WebM, tretton år senare
Re: WebM, nio år senare
Libvpx 1.8.1 är på gång. Beskrivningen är dock rätt märklig. :-\
Orpington Duck Release Candidate
Johann Koenig skrev:The Orpington Duck is a hybrid composed of ducks from previous libvpx releases: Aylesbury (v0.9.5), Cayuga (v0.9.7), and Indian Runner (v1.4.0). We will be finalizing a v1.8.1 release soon. If you have any issues with the current branch please let us know.
SVT-AV1 v0.6.0
Nu också med avkodare.
  • Inital decoder implementation
  • Static library support
  • Alt-ref pictures – temporal filtering
  • Adaptive Transform Block for INTRA
  • Adaptive QP scaling
  • Decoder – Support for Tiles and 10bit
  • API – add option to calculate / report PSNR values
  • Support for segmentation
  • SIMD Optimizations
  • Downsampling 2×2 filtering
  • Handle incomplete SBs
  • MACROS / trailing / tabs-spaces cleanup
FFmpeg 4.2 ”Ada” har släppts, med bland annat AV1-avkodning med Dav1d.
https://ffmpeg.org/index.html#pr4.2
SVT-AV1 v0.7.0
[0.7.0] - 2019-09-26
Encoder
  • Enhanced MRP Reference Frames
  • Intra Inter Compound
  • QP Modulation support
  • MFMV Support
  • MD Staging design [Up to 4 MD stages and 3 prediction classes: Intra / Inter / Compound]
  • Compound Motion prediction
  • 10-bit Mode Decision support for Intra
  • Thread safe resource allocation
  • Added AVX512 Optimizations
  • Added AVX2 Optimizations
Decoder
  • Screen Content Tools
  • Temporal MV scan support
  • Inter support
  • Screen Content Tools support
  • Post Processing Filters support
  • Compound Mode (InterInter & InterIntra) Tool support
  • Decoder Film Grain support
Det finns nu ytterligare en AV1-avkodare, libgav1: https://chromium.googlesource.com/codecs/libgav1/
JoWa skrev:Det finns nu ytterligare en AV1-avkodare, libgav1: https://chromium.googlesource.com/codecs/libgav1/
Phoronix visar att den nya libgav1 är mycket långsammare än Dav1d:
DAV1D vs. LIBGAV1 Performance – Benchmarking Google’s New AV1 Video Decoder
Dav1d 0.5.0 ‘Asiatic Cheetah’:
0.5.0 is a medium release fixing regressions and minor issues, and improving speed significantly:
  • Export ITU T.35 metadata
  • Speed improvements on blend_ on ARM
  • Speed improvements on decode_coef and MSAC
  • NEON optimizations for blend*, w_mask_, ipred functions for ARM64
  • NEON optimizations for CDEF and warp on ARM32
  • SSE2 optimizations for MSAC hi_tok decoding
  • SSSE3 optimizations for deblocking loopfilters and warp_affine
  • AVX-2 optimizations for film grain and ipred_z2
  • SSE4 optimizations for warp_affine
  • VSX optimizations for wiener
  • Fix inverse transform overflows in x86 and NEON asm
  • Fix integer overflows with large frames
  • Improve film grain generation to match reference code
  • Improve compatibility with older binutils for ARM
  • More advanced Player example in tools
https://code.videolan.org/videolan/dav1 ... aster/NEWS
Phoronix har mätt och jämfört med 0.4.0:
Dav1d 0.5 Released With AVX2, SSSE3 & ARM64 Performance Improvements - Benchmarks
Dav1d 0.5.1 ‘Asiatic Cheetah’:
0.5.1 is a small release improving speeds and fixing minor issues compared to 0.5.0:
  • SSE2 optimizations for CDEF, wiener and warp_affine
  • NEON optimizations for SGR on ARM32
  • Fix mismatch issue in x86 asm in inverse identity transforms
  • Fix build issue in ARM64 assembly if debug info was enabled
  • Add a workaround for Xcode 11 -fstack-check bug
Rav1e 0.1.0 har släppts.
Rav1e är en AV1-kodaren skriven i Rust.
First official release, published during the Video Dev Days 2019 in Tokyo.
