Talsyntes:____"För Folk I Tiden"
Hans Linde
OS: Crunchbang
Re: Talsyntes:____"För Folk I Tiden"____[HÖGTRYCKSTRÅD]
Inlägg av Hans Linde »
Kors i taket.
Men fråga mig inte varför.
Man ska ju inte behöva spela en CD först innan det funkar.
Det för funkar nu.
# aplay ~/test.wav
Playing WAVE '/root/test.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
Konservburk
Inlägg av Konservburk »
Har mplayer också börjat fungera helt plötsligt?
Hans Linde
OS: Crunchbang
Tyvärr inte... ::)
# mplayer /root/test.wav
MPlayer dev-SVN-rUNKNOWN-4.2.2 (C) 2000-2007 MPlayer Team
CPU: Intel Celeron Covington/Pentium II Deschutes,Tonga/Pentium II Xeon (Family: 6, Model: 5, Stepping: 2)
CPUflags: MMX: 1 MMX2: 0 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
115 audio & 237 video codecs
[MENU] Can't open menu config file: /root/.mplayer/menu.conf
Menu inited: /etc/mplayer/menu.conf
Playing /root/test.wav.
Audio file file format detected.
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 16000 Hz, 1 ch, s16le, 256.0 kbit/100.00% (ratio: 32000->32000)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
[AO OSS] audio_setup: Can't open audio device /dev/dsp: No such file or director y
AO: [alsa] 16000Hz 1ch s16le (2 bytes per sample)
Video: no video
Starting playback...
MPlayer interrupted by signal 4 in module: decode_audio
- MPlayer crashed by an 'Illegal Instruction'.
It usually happens when you run it on a CPU different than the one it was
compiled/optimized for.
Verify this!
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
Hans Linde
OS: Crunchbang
Mplayer har jag i tillgång från
Meny -> Multimedia -> Mplayer media player
Men det kommer ett gäng fel meddelande om jag tycker det.
Hans Linde
OS: Crunchbang
Det är samma som tidigare.
http://ubuntu-se.org/phpBB3/viewtopic.p ... 80#p297110
Nja... den här kommer först.
Rune.K
Inlägg av Rune.K »
Jag börjar bli nyfiken på vad ni gör.
Är det en förbättring av de vanliga text-to-speech-programmen?
Eller är det så att ni egentligen håller på och bygger en hembränningsapparat och skickar kodade bygginstruktioner via det här forumet?
mvh Rune
Konservburk
Hans Linde skrev:MPlayer interrupted by signal 4 in module: decode_audio
Verify this!
Det här felmeddelandet tyder på att du försöker använda en mplayer som är byggd för en processor du inte har. Du använder kanske en i686-version av mplayer på en i486-processor?
Hans Linde
OS: Crunchbang
Säg inget till FRA, men du har avslöjat oss :)
Fast de kanske har ett intresse i att få vara med :D
Kortfattat:
Ja vi försöker utöka kompabiliteten på den Talsyntes vi , Konservburk har gjort.
Men Puppy är en.... :'( .....inte likadan som Ubuntu.
Hans Linde
OS: Crunchbang
Ack nej :o
Det här är en av de första HemPC-maskinerna. Pentium 2, 450MHz.....osv.
Mao det här är en riktigt lågbudget lösning. Det är där Puppy Linux får en framskjuten betydelse.
I övriga funktioner fungerar PC som en köpt PC. :)
Rune.K
Inlägg av Rune.K »
Hans Linde skrev: Kortfattat:
Kan du/ni utveckla det lite! om kompabiliteten
Jag är sugen på att prova, om jag får vara med?
Hans Linde
OS: Crunchbang
Om Mplayer inte trivs i den här PCn.
Finns det ett alternativ som vi kan använda. Det är kanske inte trorligt att många avser att ha så gammla PCs, men 450MHz är troligt (på modernare och effektivare arkitektur).
Hmmm......men vänta nu..jag är nästa säker på att jag fick Crunchbang Linux Lite (8.04) att funka med r31..
Hans Linde
OS: Crunchbang
Du får gärna vara med. Vi har väntat på att någon skulle våga fråga.
du har r31 här:
http://ubuntu-se.org/phpBB3/download/file.php?id=3109
Men du ska installera den på en Ubuntu eller någon av de som jag listat på 1a inlägget i tråden.
http://ubuntu-se.org/phpBB3/viewtopic.p ... 08#p248992
Hans Linde
OS: Crunchbang
P2-i386-cbl
amd64c-cbl
förklaring: P2=Pentium2 450MHz o 250Mram, cbl=Crunchbang Linux Lite
Ja det stämmer, att Mplayer och r31 funkar med en Ubuntu version som Crunchbang är.
