sec.
 I=17 L=   22353        Time=       4.264 Sec.
 I=18 L=   44707        Time=       3.888 Sec.
 I=19 L=   89415        Time=       3.592 Sec.
 End of main loop
 End of calculation.    Time=      79.745 Sec.
 End of data output.    Time=       0.560 Sec.
 Total calculation(I/O) time=      80.305(       1.684) Sec.
 ------ Ended super_pi run : mån sep 15 18:22:15 CEST 2008
Pentium 4 2 Ghz
Intel Core™ 2 Duo E8400 och Corsair XMS2 DHX PC6400 DDR2, 2GB:
 ------ Started super_pi run : Mon Sep 15 20:53:42 CEST 2008
 End of initialization. Time=       0.216 Sec.
 I= 1 L=       0        Time=       0.624 Sec.
 I= 2 L=       0        Time=       0.716 Sec.
 I= 3 L=       1        Time=       0.708 Sec.
 I= 4 L=       2        Time=       0.712 Sec.
 I= 5 L=       5        Time=       0.712 Sec.
 I= 6 L=      10        Time=       0.716 Sec.
 I= 7 L=      21        Time=       0.712 Sec.
 I= 8 L=      43        Time=       0.712 Sec.
 I= 9 L=      87        Time=       0.712 Sec.
 I=10 L=     174        Time=       0.712 Sec.
 I=11 L=     349        Time=       0.716 Sec.
 I=12 L=     698        Time=       0.712 Sec.
 I=13 L=    1396        Time=       0.708 Sec.
 I=14 L=    2794        Time=       0.712 Sec.
 I=15 L=    5588        Time=       0.708 Sec.
 I=16 L=   11176        Time=       0.700 Sec.
 I=17 L=   22353        Time=       0.684 Sec.
 I=18 L=   44707        Time=       0.664 Sec.
 End of main loop
 End of calculation.    Time=      14.057 Sec.
 Total calculation(I/O) time=      14.145(       0.464) Sec.
 ------ Ended super_pi run : Mon Sep 15 20:53:58 CEST 2008
BadOmen
Inlägg av BadOmen »
P4 3.2 Ghz 1GB RAM
 ./super_pi 20
 compilation.
 ------ Started super_pi run : mån sep 15 21:15:03 CEST 2008
 End of initialization. Time=       0.548 Sec.
 I= 1 L=       0        Time=       1.664 Sec.
 I= 2 L=       0        Time=       1.900 Sec.
 I= 3 L=       1        Time=       1.908 Sec.
 I= 4 L=       2        Time=       1.924 Sec.
 I= 5 L=       5        Time=       1.916 Sec.
 I= 6 L=      10        Time=       1.928 Sec.
 I= 7 L=      21        Time=       1.912 Sec.
 I= 8 L=      43        Time=       1.932 Sec.
 I= 9 L=      87        Time=       1.916 Sec.
 I=10 L=     174        Time=       1.924 Sec.
 I=11 L=     349        Time=       1.912 Sec.
 I=12 L=     698        Time=       1.884 Sec.
 I=13 L=    1396        Time=       1.900 Sec.
 I=14 L=    2794        Time=       1.896 Sec.
 I=15 L=    5588        Time=       1.900 Sec.
 I=16 L=   11176        Time=       1.880 Sec.
 I=17 L=   22353        Time=       1.876 Sec.
 I=18 L=   44707        Time=       1.812 Sec.
 I=19 L=   89415        Time=       1.704 Sec.
 End of main loop
 End of calculation.    Time=      37.742 Sec.
 End of data output.    Time=       0.188 Sec.
 Total calculation(I/O) time=      37.930(       0.980) Sec.
 ------ Ended super_pi run : mån sep 15 21:15:41 CEST 2008
webaake
Inlägg av webaake »
Shuttle KPC 45, Celeron 430 1,8 Ghz:
 End of initialization. Time=       0.400 Sec.
 I= 1 L=       0        Time=       1.228 Sec.
 I= 2 L=       0        Time=       1.404 Sec.
 I= 3 L=       1        Time=       1.400 Sec.
 I= 4 L=       2        Time=       1.412 Sec.
 I= 5 L=       5        Time=       1.400 Sec.
 I= 6 L=      10        Time=       1.404 Sec.
 I= 7 L=      21        Time=       1.404 Sec.
 I= 8 L=      43        Time=       1.408 Sec.
 I= 9 L=      87        Time=       1.404 Sec.
 I=10 L=     174        Time=       1.404 Sec.
 I=11 L=     349        Time=       1.416 Sec.
 I=12 L=     698        Time=       1.416 Sec.
 I=13 L=    1396        Time=       1.396 Sec.
 I=14 L=    2794        Time=       1.400 Sec.
 I=15 L=    5588        Time=       1.408 Sec.
 I=16 L=   11176        Time=       1.388 Sec.
 I=17 L=   22353        Time=       1.376 Sec.
 I=18 L=   44707        Time=       1.328 Sec.
 I=19 L=   89415        Time=       1.248 Sec.
 End of main loop
 End of calculation.    Time=      27.738 Sec.
 End of data output.    Time=       0.140 Sec.
 Total calculation(I/O) time=      27.878(       0.784) Sec.
 ------ Ended super_pi run : ons sep 17 07:38:29 CEST 2008