Features
  • Intra and inter frames
  • 64×64 superblocks
  • 4×4 to 64×64 RDO-selected square and 2:1/1:2 rectangular blocks
  • DC, H, V, Paeth, smooth, and a subset of directional prediction modes
  • DCT, (FLIP-)ADST and identity transforms (up to 64×64, 16×16 and 32×32 respectively)
  • 8-, 10- and 12-bit depth color
  • 4:2:0 (full support), 4:2:2 and 4:4:4 (limited) chroma sampling
  • 11 speed settings (0–10)
  • Near real-time encoding at high speed levels
  • Rate control (single-pass and two-pass)
  • Temporal RDO
  • Scene cut detection
  • CLI tool and C API
https://github.com/xiph/rav1e/releases/tag/0.1.0
SVT-AV1 v0.7.5
[0.7.5] - 2019-11-24
Encoder
  • RDOQ for 10-bit
  • Inter Intra Class pruning at MD-Staging
  • Global Motion Vector support for 8-bit and 10-bit
  • Interpolation Filter Search support for 10-bit
  • Palette Prediction support
  • 2-pass encoding support
  • ATB 10-bit support at the encode pass
  • Simplified MD Staging [only 3 stages]
  • Inter-Inter and Inter-Intra Compound for 10-bit
  • Intra Paeth for 10-bit
  • Filter Intra Prediction
  • New-Near and Near-New support
  • OBMC Support for 8-bit and 10-bit
  • RDOQ Chroma
  • ATB Support for Inter Blocks
  • Temporal Filtering for 10-bit
  • Eight-pel support in predictive ME
  • MCTS Tiles support
Decoder
  • SuperRes support
  • Reference Frame Scaling support
  • 12-bit support
  • Annex B support
Dav1d 0.5.2 ‘Asiatic Cheetah’:
0.5.2 is a small release improving speed for ARM32 and adding minor features:
  • ARM32 optimizations for loopfilter, ipred_dc|h|v
  • Add section-5 raw OBU demuxer
  • Improve the speed by reducing the L2 cache collisions
  • Fix minor issues
Pekin Duck Release Candidate
Ett försläpp av den kommande libvpx 1.8.2.
Rav1e 0.2.0 har släppts, och är åtskilligt snabbare än 0.1.0.
v0.2.0: Yuletide Greetings
Improvements
  • Faster, overall 40%-70% faster than v0.1.0 depending on the encoding settings.
  • Optional serialization/deserialization of the encoding parameters through the feature serialize
    • Optional cli advanced commands to use it.
  • The builds are now using the dwarf debug format for the targets that support it, before it was a mixture of dwarf and stabs due to the nasm defaults.
  • Added a --benchmark hidden flag for the cli for MacOS and Linux.
  • documentation is now available on docs.rs.
Changes
  • Segmentation support is now a tunable SpeedSetting and currently it is default off since it can produce desyncs, this does cause a 3% decrease in quality.
Fixes
  • #1903 - edge-of-frame miscomputation
  • #1858 - desync on speed 0 and 1 when certain quantizers are selected
Known issues
  • #1930 - segmentation encoding may cause desync
https://github.com/xiph/rav1e/releases/tag/v0.2.0
Libvpx, referensimplementering för VP8 och VP9, har nu släppts i en ny version, 1.8.2.
Pekin Duck Release (v1.8.2)
https://chromium.googlesource.com/webm/libvpx/+/v1.8.2
SVT-AV1 v0.8.0
[0.8.0] - 2019-12-20
Encoder
  • Preset Optimizations
  • Single-core execution memory optimization [-lp 1 -lad 0]
  • Rate estimation update enhancements
  • On / off flags for feature run-time switching
  • Auto-max partitioning algorithm support
  • Multi-pass partitioning depth support
  • Remove deprecated RC mode 1 and shifter RC mode 2 and mode 3 to mode 1 and mode 2 respectively
  • Update cost calculation for CDEF Filtering
  • Intra-Inter compound for 10-bit
  • Eigth-pel optimization
  • AVX512 Optimizations
  • AVX2 Optimizations
Decoder
  • Initial multi-threading support
  • Decoder optimizations / cleanup
Build and Testing
  • Bug fixes
  • Improve CI
  • Improve Unit Test Coverage
  • Address C vs asm mismatches
Netflix Now Streaming AV1 on Android (Netflix Technology Blog)
Today we are excited to announce that Netflix has started streaming AV1 to our Android mobile app. AV1 [libaom] is a high performance, royalty-free video codec that provides 20% improved compression efficiency over our VP9 [libvpx] encodes.