Konservburk
Hans Linde skrev:Om Mplayer inte trivs i den här PCn.
Det är inte mplayer i sig som är problemet. Du har helt enkelt lyckats installera fel version av mplayer.
Hans Linde
OS: Crunchbang
Kan vi ha ett fel i r31 som finns i "förrådet".
se djkmmo's meddelande
Hans Linde
OS: Crunchbang
Text ur medelanden.
Var får man support på talsyntes.sh? Jag har laddat ned det och packat upp det, men det händer inget över huvud taget när jag försöker köra det.
djkmmo
Säger du det????
Det kanske har blivit något fel på det som ligger där.
Vi har inte kontrollerat på en tid,
och nu har vi problem att få igång den på Puppy Linux.
Konservburk,
du få nog bekräfta att vi kör med "äkta vara".
Hans
Ni kanske skulle ha en supporttråd att ställa frågor i också? Det känns lite fel att komma in med frågor om hur man använder det mitt uppe i utvecklingsdiskussionerna.
djkmmo
Jag tror att du rätt.
Det är troligt att är därför som det inte är andra som har "hakat på", men jag vet inte om vi har bandbredd för bevakning bredvid....jo det måste jo gå....fast hur??
Det blir något för Dig Konservburk, som sitter närmare "Pudelns kärna".
Det är inget problem iaf om du, djkmmo eller någon annan, hoppa in och frågar.
Jag lägger ut det här i Tråden.
Hans
Hans Linde
OS: Crunchbang
Mplayer är av den här versionen och jag ganska säker på att jag inte försökt installera det själv.
Eller gjorde jag det innan vi började med Talsyntesen.........hmmmm
# mplayer
Usage: mplayer [options] [url|path/]filename
Basic options: (complete list in the man page)
-vo <drv> select video output driver ('-vo help' for a list)
-ao <drv> select audio output driver ('-ao help' for a list)
vcd://<trackno> play (S)VCD (Super Video CD) track (raw device, no mount)
dvd://<titleno> play DVD title from device instead of plain file
-alang/-slang select DVD audio/subtitle language (by 2-char country code)
-ss <position> seek to given (seconds or hh:mm:ss) position
-nosound do not play sound
-fs fullscreen playback (or -vm, -zoom, details in the man page)
-x <x> -y <y> set display resolution (for use with -vm or -zoom)
-sub <file> specify subtitle file to use (also see -subfps, -subdelay)
-playlist <file> specify playlist file
-vid x -aid y select video (x) and audio (y) stream to play
-fps x -srate y change video (x fps) and audio (y Hz) rate
-pp <quality> enable postprocessing filter (details in the man page)
-framedrop enable frame dropping (for slow machines)
Basic keys: (complete list in the man page, also check input.conf)
<- or -> seek backward/forward 10 seconds
down or up seek backward/forward 1 minute
pgdown or pgup seek backward/forward 10 minutes
< or > step backward/forward in playlist
p or SPACE pause movie (press any key to continue)
q or ESC stop playing and quit program
+ or - adjust audio delay by +/- 0.1 second
o cycle OSD mode: none / seekbar / seekbar + timer
* or / increase or decrease PCM volume
x or z adjust subtitle delay by +/- 0.1 second
r or t adjust subtitle position up/down, also see -vf expand
* * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * *
Konservburk
Jag provade nu att ladda ner r31 härifrån, och det fungerade bra för mig.
curl -s 'http://ubuntu-se.org/phpBB3/download/file.php?id=3109' | tar -jx
./talsyntes.sh
Det är bra om vi lyckas komma fram till varför det inte fungerar för vissa. Det är förmodligen inget svårt att rätta till bara vi vet vad det egentliga problemet är.
Konservburk
Hans Linde skrev:MPlayer dev-SVN-rUNKNOWN-4.2.2 (C) 2000-2007 MPlayer Team
Jämför med cat /proc/cpuinfo och se om det stämmer överrens.
Hans Linde
OS: Crunchbang
Det finns ingen cat /proc/cpuinfo ???
Det finns ingen /cat/
Vill du ha en bild / - katalogen?
