Visa upp ditt skrivbord - (Hardy Heron)
Re: Visa upp ditt skrivbord - (Hardy Heron)
Jag har funderat lite på det. Kanske ska sätta mig ner och börja på det ändå. 8)
#!/usr/bin/python
# themeinfo.py by dbbolton (envyouraudience at gmail)
import gconf
import os
import string
from os.path import exists
from subprocess import call
from time import strftime
#colors
blue = "\033[1;34m"
green = "\033[1;32m"
cyan = "\033[1;36m"
red = "\033[1;31m"
bblue = "\033[0;38;5;12m"
orange = "\033[0;38;5;202m"
yelloworange = "\033[0;38;5;208m"
gold = "\033[0;38;5;214m"
darkorange = "\033[0;38;5;130m"
darkcyan="\033[0;38;5;32m"
#change color back to default
end="\033[0m"
#   OPTIONS
# Is your GTK theme specified in yout .gtkrc.mine file?
include_gtkrcmine = False
# What about your font?
my_font = False
# And your icons?
my_icons = False
# Which window manager?
include_ob = False #openbox
include_mt = True #metacity
include_aw = False  #awesome
# Which terminal are you using?
include_gt = True #gnome-terminal
include_tilda = False
include_urxvt = False
# Do you use feh to set your wallpaper?
include_feh = False
#   END OPTIONS
#define key to get stuff from gconf
key = gconf.client_get_default()
# distro
if exists(os.path.expanduser("/etc/issue")):
	for line in open(os.path.expanduser("/etc/issue")):
		if " " in line:
			distro=line
               		break
else:
	distro = " "
# gtk
if include_gtkrcmine:
	if exists(os.path.expanduser("~/.gtkrc.mine")):
		for line in open(os.path.expanduser("~/.gtkrc.mine")):
			if "/gtk-2.0/gtkrc" in line:
				mygtk=line
				use_my_gtk = True
               			break
			else:
				use_my_gtk = False
else:
	mygtk = " "
	use_my_gtk = False
gnomegtk = key.get_value("/desktop/gnome/interface/gtk_theme")
# fonts
if my_font:
			if "gtk-font-name" in line:
				myfont = line
				use_my_font = True
               			break
			else:
				use_my_font = False
else:
	use_my_font = False
gnomefont = key.get_value("/desktop/gnome/interface/font_name")
#tilda
if exists(os.path.expanduser("~/.tilda/config_0")):
	for line in open(os.path.expanduser("~/.tilda/config_0")):
		if "font" in line:
			tildfont=line
               		break
else:
	tildfont = " "
#gnome-terminal
gtfont = key.get_value("/apps/gnome-terminal/profiles/Default/font")
#urxvt
if exists(os.path.expanduser("~/.Xdefaults")):
	for line in open(os.path.expanduser("~/.Xdefaults")):
		if "urxvt*font" in line:
			urxvtfont=line
               		break
else:
	tildfont = " "
# icons
if my_icons:
			if "icon-theme" in line:
				myicons = line
				use_my_icons = True
				break
			else:
				use_my_icons = False
else:
	myicons = " "
gnomeicons = key.get_value("/desktop/gnome/interface/icon_theme")
# metacity
metacitytheme = key.get_value("/apps/metacity/general/theme")
# openbox
if exists(os.path.expanduser("~/.config/openbox/rc.xml")):
	for line in open(os.path.expanduser("~/.config/openbox/rc.xml")):
		if "<name>" in line:
			ob = line
			break
else:
	ob = " "
# wall
if include_feh:
	if exists(os.path.expanduser("~/.fehbg")):
		for line in open(os.path.expanduser("~/.fehbg")):
			if "feh" in line:
				fehwall = line
				break
			else:
				use_feh_wall = False
else:
	wall=" "
gwallpath = key.get_value("/desktop/gnome/background/picture_filename")[0:-4]
gwallname = gwallpath.split('/')[-1]
#print info
print "\n  "+orange+distro.split(' ')[0]+" "+distro.split(' ')[1]+"\n"
if use_my_gtk:
	print darkcyan+"  GTK:"+end+"                   "+mygtk.split('/')[4]
else:
	print darkcyan+"  GTK:"+end+"                   "+gnomegtk
if use_my_font:
	print darkcyan+"  Font (Apps):"+end+"           "+myfont.split('"')[1]
else:
	print darkcyan+"  Font (Apps):"+end+"           "+gnomefont
if include_tilda:
	print darkcyan+"  Font (Terminal):"+end+"       "+tildfont.split('"')[1]
elif include_gt:
	print darkcyan+"  Font (Terminal):"+end+"       "+gtfont
elif include_urxvt:
	print darkcyan+"  Font (Terminal):"+end+"       "+urxvtfont.split(':')[-1][0:-1]
if use_my_icons:
	print darkcyan+"  Icons:"+end+"                 "+myicons.split('"')[1]
else:
	print darkcyan+"  Icons:"+end+"                 "+gnomeicons
if include_mt:
	print darkcyan+"  Metacity:"+end+"              "+metacitytheme
elif include_ob:
		print darkcyan+"  Openbox:"+end+"               "+ob.split('>')[1][0:-6]
	else:
		print "Openbox theme not found."
