Mitt serverbygge - Raid fråga
skalman65
Mitt serverbygge - Konstig felkod
Inlägg av skalman65 »
Min lycka att fått igång servern igen vart kortvarig.
Inga fel på någon av raid enheterna,
helt normalt på kommandot
cat /proc/mdstat
Men däremot så har jag fått en hel sida med (för mig) obegripliga felkoder
journalctl -p err -b ser ut så här
-- Logs begin at lör 2019-02-02 09:56:16 CET, end at mån 2019-02-04 19:17:12 CET. --
feb 02 09:56:19 server systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:1/4:0:1:0/block/sdc and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:0/4:0:0:0/block/sdb
feb 02 09:56:21 server systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1\x2dpart1.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1\x2dpart1.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:1/4:0:1:0/block/sdc/sdc1 and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:0/4:0:0:0/block/sdb/sdb1
feb 02 09:56:25 server iscsid[1198]: iSCSI daemon with pid=1199 started!
feb 02 10:02:53 server systemd[1566]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d2.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d2.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata6/host5/target5:0:1/5:0:1:0/block/sde and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata6/host5/target5:0:0/5:0:0:0/block/sdd
feb 02 10:02:53 server systemd[1326]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d2.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d2.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata6/host5/target5:0:1/5:0:1:0/block/sde and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata6/host5/target5:0:0/5:0:0:0/block/sdd
feb 02 10:02:53 server systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d2.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d2.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata6/host5/target5:0:1/5:0:1:0/block/sde and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata6/host5/target5:0:0/5:0:0:0/block/sdd
feb 02 10:02:53 server systemd[1566]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:0/4:0:0:0/block/sdb and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:1/4:0:1:0/block/sdc
feb 02 10:02:53 server systemd[1326]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:0/4:0:0:0/block/sdb and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:1/4:0:1:0/block/sdc
feb 02 10:02:53 server systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device: Dev dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2data\x2d1.device appeared twice with different sysfs paths /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:0/4:0:0:0/block/sdb and /sys/devices/pci0000:00/0000:00:1e.0/0000:01:00.0/ata5/host4/target4:0:1/4:0:1:0/block/sdc
loggen fortsätter sedan med ytterligare drygt 100 rader som ser i stort sett likadana ut.
Såg när jag googlade på detta att jag hade något liknande för ett år sedan
Hittade även en buggrapport som jag funderar på om den kan vara aktuell för mig
Någon som vet eller kan guida mig i rätt riktning.
skalman65
Re: Mitt serverbygge - Raid fråga
En av diskarna i raid konfigurationen har rasat för mig,
brukar byta ut dem med någon disk som jag har liggandes sedan tidigare.
Brukar då ta den med minst utrymme som jag har liggandes, men som är större än dem som sitter i raiden sedan tidtagare.
Nu (i turordning) har jag en disk från en laptop, har adapter sedan tidigare för att kunna ansluta den mot 3,5 IDE.
Men kan det ställa till med oväntade problem i en Raid konfiguration.
Då jag måste använda en adapter mellan disk och IDe kabel ?
Nemo
Inlägg av Nemo »
skalman65 skrev:Nu (i turordning) har jag en disk från en laptop, har adapter sedan tidigare för att kunna ansluta den mot 3,5 IDE.
Jag har inte provat det du vill göra, men tycker det inte borde orsaka några problem, så länge datorn hittar igen din disk från din laptop.
Det enda som du behöver tänka på är att ha samma storlek på partitionen i den disk du vill byta ut som de som redan ingår i din RAID konfiguration. (Antar att du kör mjukvarubaserad RAID, har inte läst igenom alla inlägg i denna tråd)
skalman65
Det vart inga problem som du sa Nemo, 2,5 "disken med adapter funkade fint.
Tror att det är tredje gången jag byter disk nu, och det har varje gång varit samma enhet (sdc) som har lagt av, detta trots att sdb som är kopplad på samma array då är "äldre" .
Kan finna det lite lustigt?