elif include_aw:
	print darkcyan+"  WM:"+end+"                    Awesome"
else:
	print darkcyan+"  WM:"+end+"                    ?"
if include_feh:
	print darkcyan+"  Wall:"+end+"                  "+fehwall.split('/')[-1]+"\n"
else:
	print darkcyan+"  Wall:"+end+"                  "+gwallname+"\n"
print "  "+strftime("%A %d %B %Y")+"\n"
#take screenshot
call(["sleep", "1"])
#call("scrot")
Man använder det med kommandot python <namn>.py
Johanna
Inlägg av Johanna »
Ja jag fick ju sambon att gå med på att jag installerade Ubuntu på laptopen också så jag får visa upp den nu när jag är "klar" med den :)
Skrivbordsmiljö/Fönsterhanterare: Gnome/Emerald
Tema: Mac4Lin (http://sourceforge.net/projects/mac4lin)
Emeraldtema: Mac4Lin
Ikontema: Mac4Lin
Bakgrundsbild: Frost Winter Forms (http://www.wallpapers.org/wallpapers/vi ... 68273&ia=0)
Program: Som syns: Avant Window Navigator (awn), och på undre bilden även Nautilus med min hemmapp. Sen är även terminalen, Firefox och Compiz Fusion igång men minimerade / inte fullt lika synligt.
Jag har kärat ner mig totalt i utseendet på OS X, syns det? ;D
Edit: stavfel
max_
Inlägg av max_ »
@Hund
Jag försöker använda ditt script, men jag får error. (Jag döpte filen till hund.)
max@skokartongen:~/Skrivbord$ python hund.py
  File "hund.py", line 67
    break
IndentationError: unexpected indent
Hur ändrar man på det så att säga? :P
Smygis
Inlägg av Smygis »
max_ skrev:@Hund
    break
Sectionen:
# distro
      if " " in line:
         distro=line
                     break
else:
   distro = " "
ska ändras till:
# distro
      if " " in line:
         distro=line
         break
else:
   distro = " "
max_
Inlägg av max_ »
Tack så mycket Smygis!
Det fanns lite andra sådana break-fel, men jag antog att de skulle vara likadant på dom, så det fungerade till slut. :D
Mitt Skrivbord:
Bild Bild
:D
cupe
Inlägg av cupe »
Openbox, irssi, urxvt, visibility.
det var en maktdemonstration..!
tille
Inlägg av tille »
kollektivist
Inlägg av kollektivist »
Vad använder du för gtk-tema och filhanterare?
cupe
Inlägg av cupe »
Ulsak skrev:det var en maktdemonstration..!
Haha, va? ;D
snyggt som fan menar jag... :)
cupe
Inlägg av cupe »
Ulsak skrev:snyggt som fan menar jag... :)
Hehe, tack. :)
Skrivbordsmiljö/Fönsterhanterare: Gnome -Compiz-Fusion
Tema: Gnome/GTK-murrine (fönsterram Aging Gorilla)
Bakgrundsbild: En gimpad detalj från en försommarbild tagen av min fru, helt otroligt träffsäker färgkombo!
Ikontema: Gartoon
Program: Screenlets ( fast det var roligare att confa conky :P ), AWN
sommarskrivbord
sommarskrivbord
Slobban
Inlägg av Slobban »
Är det bara jag som använder mig av multipla skrivbordsytor? ;s
Förresten, hur får man rythmbox att bara visa sig som ett litet cd-fodral som jag sett på vissa screens?
max_
Inlägg av max_ »
Det är väl screenlets man kan använda sig av om man vill ha albumet på skrivbordet. :)
Det finns kanske andra alternativ, men screenlets fungerar iallafall.
AntonPetts
Inlägg av AntonPetts »
Är det bara jag som använder cylindern? :D
Finns inte för ubuntu än (det går ju förstås men jag tyckte det kändes väldigt instabilt när jag försökte). Kör Archlinux nu, mest för att det är mycket snabbare än ubuntu: de flesta program, inkl. firefox, startar på under en sekund och uppstarten tar ca 20 s (och då har jag ju ändå compiz/emerald igång, kan inte föreställa mig hur snabbt det skulle gå med t.ex. fluxbox... :P).
Mina teman: iod Suite, SimplyGrey
max_
Inlägg av max_ »
Du skulle inte kunna göra en liten screencast på cylindern tror du?
är det något funktionellt värde i de, eller är de bara för syns skull? :P
AntonPetts
max_ skrev:Du skulle inte kunna göra en liten screencast på cylindern tror du?
http://www.youtube.com/results?search_q ... type=&aq=f Finns redan gott om screencasts, det finns förresten en sfär också, fast den är inte lika häftig som det ser ut tycker jag :).
I fråga om funktionalitet så kan man ju ser mer av skrivborden på en gång, inga kanter ivägen. Den går lite långsammare än kuben också. men det är lätt värt det när man har nästan 400fps i compiz :P (50-60 när cylindern körs).
max_
Inlägg av max_ »
Dum som ja e glömde jag att leta på youtube xD
Men det verkar bra... ;)
cupe
Inlägg av cupe »
Openbox, urxvt, irssi, pcmanfm, firefox, pidgin, visibility
